Gas Compressibility Factor Interpretation
  • Thread starter Thread starter Kakashi
1 reply · 2K views
Kakashi
Z=Vreal gas/V ideal gas
An Ideal gase assumes the only interaction between molecules is that they elastically bounce off each other it ignores attractive/repulsive force intermolecular forces (except during collisions). Does this mean that the ratio of intermolecular distance to molecular size is large making interactions negligible?
For n mol of gas in a container at a certain T and P isnt Vreal the volume of the container? And V-ideal would be tte volume predicted from the ideal gas law.
If Vreal/Videal>1, does this imply that repulsive forces dominate? My understanding is molecules are closer, electron clouds overlap causes repulsion and so to maintain the same P (collisions with the vessel's walls) the system must expand to a larger volume?
Chemistry news on Phys.org
the ideal gas assumption also includes zero molecular volume. The ratio you mention doesn't exist.
To go from ideal gas ##\ \displaystyle {\left ( {pV = nRT}\right)}\ ## to real gas ##\ \displaystyle {\left ( {pV = ZnRT}\right)}\ ## two phenomena are brought in: molecular size and intermolecular force. Clearly illustrated in the van der Waals equation $$ \left ( p+{a\over{V_m^2}}\right )\left(V_m - b\right) = RT $$(actually not an equation but an approximation).
So I would stick to ##\ \displaystyle Z = {p_{\rm real}V_{\rm real}\over{p_{\rm ideal}V_{\rm ideal}}}\ ## and take it from there.
Note that intermolecular forces are often attractive (polar molecules). See Atkins: physical chemistry
