Is Particle 2 in the Eigenstate of ##S_z = \hbar/2##?
  • Thread starter Thread starter andre220
    Particles
The discussion revolves around determining the probability that particle 2 is in the eigenstate of S_z = ℏ/2 after measuring particle 1 in the eigenstate of S_x = -ℏ/2, given that both particles are initially in a spin singlet state. The solution involves recognizing that if particle 1 is measured in S_x = -ℏ/2, particle 2 must be in S_x = ℏ/2, leading to a probability calculation for S_z. The probability of measuring S_z = ℏ/2 for particle 2 is found to be 1/2, despite the entangled nature of the singlet state. This outcome highlights the complexity of quantum measurements and the implications of entanglement, as the system's state changes post-measurement. The conclusion emphasizes that both the singlet state and the measurement results can coexist, reflecting the non-classical behavior of quantum systems.
andre220
Consider two spin 1/2 particles. Initially these two particles are in a spin singlet state. If a measurement shows that particle 1 is in the eigenstate of ##S_x = -\hbar/2##, what is the probability that particle 2 in this same measurement is in the eigenstate of ##S_z = \hbar/2##?
##\chi^{(x)}_{\pm} = \begin{pmatrix} \frac{1}{\sqrt{2}}\\ \frac{\pm1}{\sqrt{2}}\end{pmatrix}## and
##\chi^{(z)}_{+} = \begin{pmatrix}1\\0\end{pmatrix}##
##\chi^{(z)}_{-} = \begin{pmatrix}0\\1\end{pmatrix}##
Okay so I am not entirely sure how to proceed, my instinct tells me to setup a linear combination of two measurements such that the linear combo is equal to one, i.e.:
\begin{pmatrix}1\\1\end{pmatrix} = a
\begin{pmatrix} \frac{1}{\sqrt{2}}\\ \frac{-1}{\sqrt{2}}\end{pmatrix} + b \begin{pmatrix}1\\0\end{pmatrix}
$$ But that gives a or b =1. So that is not correct. What am i doing wrong?
What is the state vector for the singlet state? Which state is the second spin going to be in if you measure the first to be in state Sx = - hbar/2?
The singlet state is:
$$|00\rangle = \frac{1}{\sqrt{2}}(\uparrow\downarrow-\downarrow\uparrow)$$
As I understand it, the total spin that the two particles can carry is 0. So that would mean that if the first measurement is ##-\hbar/2## then the other must yield ##+\hbar/2## for the total spin to be zero.
So what is the probability of a particle in the Sx = hbar/2 state to be in the Sz = hbar/2 state?
So after some thought here is how I went about solving it: If particle one has ##S_x = -\hbar/2## then particle two must have ##S_x = \hbar/2## therefore the probability of measuring ##\hbar/2## for ##S_z## for particle two is: $$\left|\langle\chi^{(x)}_{+}|\chi^{(z)}_{+}\rangle\right|^2 = \begin{pmatrix} \frac{1}{\sqrt{2}}&\frac{1}{\sqrt{2}}\end{pmatrix}\begin{pmatrix}1\\0\end{pmatrix} = \frac{1}{2}$$ I wanted to make sure that I could justify the answer mathematically.
Just for fun, consider what the result of the probability being 1/2 means. If you had no knowledge whatever of the state of the second particle, if it was completely random up or down, you would get half. But you have been told that it is part of a singlet state, and the other particle in that state is down. And the probability is still 1/2 of it being up. Does that seem correct?
Consider exactly what it means to state that the system is in the singlet state, and to state that one of the particles is definitely in the down state. Can both of these statements be true at the same time? What does it mean to perform a measurement on the system? After the measurement, what will the system look like? (Hint: It won't be in the singlet state any more.) Think projection operators.
andre220 said:
therefore the probability of measuring ℏ/2\hbar/2 for SzS_z for particle two is
But what is it given that you know it already for particle one?
Yes, this can (and is) definitely true as the problem states that the spin of the particles are considered in different directions. As the original state is a singlet and the first particle is found in the spin down state in the x-direction, the second particle must now be in the spin up state in the x-direction. This spin state has probability 1/2 to be in the spin up state of the z-direction, as found by the OP.
