58 replies · 9K views
Physicsissuef
- 908
- 0
Why it doesn't?
Homework Helper
- 2,143
- 52
You said these were the conditions :
1. [tex]Re(z) \geq 0[/tex]
2. [tex]Im(z) \geq 0[/tex]
3. [tex]|z| \leq 2[/tex]
Part of your picture is to the left of the vertical axis, so it doesn't satisfy (1). Part of your picture is below the horizontal axis, so it doesn't satisfy (2). And part of it is further away from the origin than 2, so it doesn't satisfy (3).
- 12,179
- 186
Physicsissuef, I see you included points where x < 0 as well as y < 0. Does that not violate two of the requirements?
Physicsissuef
- 908
- 0
So it is, http://i28.tinypic.com/sl0foz.jpg"...
- 186
Yes, good job!
You might want to indicate the value of the radius in the figure.
Physicsissuef
- 908
- 0
- 186
No.
Try getting the equation (or inequality) in terms of x and y first. By now you've seen enough examples that you should be able to do it.
Then draw the figure.
Physicsissuef
- 908
- 0
[tex]
<br />
1 \leq x^2+y^2 \leq 9<br />
[/tex]
But the question is how will I draw it?
- 12,179
- 186
Do you honestly not recognize equations for simple familiar figures in what you have written? Even after doing numerous similar problems?
To be honest and frank with you, I am wondering how it will be possible for you to answer questions like this on an exam in the future.
Nick89
- 553
- 0
Do you understand that (and why) [tex]x^2 + y^2 = r^2[/tex] represents a circle with radius r?
Do you understand that [tex]x^2 + y^2 < r^2[/tex] represents a disk with radius r, not including the boundary?
Physicsissuef
- 908
- 0
Redbelly98 said:Do you honestly not recognize equations for simple familiar figures in what you have written? Even after doing numerous similar problems?
Redbelly98 please be patient with me... I just started to learn about Complex numbers... I can't be expert with 2 hours of learning for god sake...
Nick89 said:Do you understand that (and why) [tex]x^2 + y^2 = r^2[/tex] represents a circle with radius r?
For how many times, I understand. [tex]r^2=x^2+y^2[/tex] because of Pita gore theorem in polar coordinate system.
Lets go back to the problem. Is it like http://i25.tinypic.com/24wya1d.jpg"
Physicsissuef
- 908
- 0
Is it like that, please I need confirmation. Thank you...
Physicsissuef
- 908
- 0
Ok. Thanks. And for [itex]|z| \leq 4[/itex], is it like http://i31.tinypic.com/511rno.jpg"
Physicsissuef
- 908
- 0
Ok, thanks. And what about this http://i26.tinypic.com/jj360y.jpg"
a)[tex]1 \leq |z| \leq 2[/tex]
b)
[tex] -2 \leq Re(z) \leq 2[/tex]
[tex] -2 \leq Im(z) \leq 2[/tex]
c)[tex]|z-(1,1)| \leq \sqrt{2}[/tex]
b)
Physicsissuef
- 908
- 0
[tex]-2 \leq Re(z) \leq 2[/tex]
[tex]0 \leq Im(z) \leq 2[/tex]
It was typo. Now is it correct?
Physicsissuef
- 908
- 0
Ok, thanks. And can you please tell me about this two pictures. http://i31.tinypic.com/18d3py.jpg" I will be very happy if you can confirm me. Thank you once again...
Homework Helper
- 42,895
- 983
Yes, [itex]|z|\le 4[/itex], in the complex plane, refers to those points, (x,y), whose distance from (0,0) is less than or equal to 4. That consists of the circle with center at (0,0) and radius 4 as well as its interior.Physicsissuef said:Ok. Thanks. And for [itex]|z| \leq 4[/itex], is it like http://i31.tinypic.com/511rno.jpg"
Physicsissuef
- 908
- 0
Yes, but can you confirm me about the pictures in the above post, they're not same. Thanks.
Homework Helper
- 2,143
- 52
Physicsissuef said:Ok, thanks. And can you please tell me about this two pictures. http://i31.tinypic.com/18d3py.jpg" I will be very happy if you can confirm me. Thank you once again...
Yes they're correct.
Physicsissuef
- 908
- 0
They are all correct? What about i) [itex]0 < |z| \leq 3[/itex]? How will I make the disk without zero?
Nick89
- 553
- 0
Usually you put a circle (like an 'o') on the point, instead of a dot.
For example, this could be the line [itex]y = 2x + 1, x \neq 3[/itex]:
Code:
| o
|_________
Physicsissuef
- 908
- 0
Ok, thank you, and my other tasks are correct? (I mean, with stuff like shadowing and circles like in this case) Is it correct with the angles?
Nick89
- 553
- 0
Yes. Don't worry about these things (how to draw it) too much, as long as it's clear what you mean. If your teacher understands what you mean he will most probably accept it, even if the way you have drawn it is maybe not 100% 'conventional'... (I don't even know if there is any convention for things like this... But it's pretty obvious how you've drawn it, so I think you're going to be ok.)
Physicsissuef
- 908
- 0
Ok. Thank you.
What is the transformation function for reflecting points on a complex plane?
- Robin04
- · Replies 24 ·
- Precalculus Mathematics Homework Help
- Replies
- 24
What are the solutions to the complex polynomial equation ##z^3+3i\bar z=0##?
- Dank2
- · Replies 64 ·
- Replies
- 64
What curve does z = (α + βt)/(γ + δt) represent in the complex plane?
- erisedk
- · Replies 1 ·
- Replies
- 1
How to find the intersection of complex roots, Im(z) and Re(z)?
- Cottontails
- · Replies 4 ·
- Replies
- 4
What do |z-a|=r and |z-a|=|z-b| represent in the complex plane?
- Physicsissuef
- · Replies 19 ·
- Replies
- 19
Conic Sections on the Complex Plane (circle)
- miniradman
- · Replies 3 ·
- Replies
- 3
What is the Locus of Re[z^2]>1?
- Grand
- · Replies 1 ·
- Replies
- 1
Set of points on the complex plane
- cbarker1
- · Replies 1 ·
- Topology and Analysis
- Replies
- 1
Plotting the roots of unity on the complex plane
- Cottontails
- · Replies 1 ·
- Replies
- 1
Image of the upper half complex plane, under the function g(z) = exp(2 \pi i z).
- kalish1
- · Replies 1 ·
- Replies
- 1
