Construct grammar and find its type
  • Context: MHB
  • Thread starter Thread starter evinda
    Type
The discussion revolves around constructing a grammar for the language $L=\{ a^i b^j \mid i,j \geq 1, i>j\}$. Participants explore various grammar rules and their implications, focusing on the type of grammar that can generate this language.
  • Some participants propose initial grammar rules such as $S \to aSb$ and $S \to aDb$ to represent the language.
  • There is confusion regarding the inclusion of certain strings like $aaabb$ and whether they can be generated by the proposed rules.
  • Participants discuss the minimum powers of $a$ and $b$, suggesting that the initial rule should reflect that $i > j$.
  • Some participants suggest that the grammar must include rules that allow for more $a$s than $b$s, leading to various iterations of the grammar.
  • There is a discussion about the classification of the grammar types, with references to type-0, type-1, type-2, and type-3 grammars, and their definitions.
  • Questions arise about the implications of certain grammar rules and whether they fit within the definitions of the different grammar types.
Participants express uncertainty and disagreement about the correctness of the proposed grammar rules and their ability to generate the desired language. There is no consensus on the final form of the grammar or its classification type.
Participants note that certain strings generated by the grammar may not belong to the language, indicating limitations in the proposed rules. There is also ambiguity regarding the definitions of grammar types and the conditions under which they apply.
This discussion may be useful for those interested in formal language theory, grammar construction, and the classification of grammars in computational linguistics.
evinda
MHB
Hello! (Wave)
I want to construct a grammar for the language $L=\{ a^i b^j \mid i,j \geq 1, i>j\}$. What type of grammar is it?
I have thought to start with the command $S \to aSb$.
Since we can have several times $a,b$ I have thought to continue with the command $S \to aDb$.
Since there have to be more $a$s than $b$s, do we continue with the commands $D \to aD$ and $D \to a$ ?
So is the grammar the following? :unsure:
S-> aSb
A->aDb
D->aD
D->a
Hey evinda!
What is $A$? 🤔
Klaas van Aarsen said:
Hey evinda!
What is $A$? 🤔
Oh sorry! I meant :
S-> aDb
D->aD
D->a
:unsure: :unsure: :unsure:
evinda said:
S-> aDb
D->aD
D->a
Ah okay.
The word $aaabb$ is part of the language isn't it?
But we can't construct it with those rules can we? (Worried)
Ah okay.
Oh yes, right! We cannot construct it with those rules... (Tmi)
We have to reuse S...
I have thought of the following grammar so far:
S->aSb
S->D
D->a
D->aDBut as I see this is not true, since we cannot get as many b's as we want. Or am I wrong? :unsure:
Indeed. It is not true.
Additionally we can get $a$ now, which is not in the language either is it? (Worried)
So the minimum possible power of $a$ is $2$ and of $b$, $1$.So the initial rule should be this one: S->a^2Sb. Right? :unsure:
Then S can either get the value ab or a or it finishes.
Is this right? :unsure::unsure::unsure:
Is this right?
Sounds about right yes. 🤔
So is the grammar the following one?
S->a^2Sb
S->ab
S->a
S->λ
:unsure: :unsure:
But a, ab, and $\lambda$ are not in the language are they? (Worried)
Oh yes, right! (Nod)
So is the grammar the following? (Thinking)
S->a^2Db
D->ab
D->a
D->λ
That looks correct to me. (Nod)
Great! (Blush) And how do we find what type of grammar it is? :unsure:
I have found the following about the possible types of a grammar:
From the above, I understand that if a grammar is of type-2, then it is also of type-1, right? (Thinking)
Also, all the types 1,2,3 are also type 0, right? :unsure:
As for the type-3 grammars, I haven't understood something... It says that on the left-hand side we have a single nonterimal and at the right-hand side a single terminal, possibly followed by a single nonterminal. Then why is A->abcB allowed, as it stated at the example? :unsure::unsure: Shouldn't we only have rules of the form A->aB? Could you explain it to me? :oops:
Maybe, but it does not seem to follow directly from the definition.
That is because I think $\gamma$ can be empty in the type-2 grammar, but must specifically be non-empty in the type-1 grammar.
That depends on how a 'string' is defined though - whether it is allowed to be empty or not. :unsure:
I believe so, yes.
We should be able to recursive apply each possible rule and backtrack, making each of the types 1, 2, and 3 recursively enumerable, and therefore a type 0-grammar. 🤔
evinda said:
As for the type-3 grammars, I haven't understood something... It says that on the left-hand side we have a single nonterimal and at the right-hand side a single terminal, possibly followed by a single nonterminal. Then why is A->abcB allowed, as it stated at the example? Shouldn't we only have rules of the form A->aB? Could you explain it to me?
It seems to me that they either consider "abc" a single terminal.
Or they imply that $A\to abcB$ can be rewritten as $A\to aA_1,\,A_1\to bA_2,\,A_2\to cB$, after which the condition is satisfied. 🤔
However we interpret it, a language that allows $A\to abcB$ will be equivalent to a type-3 grammar,
evinda said:
S->a^2Db
D->ab
D->a
D->λ
Isn't the language generated by this grammar finite?
I believe so, yes.
Ok... 🤓
But when a language allows $A\to abcB$ then isn't the language also of type 2? 🧐
Oh yes, right! (Wait)
The language is represented by the following rules, right?
S->a^2Db
D->aDb
D->a
D->λ
How so?
How can we rewrite a rule like for instance $A\to Ba$ to that form? 🤔
How so?
I thought so since $\gamma$ is any string of terminals and non-terminals. Am I wrong? 🤔
In a type-2 grammar $\gamma$ is indeed any string of terminals and non-terminals, allowing for instance $A\to Ba$.
But in a type-3 grammar all rules must have terminal(s) left and non-terminal(s) right, don't they? 🤔
S->a^2Db
D->aDb
D->a
D->λ
This grammar does not derive aaaab.
So the following grammar is of type 2, right? :unsure:
S->a^2Db
D->aDb
D->a
D->λ
Oh yes, right... (Nod)
We have to include D also at the rule with a, i.e. it should be as follows:S->a^2Db
D->aDb
D->aD
D->λRight? :unsure:
evinda said:
S->a^2Db
D->aDb
D->aD
D->λ
Yes, I think this is right.
Great! Thank you! (Blush)
S->a^2Db
D->aDb
D->a
D->λ
Yep. (Nod)
  • · Replies 24 ·
  • · Replies 18 ·
