How to choose delta for epsilon-delta continuity proofs
  • Thread starter Thread starter Karol
    Delta Epsilon
12 replies · 3K views
Karol
Continuity:
$$\vert x-c \vert < \delta~\Rightarrow~\vert f(x)-f(c) \vert < \epsilon$$
$$\delta=\delta(c,\epsilon)$$
$$\vert f(x)-f(c) \vert <\frac{1}{2}f(c)~\Rightarrow~\vert x-c \vert < \delta_1$$
So i have this δ1 but what do i do with it?
And ε=½f(c) is big, maybe it will be in the negative zone.
Maybe i have to find a δ such that ##~\vert f(x)-f(c) \vert =0~##?
There is such a δ, so why was advised to take such a large ε?
You are still starting these proofs the wrong way round. Somehow you have to train yourself to stop writing things like:
You must, must, must stop yourself from doing this.
For this problem I would first try to "prove" it using a graph of the function and a geometric argument.
Karol said:
Continuity:
The above is continuity.
And this is what you write. You must see the difference. Every time you turn it round the wrong way.
I was wrong at the definition of continuity:
$$\vert f(x)-f(c) \vert < \epsilon~\Rightarrow~\vert x-c \vert < \delta$$
The ε is to the intersection with x
No, what you have above is backwards. The implication you showed in post 1 has the implication in the right order.
In words, "If x is close to c, then f(x) will be close to f(c)"
The delta and epsilon quantify the "close to" terms.
Karol said:
In your drawing, where is x? Where is c? Is the circled point on the curve (c, f(c))?
:headbang:
I had a friend, a fraternity brother actually, who always said that his ambition in life was to be an epsilon and delta picker.
If f(c)>0 i can take ε small and it will still be ##~\vert f(x)-f(c) \vert >0~## and find a δ because of continuity, so why do i need the ##~\epsilon=\frac{1}{2}f(c)~##?
Thank you Mark, Dr.D and PeroK
Because of continuity i can find a δ for ##~\epsilon=\frac{1}{2}f(c)~##, so in this interval: ##~c-\delta<x<c+\delta~##, f(x)>0
