Compton Scattering: Calculating Wavelength from Energy
The discussion focuses on calculating the wavelength of an incident photon in Compton scattering when the maximum energy imparted to an electron is 45 keV. The correct formula to use is derived from the Compton wavelength shift equation, which requires the angle of scattering to determine the wavelength change accurately. The maximum energy transfer occurs when the photon is scattered at an angle of 180 degrees, resulting in the greatest change in wavelength. The participants clarify the importance of mass considerations and the direction of photon and electron movement during the scattering process.
  • Understanding of Compton scattering principles
  • Familiarity with the Compton wavelength shift equation
  • Knowledge of energy-momentum conservation in collisions
  • Basic concepts of photon and electron interactions
  • Study the Compton wavelength shift equation in detail
  • Learn about energy conservation in particle collisions
  • Explore the implications of scattering angles on energy transfer
  • Investigate the relationship between photon energy and wavelength
Physics students, researchers in particle physics, and anyone interested in understanding photon-electron interactions and the principles of Compton scattering.
Jacob87411
If the maxmimum energy imparted to an electron in Compton scattering is 45 keV what is the wavelength of the incident photon?
So a compton scattering happens and the energy is 45 keV and I need to find the wavelength of the photon incident to this electron. I think I need to use
Lambda = h/mc (1-Cos), but I am not given an angle.
Maximum energy corresponds to (minimum/maximum, you decide) wavelength change? Which angle gives the (minimum/maximum) wavelength change?
Your equation is missing something. It is not quite correct in two places. For one, the angle for the cos is missing. What else?
Imagine you're playing billiards. You shoot the cue ball (photon) against the eight-ball (electron), with a certain amount of energy. What direction does the cue ball go after the collision, when it transfers the maximum amount of energy to the eight-ball?
The cue ball will go in reverse fro mthe way it came?
Yes, although in the case of a cue ball that has no backspin there is no rebound because the masses of the balls are the same. But if you had a cue ball of lesser mass, it would bounce back. And if you had a cue ball of greater mass, it would keep going forward in a stratight line when the maximum energy is transferred.
So there is the collision and there is no rebound, but the 8 ball (electron) does go forward and now has the energy from the cue ball (photon)
correct! they have the same masses, so the cue ball transfers all of its energy to the eightball making it move forward and the cue ball come to a halt.
Bleah, I forgot about the mass considerations... with equal masses and if topspin doesn't come into play, the cue ball simply comes to a dead stop in a head-on collision with a stationary eight-ball.
I should have specified something like a ping-pong ball hitting the eight-ball. After all, the photon is massless.
There will be a rebound in the Compton effect problem, and the angle that will give the electron greatest energy is when the rebound photon is straight back.
