Computing integrals of Re(z) along two complex paths
3 replies · 2K views
Maybe_Memorie
Sketch the C1 paths a: [0; 1] -> C, t -> t + it2 and b: [0; 1 + i]. Then compute the following integrals.
∫Re(z)dz over a
∫Re(z)dz over b
Sketching a seems ok, y-axis is Imaginary, x-axis is Real, and the path is a quadratic between 0 and 1.
However I'm not sure about b...
As for the integrals, is it just a case of integrating Re(a(t))a'(t)dt between 0 and 1, then integrating Re(a(t))a'(t)dt between 0 and 1+i?
Hi MM!
I believe you've got (a) down.
For (b) I have to admit I haven't seen the notation [0; 1 + i] before.
Do you have a definition for it?
I'd assume it's supposed to represent the line segment between 0 and (1+i).
Or in other words: (1+i)[0, 1].
It looks a bit weird though, since a curve is usually defined on an interval of real numbers.
However, if this is the case, you need to reconsider what Re(z) is.
I like Serena said:
Hi MM!
I don't have a definition for it. I'll upload the actual problem to show it to you.
I get it, in particular if I look at the problems that are coming, that show which theory you're currently learning.
Path b is not related to path a.
It is just a (linear) path from 0 to (1+i).
It would be given by b:[0,1]→C defined by t→t(1+i)
Note that path a also starts in 0 and ends in (1+i).
And also note that for path a the interval is [0,1] and not [0;1].
[0,1] is a real interval, whereas [0;1] would indicate a (linear) path between 0 and 1 in the complex plane.
