Confusion about pressure drops and pressure regulators
The discussion revolves around the role of pressure drops in fuel lines and the function of pressure regulators in an EFI (Electronic Fuel Injection) system. Participants explore how line diameter and restrictions affect pressure and flow, particularly in relation to the operation of pressure regulators.
  • One participant questions whether pressure drops in fuel lines need to be considered when a pressure regulator is present, noting that smaller diameter lines can increase pressure drops.
  • Another participant suggests that smaller diameter lines could be beneficial for increasing pressure, implying that a reducer might be necessary.
  • It is noted that many simple regulators can only reduce pressure and require a higher supply pressure than the target output pressure.
  • A participant explains the operation of the fuel system, emphasizing that the fuel must be delivered to the regulator at a pressure above the desired level for injectors to function correctly.
  • Concerns are raised about the potential for the pressure regulator to not fully shut off, which could affect fuel return to the tank.
Participants express differing views on the impact of line diameter and pressure drops, with no consensus reached on the optimal design considerations for fuel plumbing in relation to pressure regulators.
Some participants reference earlier discussions and diagrams to clarify their points, but the discussion remains focused on the mechanics of pressure regulation and fuel flow without resolving all uncertainties regarding the implications of pressure drops.
This discussion may be useful for individuals interested in automotive engineering, particularly those involved in fuel system design and optimization for EFI systems.
darthapple35
When designing the fuel plumbing for an efi system, do pressure drops in the fuel lines need to be considered when there is a pressure regulator? If so why? Been reading up a lot on plumbing design lately about how the goal is to minimize restrictions in the lines which ultimately cause pressure drop and play a large part in what size fuel line to use. I've read that the smaller diameter the line is, the greater the pressure drop will be. But if there is a pressure regulator, why does considerations about pressure drops and line sizes matter? Thanks
Do you mean that smaller diameter increase the pressure drop? I think to increase the pressure (reducing pressure drop) a reducer is needed, in other words using smaller design is better.
For your question, in my opinion, regulator is used to overcome the pressure drop and to increase the flow of fluid.
Sorry if my grammar is bad.
Many simple regulators can only reduce the pressure not boost it. So they need a supply pressure that is higher than the target output pressure. If the pipes between pump and regulator are too small or there are restrictions in it then the pressure going into the regulator might be too low.
So let me see if i can now explain how the fuel system works now with the pressure regulator mounted at the end/after the fuel rail. Fuel is pumped out of the pump at a certain pressure through the fuel lines and up into the fuel rail all the way to the pressure regulator. The fuel in the rail is above the desired pressure for it to be delivered to the injectors so the pressure regulator will reduce it to the desired pressure for the injectors which will result in excess fuel being returned to the tank through the outlet of the pressure regulator. Thats why the fuel wants to be delivered to the fuel rail and regulator above the desired pressure so the regulator can precisely lower it and give the injectors an accurate amount of fuel. If the fuel pressure in the rail and up to the regulator is below the desired pressure for the injectors, the injectors will not accurately get the correct amount of fuel and no fuel will be returned to the tank. Which is why a powerful enough pump is needed along with keeping pressure drops in the plumbing system to a minimum is necessary to make sure the pressure is high enough to activate the regulator so it can accurately lower it for the injectors. If the pressure is not high enough when delivered to the rail, the engine will run lean. Is this correct?
Actually there might still be some fuel returning to the tank. It depends if the pressure regulator can fully shut off in its attempt to keep the pressure up.
