Continuous Example: Weierstrass Function
  • Context: MHB
  • Thread starter Thread starter Juliayaho
    Continuous Example
The Weierstrass function, defined as f(x) = Σ (n=0 to ∞) of (1/2^n) cos(3^n x), is a classic example of a continuous function that is nowhere differentiable. However, its classification as absolutely continuous is debated. An alternative proposed is a piecewise continuous function connecting specific points, which may better fit the criteria of being absolutely continuous while exhibiting infinitely many non-differentiable points. This discussion highlights the nuances in defining continuity and differentiability in mathematical functions.
  • Understanding of the Weierstrass function and its properties
  • Knowledge of absolute continuity in mathematical analysis
  • Familiarity with piecewise functions and their construction
  • Basic concepts of differentiability and continuity
  • Research the properties of the Weierstrass function in detail
  • Study the concept of absolute continuity and its implications
  • Explore the construction and analysis of piecewise continuous functions
  • Investigate other examples of continuous functions that are nowhere differentiable
Mathematicians, students of analysis, and anyone interested in the properties of continuous and differentiable functions.
Juliayaho
An example of an absolutely continuous f: [0,1] -> ℝ with infinitely many points at which f is not differentiable?
Now what I had in mind was weierstrass function which says that f(x) = Sum (n=0 to infinity) of 1/2^n cos(3^n x) and is continuous everywhere but the derivative exists nowhere...
But I am not sure if that example really fits the criteria of the question or if there might be another more suitable example of that...
Thank for the help.
Why don't you just use a sine-like function, where you alternate between straight lines of slope $+1$ and straight lines of slope $-1$? You're not required to have the function differentiable nowhere, it seems. You could make this function non-differentiable at every integer. Something like this.
[EDIT]: Oops, I didn't see that the domain has to be $[0,1]$. You could probably take my function and squash it down in a limit, similar to the Weierstrass function.
Thank for the help.
I'm not sure that the Weierstrass function qualifies as absolutely continuous.
Here's an example that should:
let $$f(x)$$ be the piecewise continuous function connecting the points $$\left( \frac{1}{2k+1},0 \right)$$ and $$\left( \frac{1}{2k},\frac{1}{2k(k+1)} \right)$$ for all integers $$k≥1$$.
  • · Replies 38 ·
