Conduction between a steel/copper cylinder.
1 reply · 3K views
jj5959
A steel cylinder of radius 7.0 cm and length 4.0 cm is placed in end-to-end thermal contact with a copper cylinder of the same dimensions. If the free ends of the two cylinders are maintained at constant temperatures of 85°C (steel) and 20°C (copper), how much heat will flow through the cylinders in 19 min?
Q = (kAtdeltaT)/L
Q=heat
k for steel=66.9
k for copper=395
A=area
t=time
T=temperature
L=length
x=temperature in the middle of the cylinders
I set heat transferred through the steel part of the cylinder equal to the heat transferred through the copper part of the cylinder.
(66.9)(85-x) = (395)(x-20)
x=29.4
then using that value, i solved for Q.
Q=((66.9)(.0154)(85-29.4)(1140))/.04
so Q=1.6E6 J
BUT the answer is Q=1.17E6 J
where'd i go wrong?
Q=1.17E6 J should be right. Perhaps the answer key is wrong?
