How can conservation of momentum explain the behavior of Newton's cradle?
The behavior of Newton's cradle is explained through the principles of conservation of momentum and mechanical energy. When one or more balls are lifted and released, the number of balls that move on the opposite side corresponds directly to the number of balls released, confirming momentum conservation. However, the analysis reveals that additional factors, such as shock wave propagation, play a crucial role in the observed outcomes. Textbooks often oversimplify this by assuming all balls move together without considering rebounding effects.
  • Understanding of conservation of momentum
  • Knowledge of mechanical energy conservation
  • Familiarity with Newtonian physics principles
  • Basic grasp of wave propagation concepts
  • Study the principles of conservation of momentum in multi-body systems
  • Explore mechanical energy conservation in elastic collisions
  • Investigate shock wave propagation in solids
  • Review advanced dynamics of pendulum systems
Physics students, educators, and anyone interested in understanding the dynamics of Newton's cradle and the underlying physical principles involved in momentum and energy conservation.
rebellion
so, i have a problem. see the pic
http://img255.imageshack.us/img255/4628/aughhm9.png
the question is. if we have, for example 10 balls standin like that, if we move the ball which is on the right, only one will move, the left one. if we move two of them from the right, two of them will move on the left also.
Ft = mv to satisfy the conservation of momentum
the solution is that something else is satisfied, i know that the momentum is satisfied but something is missing. please help :-)
thanks in forward
Mechanical energy is also conserved.
I don't get your question. What exactly are you asking?
From Wikipedia
http://en.wikipedia.org/wiki/Newton's_cradle
The behaviour of the pendulum follows from the conservation of momentum and energy only in the case of two pendula. Indeed, if there are r pendula there are also r unknown velocities to be calculated from the initial conditions. An additional condition for the observed outcome is that a shock wave has to propagate dispersionfree through the chain.
It is certainly true that it takes more than simple conservation of momentum and energy to derive the observed behavior of Newton's cradle. Most textbooks pull a fast one and just assume that however many balls move after the collision, they all move together. (And no rebounding.)
Using this you can show that the number of balls swung on the left will equal the number of balls that will emerge on the right.
  • · Replies 17 ·
16K
