Conservation of Momentum for explosion
The discussion focuses on a physics problem involving the conservation of momentum and kinetic energy during an explosion between two identical blocks. Initially, one block moves at 5 m/s while the other is at rest. The explosion doubles the total kinetic energy from 12.5M J to 25M J, leading to the equation 25 J = (1/2)Mv1^2 + (1/2)Mv2^2 for the final velocities of the blocks. The conservation of momentum is expressed as 5M = Mv1 + Mv2, establishing the relationship between the velocities post-explosion.
  • Understanding of momentum conservation principles
  • Knowledge of kinetic energy calculations
  • Familiarity with algebraic manipulation of equations
  • Basic concepts of collisions and explosions in physics
  • Study the principles of conservation of momentum in collisions
  • Learn how to derive equations for kinetic energy in explosive scenarios
  • Explore examples of elastic and inelastic collisions
  • Investigate the effects of mass and velocity on kinetic energy and momentum
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of momentum and kinetic energy principles.
possum30540
A block moves at 5 m/s in the positive x direction and hits an identical block, initially at rest. A small amount of gunpowder had been placed on one of the blocks. The explosion does not harm the blocks but it doubles their total kinetic energy. After the explosion, the blocks move along the x-axis and the orginally moving block has a speed of:
momentum = mass * velocity
kinetic energy = (1/2) m *(v)^2
conservation on momentum: the total initial momentum = the total final momentum
since the mass of the two cars is the same, the mass = M
v1 = velocity of cart 1
v2 = velocity of cart 2
before the collision, the total kinetic energy is 12.5M J
before the collision, the total momentum is 5M kg*m/s
after the collision, the total kinetic energy is 25M J
initial momentum = final momentum
5M = Mv1 + Mv2
This is where I am stuck. I don't know what the next step is and if someone would help me along it would be very much appreciated.
You say that the total kinetic energy after the collision is 25M J. Write the equation fror that!
The problem says the initial kinetic energy is doubled. So 2 * 12.5 = 25 J
Yes, you said that before. Now USE it! Write the equation for total kinetic energy after the collision-explosion and set it equal to 25.
  • · Replies 53 ·
  • · Replies 47 ·
  • · Replies 16 ·
  • · Replies 67 ·
  • · Replies 21 ·
