Complex Summation: Understanding Discrete Time Function
  • Thread starter Thread starter WolfOfTheSteps
    Complex Summation
WolfOfTheSteps
This is not really a homework problem, but I'm studying a text, and I came across this:
http://img198.imageshack.us/img198/4586/sumh.jpg
I know how to get that fraction with the exponents in it (using a summation formula). But for the life of me, I can't figure out how to manipulate that fraction to give the final result.
For example, if I put k=0 into that fraction, I get 0/0, not 5. I tried a bunch of manipulation of the fraction to get sines and cosines, and make the denominator real, but I still can't get a closed form solution that gives the final result.
What am I missing?
Thanks!
UPDATE: Forgot to mention, this is a discrete time function. k is always an integer.
I totally forgot about that factoring trick:
<br /> 1-e^{-j x} = e^{-j x/2}(e^{j x/2}-e^{-j x/2}) = e^{-j x/2}jsin(x/2)<br />
That's all I needed!
UPDATE:
Wait, I was wrong. :frown: :frown:
Even with that factoring trick, I get:
<br /> e^{-j(\pi k-\pi k/5)}*sin(\pi k)/sin(\pi k/5)<br />
But this is still 0/0 for k=0. How do I get the real result?? I'm so frustrated with this! :confused:
No matter what k is, the top is 0. If k is not 0,+/-5,+/-10,..., then the bottom is not 0, so that is how they get 0 for otherwise. For k=0,+/-5,+/-10,..., you need to find the limit as k approaches those values, because 0/0 has no meaning. Use l'Hospital's rule to evaluate your function at those points.
Thanks, that makes sense.
Also, instead of going to L'Hospital's rule, I could just go back to the summation for k=0,+-5, etc and show that it is a summation of ones... while the fraction would prove the "0 otherwise" for the other k values. This would work too.
Thanks a lot!
No problem. Yea, you're right about the summation giving you the five.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
