Compute Euler Phi Function of Large Integer | Matlab Solution
  • Context: MATLAB
  • Thread starter Thread starter paton51
    Euler Function Phi
5 replies · 12K views
paton51
How do i comput the euler phi function of a large interger?
i know that if p is prime then phi(p)=p-1 and I've found a formula for computing non primes but i don't know how to implement in something like Matlab.
Does anyone know how?
What, Matlab doesn't have that already?
phi is a multiplicative function: phi(ab) = phi(a) * phi(b) if gcd(a, b) = 1. So to find phi(n), first factor n and then find phi(p^k) for each prime p dividing n exactly k times. Have you seen the formula for that? Can you prove it?
As for implementing the formula, just loop through the factor vector.
By the way, I assume this is for homework. If not, I strongly recommend Pari/GP rather than Matlab for number theory! The command in Pari/GP is eulerphi:
Code:
(11:09)eulerphi(10^50+35)
time = 375 ms.
%10 = 52844036689487355925892416914616365612135546307584
Ok thanks i'll have a go at it. I don't have PARI/GP but i mite try and download it, i generally use MATLAB cus it relativly easy. Its not a homework question, a lecture mentioned it and I am just trying to understand it!
Thanks for your comments!
No problem. I think that Pari is easier to use for these sorts of problems than Matlab, that's why I suggested it.
If you wanted to implement phi on your own in Pari (obviously it won't be quite as fast, but it'll help you understand):
Code:
myPhi(n)={
  local(f,t);
  f = factor(n);
  t = 1;
  for(i=1, #f[,1],
    t *= f[i, 1] - 1;
    t *= f[i, 1]^(f[i, 2] - 1);
  t
The code loops through each prime component p^k and multiplies the running total t by p - 1 then by p^(k-1). For large n, most of the time is spent factoring (or proving primality) and so the code isn't actually that much worse in those cases.
I'll reply because this thread is a top Google hit:
Code:
function phi = eulerphi(n)
	phi = n;
	for i = 1:length(n)
		p = unique( factor(n(i)) );
		phi(i) = phi(i) * prod(1 - 1./p);
	end
end
The for-loop makes the function work with vectors, which is useful for MATLAB commands like "stem(1:100,eulerphi(1:100))".
