Conservation Of Mechanical Energy
The discussion centers on a physics problem involving the conservation of mechanical energy with two blocks connected by a rope over a frictionless pulley. The key equation used is m1gh1 + 0.5m1v1^2 = m2gh2 + 0.5m2v2^2, where m1 is the mass of the heavier block and m2 is the lighter block. The participants clarify that kinetic energy (KE) is always positive, and the initial mechanical energy cannot be zero due to the potential energy (PE) gained by the blocks. The correct approach involves calculating the kinetic energy gained and the potential energy difference to find the mass of the heavier block.
  • Understanding of basic physics concepts such as potential energy (PE) and kinetic energy (KE).
  • Familiarity with the conservation of mechanical energy principle.
  • Ability to manipulate algebraic equations involving variables and constants.
  • Knowledge of gravitational acceleration (9.80 m/s²) and its application in physics problems.
  • Study the derivation of the conservation of mechanical energy equation in physics.
  • Learn how to apply the equations of motion to problems involving pulleys and inclined planes.
  • Explore the concept of acceleration in relation to mass and force using Newton's second law.
  • Practice solving similar problems involving multiple masses and energy conservation.
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of energy conservation in dynamic systems.
tizzful
Two blocks with different mass are attached to either end of a light rope that passes over a light, frictionless pulley that is suspended from the ceiling. The masses are released from rest, and the more massive one starts to descend. After this block has descended a distance 1.30 , its speed is 1.00 .
If the total mass of the two blocks is 18.0 , what is the mass of the more massive block?
Take free fall acceleration to be 9.80 .
I set the heavier block as m1.
m1gh1+0.5m1v1^2=m2gh2+0.5m2v2^2
They both start at height 0 and velocity 0 and so the initial PE and KE is going to be 0, and so the initial Mechanical energy is also 0 (I'm pretty sure this is wrong but don't know how to fix it). Then m1 drops 1.30m so that's h1 and m2 goes up -1.30m=h2. v should be equal between both, m1=1, m2=-1.
m1(gh1+0.5v^2)=m2(gh2+0.5v^2)
m1/m2=(gh2+0.5v^2)/(gh1+0.5v^2)
=(9.8*-1.30+1/2*-1^2)/(9.8*1.30+1/2*1^2)
Therefore
m1=-m2
So its wrong ahah I was wondering if someone could help me?
Thanks in advance!:shy:
Hi tizzful! :smile:
erm … it's not "-1^2" … :redface:
No wonder they came out minus each other! :rolleyes:
tiny-tim said:
Hi tizzful! :smile:
actually the -1 gets squared and so it becomes one.. Its negative because the height is negative because down is positive and up is negative.. But from what you're saying why isn't it -1? It's also in the opposite direction...
tizzful said:
… why isn't it -1? It's also in the opposite direction...
Noooooo … the kinetic energy mv^2/2 is always positive!
It depends only on speed, not direction!
You have too much imagination! :smile:
ahahah thank you! But I know KE is always positive because if velocity is negative it gets squared making it positive.. And that's what happened in this case.. But i still can't figure out the answer.. I think there's something wrong with me saying initial ME = 0...
ah … I see now … your basic equation is wrong …
KE gained is (m1 + m2)v^2/2
PE gained is (m1 - m2)gh. :smile:
When you have gotten the answer using that method (which is probably the easiest), you can also try doing it by finding the acceleration on the big mass, and then use s=(at^2)/2. You will end up with the exactly same equation. :)
  • · Replies 16 ·
