How Fast Must a Bullet Travel to Tip a Cube on Its Edge?
The discussion focuses on calculating the minimum speed required for a bullet to tip a wooden cube constrained to rotate about an axis. The cube has a side length of 2a and mass M, while the bullet has mass m and impacts at a height of 4a/3. Key equations include conservation of momentum (mv = (m + M)V) and conservation of angular momentum (L_initial = L_final). The rotational inertia of the cube is established as I = (8/3)Ma^2, and the necessary energy calculations involve both kinetic and potential energy transformations.
  • Understanding of perfectly inelastic collisions
  • Familiarity with angular momentum conservation principles
  • Knowledge of rotational inertia calculations
  • Basic concepts of kinetic and potential energy transformations
  • Study the principles of conservation of angular momentum in inelastic collisions
  • Learn how to calculate rotational inertia for various shapes
  • Explore energy conservation in mechanical systems
  • Investigate the dynamics of tipping objects and the forces involved
Physics students, mechanical engineers, and anyone interested in dynamics and collision mechanics will benefit from this discussion.
gaborfk
:cry:
Can someone please help me with the following problem:
A solid cube of wood of side 2a and mass M is resting on a horizontal surface. The cube is constrained to rotate about an axis AB. A bullet of mass m and speed v is shot at the face opposite ABCD at a height of 4a/3. The bullet becoes embedded in the cube. Find the minimum value of v required to tip the cube so that it falls on face ABCD. Assume m<<M.
This is what I got so far:
I understand that it is a perfectly inelastic collision and that
mv=(m+M)V
L(initial)=I*Omega where I is the combined Inertia for both object. The I for a cube rotating around one of its edge is I=(8Ma^2)/3 and the bullet is a point mass with an r of sgrt((4a/3)^2+(2a)^2).
omega=V/R where V is the final speed and R is the radius of rotation, which is ...?
Thank you in advance!
mv=(m+M)V
This won't help. Since the cube is constrained, translational momentum is not conserved. But angular momentum is conserved. (Hint: How much energy is needed to topple the "cube + bullet"?)
"mv=(m+M)V"
Careful about this one!
You cannot use this with respect to the C.M. of the bullet+cube system, since that system is affected by an external force comparable in magnitude of the internal forces.
That external force acts from the axis to which the cube is constrained, ensuring that the cube's contact velocity (with the axis) remains zero throughout the collision.
Do you agree so far?
Note:
it's only fair that Doc Al beats me occasionally..:wink:
So then
K(initial)=K(final)
Bullet K(initial)=1/2mv^2
Bullet + Block= K(final)=1/2I*omega^2
1/2mv^2=1/2I*omega^2
where I is the combination of both bullet and block, I(block)=(8M(2a)^2)/3 and I(bullet)=mr^2 where r is sgrt[(4a/3)^2+(2a)^2]. Also, omega is=V/R where V is the final speed of a point on the block.
Can you please double check...
But how about R and how do I figure out how much Energy is needed in order to topple?
Why do you think kinetic energy is conserved in the collision?
Doc Al wrote that the system's angular momentum is conserved (with respect to a point lying on the fixed axis)
During the collision, angular momentum is conserved; after the collision, mechanical energy is conserved.
How about this:
Angular momentum right before the collision for the bullet is
mvr where r is the distance from the rotation point.
After the collision for the bullet
mr^2*omega
The block's angular momentum after the collision is
L=I*omega
In both cases omega is the angular velocity of the block, which breaks down to omega=V/R
So is it mvr=mr^2*omega+I*omega?
mvr=mr^2*(V/R)+I(V/R)
I=(8M(2a)^2)/3
Is R SQRT[8a^2]? How about V?
Careful: \vec{L} = \vec{r}\times m\vec{v}
mr^2*omega
L=I*omega
OK. What's the rotational inertia of the cube about its edge?
Since m << M, you can probably ignore the moment of inertia of the bullet.
You should be able to find \omega in terms of the bullet speed v. What minimum value of \omega is required to get the cube to tip? (That's where energy conservation will come in.)
so L=rx\omega so it is the cross product...
that means that I need to take the perpendicular component to r which is the \sin[\theta] of the bullet's angle of impact to r?
Rotational Inertia of the block around its edge is:
I=\frac{8M(2a)^2}{3}?
Sure. Or you can find the perpendicular distance between the velocity vector and the the axis---that's given to you.
Doesn't look right to me. I'd say the rotational inertia would be I = 2/3 Ms^2, where s is the edge length, in your case s = 2a, but you'd better check it.
I thought that L=\frac{2}{3}Ms^2is if the center of rotation is in the center of the cube. I will use the parallel axis formula to move it's rotational axis to see what I get...
With the axis in the center of the cube, the rotational inertia would be I = 1/6 Ms^2
Still in need of understanding
I am still having trouble finding \omega in terms of the bullet's speed v. I do not understand how conservation of energy comes into play after the collision.
BTW. You were right about the rotational inertia of the cube around it's edge.
I=\frac{2}{3}Ms^2 since s=2a I=\frac{2}{3}M(2a)^2<br /> I=\frac{2}{3}M4a^2=\frac{8}{3}Ma^2
Thank you, and Happy Thanksgiving!
This is just conservation of angular momentum: initial angular momentum (due to the bullet, in terms of v) equals angular momentum of rotating cube (in terms of \omega) immediately after the collision.
Immediately after the collision, the cube+bullet has some kinetic energy. As the cube tips up, KE is transformed to gravitational PE. So, how much energy is needed to make it tip over? (If it doesn't have enough KE, it will just fall back down again. It's just like if you wanted to roll a ball over the top of a hill: how much energy do you have to give it at the bottom to make it all the way to the top and over?)
I know. :wink:
Initial Angular due to the bullet
L_{i} =mvr\sin{\theta}
Where r\sin{\theta}=d
Which is given as d=\frac{4a}{3}
so L_{i} =mv\frac{4a}{3}
Final Angular velocity of cube+bullet (bullet can be ignored, as you pointed out)
L_{f} =I\omega
Where I=\frac{8}{3}Ma^2
So L_{i} =L_{f}
Yields mv\frac{4a}{3}=\frac{8}{3}Ma^2\omega
Solve it for \omega and plug it into below...
KE+PE=0?
KE=\frac{1}{2}I\omega^{2}
It has to rise higher than when the cube is it's corner which is
2a=\sqrt{h^{2}+h^{2}} so h=\sqrt{2}a
That is how far I got... Is PE=Mgh? Or is it KE=PE so, KE-PE=0...
gaborfk said:
That is how far I got... I still do not know PE for the cube...
You're almost there. Consider that \Delta {KE} + \Delta{PE} = 0. The change in PE of the cube is Mg\Delta{h}, where \Delta{h} is the change in height of the cube's center of mass.
My last question for the week...
The cube has to rotate over it's edge. In order to do that I put the cube on it's corner figured out the height of a side corner to the groud..
So is h going to be 2a=\sqrt{h^{2}+h^{2}}
yields that h=\sqrt{2}a
Now I plug all that into the KE+PE=0 equation, solve for v and then make v larger than what I get on the other side. This way if v is larger it should have enough energy to rotate over a height h, which is the max height of a side corner if the cube is stands on one of it's corners.
I assume you mean: h =\sqrt{a^{2}+a^{2}}
That's the final height of the center of mass. What is the change in height?
Right! Be sure to use the change in height, not just the height.
The change in height is
h_{f}-h_{i}=\sqrt{2}a-a=(\sqrt{2}-1)a
Damn, that is going to be messy...
I am getting
v=\sqrt{-\frac{3(\sqrt{2}-1)Mga}{m}}
Which I think is wrong, since I got a negative under the SQRT.
Are we sure that it is \Delta KE+\Delta PE=0
and not \Delta KE=\Delta PE initial KE transfers to final PE
which is \Delta KE-\Delta PE=0 ?
gaborfk said:
I am getting
Yep, that's not right. (It's pretty close though; check over your work.)
That's just a statement of energy conservation. You are probably mixing up your signs somewhere. As the cube tips up, KE decreases and PE increases.
I can not see it...
So here it is.
I=\frac{8}{3}Ma^2
\omega=\frac{mv\frac{4a}{3}}{\frac{8}{3}Ma^2}=\frac{1}{2}\frac{mv}{Ma}
\Delta KE=\frac{1}{2}I\omega^2
\Delta PE=Mg(\sqrt{2}-1)a
\frac{1}{2}(\frac{8}{3}Ma^2)(\frac{1}{2}\frac{mv}{Ma}})^2+(Mg(\sqrt{2}-1)a)=0
(\frac{4}{3}Ma^2)(\frac{m^2v^2}{4M^2a^2})+(Mg(\sqrt{2}-1)a)=0
\frac{m^{2}v^{2}}{3M}+(Mg(\sqrt{2}-1)a)=0
\frac{m^{2}v^{2}}{3M}=-(Mg(\sqrt{2}-1)a)
v^{2}=-\frac{Mg(\sqrt{2}-1)a}{\frac{m^{2}}{3M}}
v=\sqrt{-\frac{3(\sqrt{2}-1)M^{2}ga}{m^{2}}
Is g negative, because it is acting againts to motion? That would fix the negative sign...
gaborfk said:
I can not see it...
So here it is.
I=\frac{8}{3}Ma^2
Right.
No, \Delta {KE} = - 1/2 I\omega^2. KE decreases so \Delta {KE} is negative.
Exactly right... except for that minus sign! :smile:
Thank you very much! You guys, Doc Al and Arildno, always got the answers!
Bye
  • · Replies 17 ·
16K
