Mapping of a Complex Region Using a Rational Function
The discussion focuses on determining the image of a complex region S under the rational function f(z) = (z + 1) / (z - 1). The initial steps involve algebraic manipulation leading to the expression for the imaginary part of f(z), which is given as Im(z) = -2y/((x - 1)^2 + y^2). Participants identify that the boundaries of the region correspond to the equations resulting from setting the imaginary part equal to 1 and 2, respectively. It is concluded that these boundaries represent two circles, clarifying the mapping of the region S under the transformation. The conversation emphasizes the importance of analyzing boundary conditions to understand the geometric implications of the function.
Genericcoder
Let S = {z : 1<= Im(z) <=2}. Determine f(S) if f: S ->C
defined by
z = x + iy
[attempt at solution]
so here my solution
f(z) = 1 + 2/(z - 1)
after doing some algebra <-> f(z) = x^2 + y^2/((x - 1)^2 + y^2) - [2y/((x-1)^2 + y^2)]i
therefore Im(z) = -2y/((x - 1)^2 + y^2) so F(S) = {z : 1<= (-2y)/((x-1)^2 + y^2) <= 2}
but I am stuck at this point I don't know wat does this represent.
defined by
z = x + iy
so here my solution
Concentrate on what the boundaries of your region are. For example, if 1=(-2y)/((x-1)^2 + y^2) what kind of curve is that? Multiply it out and complete the square. At a more abstract level f(z) is a Mobius transformation. It will map lines to lines or circles, yes?
yes I did that I got something weird
I got (x-1)^2 + y^2 <= -2y <= 2( (x - 1)^2 + y^2)) the way I see it its between two circles but how to show that ?
Just look at the boundaries. Where your inequality becomes an equality. 1=(-2y)/((x-1)^2 + y^2) and 2=(-2y)/((x-1)^2 + y^2). What are the boundary curves? And yes, they are two circles.
o I see I figured it out ty a lot Dick!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 27 ·
