Connecting three black boxes to three red boxes without crossing lines
15 replies · 3K views · last reply
Basimalasi
Hello computer science people,
riddle me this... you have three black boxes and three red boxes. You want to connect each black box with the three red boxes without making the lines interact with each other. can you do it ? or is it unsolvable ?
Like this :
Three diagrams of three black boxes on top and three red boxes below, with arrows connecting them; the lines cross in the top diagram, and the bottom two show attempted connections with some lines routed around the outside.
I've seen this many times in the past. To the best of my recollection, it is unsolvable (in two dimensions).
Is this possible ? there is no cut.
  • Diagram of three black oval loops in a row with a blue line passing horizontally through them, connecting two red circles at the left and right ends, and a third red circle above the middle loop joined by three blue lines to the tops of the three loops.
Like this?
  • Diagram of three black rectangles across the top and three red rectangles across the bottom, joined by thin black lines that connect each top box to a bottom box without crossing.
skeptic2 said:
Like this?
I don't think this meets the requirements of a direct link between each red box with each black box, and vice versa. This might not have been stated in the OP but I believe that is what is implied.
Why would you want to use software to solve this puzzle?
Try designing a complex multi-layer printed circuit board without using a computer track routing algorithm. :smile:
because i think its unsolvable
solving this riddle is like guessing a 6-charechters password..you have to have an algorithm that will test all the possible paths the 9 arrows are going to take from the black boxes to the red boxes without interacting
you can't make the lines go "through" the red boxes.
3 arrows from the first black box to all red boxes
3 arrows from the second black box to all red boxes
3 arrows from the third black box to all red boxes
without no interaction between the lines
I know this stupid of me and a waste of your time guys but I can't be satisfied without an algorithm that would test all the possibilities
Code:
while there_exist_more_possibilities(); do test_next_possibility();
I don't have much time to waste, so I am not going much deeper. That's your algorithm, just fill in details.
I understand. You trust computers more than people.
Here's a more detailed algorithm. In fact, it's actual C code:
Code:
//  For an explanation of why this algorithm works, see:
//    http://mathforum.org/dr.math/faq/faq.3utilities.html
#include <stdio.h>
void main(void) {
printf(“Results from analysis of Red/Black box riddle: No solutions exist!\n");
Try it out and let me know if it finds anything.
