Contour: Constructing a Contour Map from h(x,y) = x^2 + y
  • Thread starter Thread starter hexa
    Map
The discussion focuses on constructing a contour map from the height field defined by h(x,y) = x^2 + y within the domain [-3 ≤ x ≤ 3; 0 ≤ y ≤ 9]. Participants clarify that the northern, middle, and southern cross sections correspond to y-values of 9, 4.5, and 0, respectively. The height (z) is calculated as z = x^2 + y, ensuring all values remain non-negative due to the specified domain. The conversation emphasizes the importance of understanding the domain constraints when creating cross sections.
  • Understanding of contour mapping techniques
  • Familiarity with mathematical functions and height fields
  • Knowledge of cross-sectional analysis in two-dimensional graphs
  • Basic skills in graphing software or tools for visual representation
  • Research how to create contour maps using Python libraries such as Matplotlib
  • Learn about cross-sectional analysis in mathematical modeling
  • Explore the implications of domain constraints in function visualization
  • Study the principles of height fields and their applications in graphical representations
Mathematicians, data scientists, educators, and anyone involved in graphical data representation or mathematical modeling will benefit from this discussion.
hexa
Hello,
I have a sum:
make a contour map from a height field h(x,y) = x^2 + y on the domain: [-3<_ x <_3 ; 0<_ y <_9]. Make an east-western cross section (paralell to x-axis) through the field h in the northern, middle and southern part of the domain and draw all three height profiles into a figure.
Well, the first part is not really a problem, but what would be the northern, middle and southern part of such cross section? I can only imagine a negative and positive value for y and zero for the middle?
hexa
y can't be negative based on the domain you supplied. Therefore, the height is always non-negative. Making a cross section I would think means make a cross section at y = 9, another at y = 4.5, and another at y = 0. In other words, set z = x^2 + y, and draw the height (z) at y = 9, 4.5, and 0.
you're right, daveb, didn't think of the domain. But still that's more or less what I thought. Thanks a lot for confirming.
  • · Replies 22 ·
  • · Replies 42 ·
