Conformal inv of scalar wave equation
The discussion revolves around the conformal invariance of the scalar wave equation under the transformation \( g_{\mu\nu} \to \omega^2 g_{\mu\nu} \). Participants explore the implications of this transformation on the wave operator and the Ricci scalar, examining the algebraic manipulations involved in proving invariance. The conversation includes technical details and algebraic identities relevant to the topic.
  • One participant attempts to prove the conformal invariance of the modified wave equation, expressing concern over an extra unwanted term that appears in their calculations.
  • Another participant suggests using a specific identity for the wave operator, indicating that it may simplify the calculations and help eliminate the unwanted term.
  • Some participants discuss the correct application of covariant derivatives versus partial derivatives, with one asserting that treating covariant derivatives like partial derivatives leads to mistakes.
  • There is a suggestion that the algebraic structure of the terms should maintain homogeneity under the transformation, and that any loss of a factor of \( \omega \) indicates an error in the calculations.
  • One participant expresses skepticism about the necessity of using the identity for the wave operator, arguing that careful use of covariant derivatives should suffice.
  • Multiple participants point out potential mistakes in the algebraic manipulations, emphasizing the importance of correctly computing derivatives and maintaining consistency in the treatment of terms involving \( \omega \).
Participants do not reach a consensus on the best approach to proving conformal invariance. There are competing views on whether to use covariant derivatives or the suggested identity for the wave operator, and disagreements on the presence and implications of mistakes in the calculations.
Participants note that the calculations depend heavily on the correct application of identities and the treatment of derivatives, with some suggesting that the algebra may be complex and prone to errors. The discussion highlights the need for careful attention to detail in the derivations.
LAHLH
I'm trying to prove the conformal invariance (under g_{\mu\nu}\to\omega^2 g_{\mu\nu}) of
<br /> \bar{\Box}{\bar{\phi}}+\frac{1}{4}\frac{n-2}{n-1}\bar{R}\bar{\phi}<br />
I've found that this equation is invariant upto a quantity proportional to
<br /> g^{\mu\nu}\left[-\omega(\nabla_{\mu}\nabla_{\nu}\omega)\phi+(\omega^2-\omega)(\nabla_{\mu}\omega)(\nabla_{\nu} \phi)-\frac{n-4}{4}(\nabla_{\mu}\omega)(\nabla_{\nu} \phi)\right]<br />
Here \bar{\phi}=\omega^{(2-n)/2}\phi, and the conformal transformations of other quantitities like box and the Ricci scalar are those found in Carroll Appendix.
How can I get rid of this extra unwanted quantity? (or have I simply made an algebraic error of some kind)
Thanks
Did you use this identity for the wave operator? ◻φ = (-g)-1/2μ[(-g)1/2 gμννφ]
I didn't, I just used
<br /> \bar{\Box}\bar{\phi}=\omega^{-2}\Box\bar{\phi}+(n-2)g^{\alpha\beta}\omega^{-3}(\nabla_{\alpha}\omega)(\nabla_{\beta}\bar{\phi})
and
<br /> \bar{R}=\omega^{-2}R-2(n-1)g^{\alpha\beta}\omega^{-3}(\nabla_{\alpha}\nabla_{\beta}\omega)-(n-1)(n-4)g^{\alpha\beta}\omega^{-4}(\nabla_{\alpha}\omega)(\nabla_{\beta}\omega)
as well as \bar{\phi}=\omega^{(2-n)/2}\phi.
I plugged these into
The full result I obtain is
\omega^{-(n+2)/2}\left(\Box\phi+\frac{1}{4}\frac{n-2}{n-1}R\phi\right)+\omega^{-(n+6)/2}(n-2)g^{\mu\nu}\left[-\omega(\nabla_{\mu}\nabla_{\nu}\omega)\phi+(\omega ^2-\omega)(\nabla_{\mu}\omega)(\nabla_{\nu} \phi)-\frac{n-4}{4}(\nabla_{\mu}\omega)(\nabla_{\nu} \phi)\right]
The first terms are obviously what I want, but the second square bracket is unwanted.
At which point are you thinking I should use the identity you posted?
thanks for the help.
You might try checking your algebra for the \Box \bar{\phi} part again, because it looks to me like it should work out although I don't see your error. Did you properly compute the derivatives of \bar{\phi} and not just \phi?
Alternatively, you could try the differential form \omega = 1 + \delta to simply things.
Also, do you know that there are mathematica packages that do this kind of algebra for you? I only mention this because I never felt that I learned much from such exercises.
\bar{\Box}\bar{\phi}=\omega^{-2}\Box\bar{\phi}+(n-2)g^{\alpha\beta}\omega^{-3}(\nabla_{\alpha}\omega)(\nabla_{\beta}\bar{\phi} )
What I did was, for example in the first term of this on RHS :\omega^{-2}\Box\bar{\phi}, I wrote
\omega^{-2}\Box\bar{\phi}=\omega^{-2}g^{\mu\nu}\nabla_{\mu}\nabla_{\nu}\left(\omega^{(2-n)/2}\phi\right) =\omega^{-2}g^{\mu\nu}\nabla_{\mu}\left[\frac{2-n}{2}\omega^{-n/2}(\nabla_{\nu}\omega)\phi+\omega^{(2-n)/2}\nabla_{\nu}\phi\right]
Ultimately I ended up with
\omega^{-(n+2)/2}\Box\phi+\omega^{-(n+4)/2}(n-2)g^{\mu\nu}\left[\frac{n}{4}\omega^{-1}(\nabla_{\mu}\omega)(\nabla_{\nu}\omega)\phi-\frac{1}{2}(\nabla_{\mu}\nabla_{\nu}\omega)\phi -(\nabla_{\mu}\omega)(\nabla_{\nu}\phi)\right]
The first piece being what I want, the second square bracketted bit again going to the unwanted piece when combined with the rest of box and the Ricci term.
This is one mistake. You're trying to treat covariant derivatives like partial derivatives. ∇μφ is a vector, and when you take the divergence of a vector you need to include a Christoffel symbol. The identity I mentioned above uses instead factors of √g to avoid the Christofel symbol. Try using the identity and see what you get.
EDIT: I think I see at least two more mistakes, but let's do one at a time!
where did I make this mistake? I was tring to be very conscious of not doing that. omega and phi are scalars so the \nabla_{\nu} cov deriv acts as a partial deriv and this is how I generate the second equality in my second line of equations in my post prev to yours. Or are you thinking of somewhere else? My expansion of the rightmost side of my second line of equations would continue by using the product rule (valid I think for the CovDeriv) to take \nabla_{\mu} of the product of scalars and 1-forms in the square brackets...
Do you agree that the identity is right?
Do you agree that if you do use it, you will get a different answer?
Second mistake.. Notice that in each equation you started with, every term has the same number of ω's. This is ignoring derivatives, so for example ω-2, ω-3∇ω and ω-4∇ω∇ω all have the same number.
There's undoubtedly a deep reason for this, like conformal transformations have the group property or something. More formally, the terms are homogeneous under ω → Cω where C is a constant.
Whatever the reason, this property must preserve itself throughout your calculation. Try it and see. In particular where you have ended up with (ω2 - ω) clearly it has been violated. So if you trace back where these two terms came from, one of them must have lost an ω.
The identity you posted for box phi you mean? If so yes I agree that that's correct. I started off doing the calculation using this identity too but haven't finished the algebra yet. I can't see however why doing it the way I initially set out too would not be an equivalent way however, unless I had made an error along the way of course.
OK, I will check into this.
Do you still believe I am treating cov derivs incorrectly?
I think that is Mistake #3! :smile: I think that this problem can't be worked correctly using covariant derivatives - you need to use the identity to write everything in terms of partial derivatives and insure that all the appearances of gμν are explicitly written out. Why? Because what you want is the new wave operator in the conformally transformed space. Using the covariant derivatives will give you the old wave operator instead.
I'm not sure I agree with that. I do accept that you could do the problem the way you posted with that identity, and will try to verify that when I get chance next, but I don't buy that you can't do it using the covariant derivs as long as you are careful. I'm starting in the conformal frame and working backwards and the first term I get is
this is not \bar{\Box} it's genuinely the box of the non-conformal frame, not the box of the conformal frame that I started with. Secondly if one needs to convert my method to your method, it's possible to just write out the Christoffel symbols in terms of the metric and I believe the two should then agree. It might even be possible at some stage to use \Gamma^{\mu}_{\mu\lambda}=(-g)^{-1/2}\partial_{\lambda}(-g)^{1/2}.
Anyway, I will go through both methods in some details when I get chance next and see explicitly if they are equivent or not, and also recheck my algebra bearing in my the number of omegas per term feature you highlighted, thanks.
No offense, Bill, but I strongly disagree with this statement. I can certainly imagine that some people find the partial derivatives simpler to work with, but the problem can definitely be worked out with covariant derivatives. There is not really anything subtle about these objects in the sense that they obey all the usual rules of derivatives in calculus in addition to producing valid tensors.
The simplest way to proceed is to replace all \Box f with g^{ab} \nabla_a \nabla_b f for all scalars f and then work on with covariant derivatives i.e. don't reintroduce box operators until the very end.
I just checked it explicitly and it works out, but only for the equation \Box \phi - \frac{1}{4}\frac{n-2}{n-1} R \phi. Is it possible you have the wrong sign in your equation?
Are you using mostly plus or mostly minus? If it's mostly plus then box acts like E^2 - p^2 and the minus sign would be appropriate (so that positive R acts like a normal mass). This is important for quantizing the theory on a sphere.
I'm working from the book Birrell and Davies and they have the plus sign \Box \phi +\frac{1}{4}\frac{n-2}{n-1} R \phi, they also use (+----) convention however.
Actually I now realize that I've been using the transformations for the Ricci etc from Carroll who uses the opposite sign convention (d'oh!) and this is probably what has messed me up! Also the omega^2 I had above should have been an omega
(as bill noted) and this kills that (omega^2-omega) term..
So I should have really been using
\bar{R}=\omega^{-2}R+2(n-1)g^{\alpha\beta}\omega^{-3}(\nabla_{\alpha}\nabla_{\beta}\omega)+(n-1)(n-4)g^{\alpha\beta}\omega^{-4}(\nabla_{\alpha}\omega)(\nabla_{\beta}\omega)
for the (+----..) conv. Is my conformal transformation for the box still valid? In the other convention Carroll has
Would this change?EDIT: It all seems to work out now! phew. thanks for all the help..
  • · Replies 17 ·
