Concept subsea PHES system, /advice with calculations
The discussion revolves around a conceptual design for a subsea pumped hydro storage (PHES) system. Participants explore calculations related to energy storage capacity, flow rates, and pressure dynamics within the system, while considering the feasibility and design challenges of the concept.
  • One participant presents calculations for energy storage capacity and flow rates, using specific parameters such as head, pipe length, and turbine power.
  • Another participant questions the existence of pressure differences in the system if the pipeline is filled with water, seeking clarification on operational conditions.
  • A later reply explains that the system would initially be empty, allowing water to fill the vessel for power generation, which would leave the pipeline filled with air.
  • Concerns are raised about the design of the underwater reservoir, with discussions on whether it should be a bag or a rigid shell, and the implications for hydrostatic pressure.
  • Some participants suggest that the presence of seawater intakes might negate the need for designing against hydrostatic pressure, while others argue that pressure differences are crucial for energy storage.
  • One participant proposes the idea of using compressed air in conjunction with the water system to create a pressure differential for energy recovery.
  • Another participant suggests creating diagrams to visualize the system's pressure dynamics and to clarify the presence of air or water in different operational states.
  • Consideration is given to the possibility of using a riser as an air inlet to facilitate water flow without restriction.
Participants express differing views on the design and operational mechanics of the subsea PHES system, particularly regarding pressure dynamics and the feasibility of using a bag versus a rigid vessel. The discussion remains unresolved with multiple competing perspectives on these issues.
Participants highlight limitations in understanding the pressure dynamics and the implications of using different vessel designs. There are unresolved questions about the operational conditions of the pipeline and the effects of hydrostatic pressure on energy storage.
kirkmcg97
TL;DR
I've designed a subsea pumped storage hydro system and want to know if I'm on the right track with my flow rate and head loss calculations
I've created a concept design of a subsea pumped hydro storage system, and need to use the flow rate in order to calculate power output. I can calculate the energy storage capacity using ##E = mgh##:
$$E = mgh = 25675000×9.81×200 = 50374 MJ = \frac {50374MJ}{3600} = 13992 kWh$$
I've attempted to determine the flow rate by choosing a turbine (5MW Francis from https://www.researchgate.net/publication/302969536_The_use_of_LINGO_programming_language_to_develop_a_computer_tool_to_provide_a_technical_and_economic_analysis_of_a_hydraulic_potential_that_allows_the_application_of_Francis_turbines_and_Kaplan_turbin/figures?lo=1) and working backwards, to then find the resulting pipe diameter and head loss. In the model below, the top of the pipe has a valve that will open to let seawater in during the power generation stage (high energy demand), down through a 90/10 Cu/Ni pipe, through a turbine and subsequently fill up the vessel, which is located 200 m below the inlet (Head = 200 m). Vessel design doesn't take into account the pressure at this depth through use of a bag seen here. In times of low demand, using excess energy produced from the wind turbine, the water will be pumped back up to the surface to be stored as potential energy.
  • Head = 200 m
  • Pipe Length = 1594m (assuming a straight path between elevations)
  • Vessel Volume = 25,000 m3
  • Seawater Density = 1027 kg/m3
  • Turbine Power = 5MW
  • Generator Efficiency (##\eta_g##) = 0.9
So in generator mode, the rated discharge will be:
$$P_g=\rho \times g \times h \times \eta_g \times Q_g$$
Rearranging for Q while assuming generator efficiency is 0.9 gives:
$$Q_g = \frac{P_g}{\rho \times g \times h \times \eta_g} = 2.7599m^3/s$$
(Can generate rated capacity for 5.03 hours)
Rearranging the formula for pump mode to find Qp;
$$Q_p = \frac{P_g \times \eta_p}{\rho \times g \times h \times} = 2.2355m^3/s$$
(Can be operated for 6 hours)
Assuming pump velocity (vp) to be 5m/s, required diameter (d) is found using:
$$A=\frac{Q}{v}$$ then $$ A=\pi \times \frac{d^2}{4}$$ therefore d = 0.754m.
Reynolds Number:
$$Re = \frac{u \times d_h}{v} = 362500$$
So flow is turbulent.
Reading from Moody chart and using Colebrook equation to check, friction coefficient (f) = 0.0147.
Therefore via Darcy Weisbach, Pressure Loss = 399 kPa and Head Loss = 39m.
Have I done this correctly or is there something glaringly obvious that I've missed? Any thoughts or suggestions are welcome! And please note this doesn't (and probably won't) be economically feasible, it's purely a concept to see if something like this could work.
Welcome to PF.
If the pipeline is also filled with water, then I do not understand where in the system there can be a pressure difference or head. When would the pipeline be filled with air ?
Baluncore said:
Welcome to PF.
So the system would be originally empty (including the vessel), enough water would be allowed to pass through to fill up the vessel to generate power leaving the pipe empty/filled with air, then would be pumped back out, leaving the pipe empty once again. Similar to how pumped hydro works with penstocks etc, the vessel will act as the lower reservoir with the sea as the upper. So while empty the pipe would need an operating pressure of 20bar which I'm aware of and have been calculating the required wall thickness.
So your underwater 25,000 m3 reservoir is not an exposed bag but a rigid shell that operates with up to 20 bar of external hydrostatic pressure.
Do the seawater intakes not mean that there isn't a need to design against the hydrostatic pressure? As when the bag is empty due to pumping, the chamber will fill up with seawater. Then during generation the bag will fill up, replacing the water in the chamber? There's a diagram in that brochure explaining it and with seawater tests too, maybe I've just got the wrong idea and should consider a large concrete chamber instead
A bag is employed to isolate oil from water, the pressure inside the bag is the same as outside the bag. If there is no pressure difference between the bag and the external seawater in contact then there is no energy storage benefit from the bag. The storage volume then becomes that of the tube that may be filled with air or water.
Consider the pipline and an air pump/turbine. You could pump air into the bag reservoir, raising the world wide sea level very slightly during the process. Then you could release the compressed air to recover the energy. The system would operate at approximately 20 bar pressure difference. The pump/turbine could be at the surface.
But I can't see how you could do it by pumping water through the pipeline since the hydrostatic pressure will then be the same in the pipeline and the ocean, so there is no pressure difference.
Maybe you need to draw four diagrams of your system. Discharged, half charged, fully charged, and then half discharged. Mark on it the presence of air or water. Start at sea level and mark the hydrostatic pressure, inside and outside the system. Look for where there is a pressure difference across the wall, between the inside and the outside. When is there any pressure across the turbine?
This
I created these, I see what you mean about the pressure, since the vessel is always water it'll be in equilibrium; if I was to disregard the bag altogether and create say, a concrete vessel of similar size would it then work? I guess it'd be very similar to the StEnSea project but worth asking.
Also under consideration is to add a riser purely as an air inlet in order to not restrict the water flow
10K
17K
  • · Replies 19 ·
