Solving Connected Particles Homework Problem
  • Thread starter Thread starter Bucky
    Particles
The problem involves two equal mass bodies, A and B, connected by a string, with A projected at a 45-degree angle. The user attempts to calculate the impulsive tension in the string when taut, using momentum equations in both the direction of AB and perpendicular to it. They express concerns about potential errors in their calculations, particularly regarding the algebra and the loss of a mass variable. A suggestion is made to express cos 45 as sqrt(2)/2 to simplify the calculations. The overall goal is to determine the correct impulsive tension, which the user believes should be 1/4 m U sqrt(2).
Bucky
Two bodies A and B of equal mass m, connected by a light inextensible string, are placed on a smooth horizontal table with the string just taut. A is projected with velocity U at 45 degrees to the direction AB. Determine the impuslive tension in the string when it becomes taut.
Well, following from previous examples i tried to find the momentum in direction AB and perpendicular to AB.
Momentum in direction AB
mu + mu = U cos45
2mu = Ucos45
u = (Ucos45) / 2m
Momentum perpendicular to AB
mv = U sin45
v = (Usin45)/m
Impulsive Energy at A
T = mu
= (Ucos45)/2
= (U * 1/root2)/2
I think I've gotten it wrong. answer should be 1/4 m U root 2. can anyone help me out? I don't know if it's an algebra problem or (most likley) a method problem.
try expressing the cos 45 as sqrt(2)/2, subbing that= u*sqrt(2)/4
annoyingly I've lost an 'm' somewhere, but otherwise the answer checks out :)
i didn't know cos 45 could be expressed as root(2)/2 ? or have you done some mathmatical jiggery-pokery that i have missed?
no real trickery, just dividing or multiplying both top and bottom by sqrt(2).
  • · Replies 17 ·
  • · Replies 31 ·
