High School What are some commonly used mathematical constants and their purposes?
Mathematical constants like π and e play crucial roles in various mathematical calculations and theories. π is essential for determining the circumference and area of circles, while e serves as the base for natural logarithms and appears in numerous mathematical contexts. The discussion highlights that constants simplify complex formulas, making them easier to use and understand. It emphasizes that while any number can be termed a constant, only those with significant applications in mathematics are commonly recognized. Ultimately, understanding these constants aids in grasping broader mathematical concepts and their applications.
pairofstrings
Hi. π is a constant. The purpose of π is to use it to find circumference of a circle or area of a circle. Correct? Can you please elaborate?
Can you point out any other two constants and its purpose?
Thanks.
Mathematics news on Phys.org
Well - not exactly. π occurs almost everywhere in mathematics, the ratio between the circle diameter and its circumference is just one example.
Other constants are (for example)
Then there are the sequences of constants like
There is a website dedicated to such sequences: https://oeis.org/.
jedishrfu said:
Is this for a school report?
Looking for a new constant.
What are the uses of constants?
Web does not show satisfying answers.
I'm not sure whether this makes any sense. In the end a mathematical constant is simply a number. The only reason why it can be called a mathematical constant, which I personally would not, is the fact that it occurs on various seemingly independent occasions and formulas. So first are the principles and then comes the constant, not the other way around. Or you just can pick any number.
Usually to write down formulas in a short and precise way. Otherwise the circumference of a circle with radius ##1## couldn't be handled nicely. Carpenters might be satisfied with ##3.14##, mathematicians can not. Or how would one write the normal distribution, which is basically all around in this universe?
Here's a nice, but by no means complete list:
https://en.wikipedia.org/wiki/Mathematical_constant
If you want to find usages, then pick one and start searching. E.g. for ##\pi\; , \;e## or the golden ratio you will find more webpages than you can read.
1 is also a constant.
In this context, I would say that a mathematical constant is a named number. We give the number a name for the same reason that we give anything a name -- to make it easy to refer to. It is a lot easier to write down ##\pi## than to write down "the ratio of the circumference of a circle to its diameter"
Likes Delta2
Except we have also named numbers like ten, a hundred, a thousand... or a googol for the convenience of talking and writing about them in a common sense way.
Here you go: 464.36466905383373880693157320423356352311325674
I am sure no one ever used this number before.
Is there any application for this number? Probably not.
You don't start with "I want a new constant". You start with a mathematical question. e. g. "what is the ratio between circumference and diameter of a circle", and you discover that it is the same for every circle, and determine properties of this constant ratio.
Likes FactChecker
I like the story of 1729. Ramanujan was sick in the hospital and GH Hardy went to see him. Hardy remarked
I remember once going to see him when he was ill at Putney. I had ridden in taxi cab number 1729 and remarked that the number seemed to me rather a dull one, and that I hoped it was not an unfavourable omen. "No," he replied, "it is a very interesting number; it is the smallest number expressible as the sum of two cubes in two different ways."
https://en.wikipedia.org/wiki/1729_(number)
https://en.wikipedia.org/wiki/Taxicab_number
More recently, mathematicians found that Ramanujan had been investigating other numbers like these and realized that he was looking into the Fermat's little theorem:
https://www.zmescience.com/science/math/taxi-number-ramanujan-03213/
I have another question: π is a constant - has value 3.14 (roughly), if I measure the area of circle in mm2 and area of square in mm2 and obtain two values - area of circle in mm2 and area of square in mm2 then how would I know that this number is talking about area of circle and this number is talking about area of square because the area of both shapes is in mm2? Assume that area of square is 201.06 mm2 and area of circle is 201.06 mm2.
Is it possible to distinguish area of circle from area of square and so that only by looking at the units or perhaps result I can say that the person is talking about area of square or area of circle? Is it possible to talk about the shape just by looking at units or perhaps result?
πr2: we know what the value of constant π is. If I multiply π with 25: 3.14 x 25 mm2 then the result is 78.5 mm2. What influence does π or 3.14 have on answer? Will this π say that we are talking about circle? But the end result is a number with units mm2 - we could not distinguish area of square with area of circle if the units are same!
No. An area is an area. The shape of an area tells you what kind of formula you need to use to calculate the area. Of course, you are free to use the raw force method - divide the area into very small squares and count them.
π is part of the formula to calculate the area of the circle, just as ½b⋅h is the formula for calculating the area of a triangle. Those formulas are there to make things easier for you, you do not have to use them.
Look at the pentacle above. There is a formula for calculating the area, I am not going to tell you what it is. How are you going to find the area and how do you know that the area is the correct one?
You seem to keep underestimating the importance of how something can be used. Out of all the mathematics and arithmetic that has been done throughout history, only a tiny, tiny fraction is worth becoming part of standard mathematics. Any single number is a "constant" but only a few have a name.
The concept of area, independent of shape is very useful. It helps to abstract many calculations and concepts without regard to shape. Abstraction of area/volume is extremely important in mathematics and physics.
My most favorite constant: ##O(1)##.
Thread closed, because the question has been answered.
  • · Replies 23 ·
  • · Replies 38 ·
