Connected normal space problem
  • Thread starter Thread starter radou
    Normal Space
6 replies · 3K views
Homework Helper
Show that a connected normal space having more than one point is uncountable.
First of all, if X has more than one point, take the points a and b in X. Let U be an open set containing a. Take a basis element B around a contained in U. Then Cl(B) and X\U are disjoint closed sets containing a and b, respectively.
Since X is normal, by the Urysohn lemma there exists a continuous function f : X --> [0, 1] such that f(Cl(B)) = 0 and f(X\U) = 1.
Now, assume that X is countable, and let f(X) be the image set of f. f(X) is a countable subset of [0, 1], and since X is connected, by the intermediate value theorem, for any r between 0 and 1 there exists some point c of X such that f(c) = r. Let r be some point of [0, 1]\f(X). Then there must exist some c in X which maps to r. Since [0, 1] is uncountable, we arrive at a contradiction with the assumption that X is countable.
I hope this works, thanks in advance.
I agree with the general proof. But I'm a bit skeptic of this part:
Some remarks:
- What do you mean with "Take a basis element B". What basis are you talking about?
- How do you know for certain that X\U contains b? What happens if you took U such that a and b are in U?
You will have to use somewhere that the one-point sets are closed...
Ahhh, a good remark indeed!
I completely forgot that one-point sets closed are a part of the definition of normality! I was skeptic about that very part of my proof too.
Btw, another question, if I have a space, I assume I can't just "take" a basis for it, i.e. simply assume it exists?
If one-point sets are closed in X, it suffices to take two distinct elements a and b from X, and apply the Urysohn lemma to the closed and disjoint sets {a} and {b}.
Btw, the first attempt of my proof was the same, but I just "took" two closed disjoint sets in X, without showing that they exist. That's the point - I can't simply take two such sets. In a general toipological space, they need not exist, right?
Yes, that is correct!
About the basis thing. If you're given a topological space [tex](X,\mathcal{T})[/tex] then you can always find a basis for this space, namely the topology [tex]\mathcal{T}[/tex] itself. But then it isn't really interesting to talk about a basis... You should only work with bases if they have an interesting description of interesting properties. For example, when working with second countable spaces, then there exists a basis with interesting properties, so it makes sense to work with such a basis.
Yes, in a general topology, such a thing will not exist. That's precisly why the T1 axiom is introduced.
Yes, I see.
OK, thanks!
