Conservation of Angular Momentum
The problem involves a solid cylinder merry-go-round with a mass of 250 kg and a radius of 1.9 m, initially spinning at a rate of 1 revolution every 5 seconds. A 40 kg child is sitting at a distance of 1.1 m from the axis, and a second child, weighing 50 kg, runs tangentially at 3 m/s and jumps onto the merry-go-round at its outer edge. The objective is to determine the new rotation rate in revolutions per second, utilizing the principle of conservation of angular momentum.
  • Mixed
  • Participants discuss the setup of the conservation of angular momentum equation, questioning the inclusion of different radii for the children and the initial angular velocity conversion.
There is ongoing dialogue about the correct setup of the equations, with some participants providing calculations and others requesting detailed steps. A participant acknowledges a potential oversight in the initial angular velocity conversion, indicating a productive exchange of ideas.
Participants are working under the constraints of homework rules, which may limit the sharing of complete solutions. There is a focus on ensuring all variables and conditions are accurately represented in the equations.
icf927
A solid cylinder merry-go-round of mass 250kg and radius of 1.9m spinning at 1 revolution every 5 seconds has a 40kg child sitting at 1.1m from the axis. A 50kg child, running tangentially at 3m/s, jumps on the merry go round at the outer edge. What is the new rotation rate in rev/s?
I1ω1=I2ω2
(1/2MR^2 +m1r^2)ω1 + (m2r^2)(v/r)=(1/2MR^2 +m1r^2 +m2r^2)ω2
I plugged in all the variables and solved for ω2 and got 0.214 rev/s. Did I set up the equation correctly and come about the right answer?
The radii are different for the children.
ehild
yes I plugged in the different radii. I just forgot to put a 1 and 2 behind them in the equations.
Could you please show your calculations in detail?
ehild
(1/2(250kg)(1.9m)^2)(1.256637061rad/s)+((50kg)(1.9m)^2(3m/s/1.9m)=(1/2(250kg)(1.9m)^2+(40kg)(1.1m)^2+(50kg)(1.9m)^2)w2.
solved for angular velocity(w2) and got 0.214rev/s. is this the right set up?
You left out the first child on the left hand side.
ehild
I did it on paper just forgot to type it on here. When I include the first child on the left hand side, is that the right setup?
It is, but I got different result. Show calculations in detail.
ehild
Did you change the initial angular velocity from revolution/sec to rad/sec and then change the final answer back to revolutions/sec
Ops! You are right. I calculated w. So your result is correct.
ehild
  • · Replies 17 ·
  • · Replies 17 ·
