Can the contour integral of z⁷ be simplified using a parameterized expression?
The discussion focuses on simplifying the contour integral of \( z^7 \) using a parameterized expression \( z(t) = 3t + i(5 - 4t) \) for \( t \) in the range [0, 1]. The derivative \( \frac{dz}{dt} = 3 - 4i \) is calculated, leading to the integral transformation \( \int_{\Gamma} z^7 dz = (3-4i)\int_{0}^{1} (3t + i(4-5t))^7 dt \). Participants explore the potential for simplification through binomial expansion and substitution techniques, particularly in the context of complex numbers.
  • Complex analysis fundamentals
  • Understanding of contour integrals
  • Familiarity with parameterization of complex functions
  • Knowledge of the binomial theorem
  • Study the application of the binomial theorem in complex integrals
  • Learn about parameterization techniques in complex analysis
  • Explore advanced integration techniques involving complex variables
  • Investigate the properties of contour integrals in the complex plane
Mathematicians, physics students, and anyone interested in advanced calculus or complex analysis, particularly those working with contour integrals and parameterization methods.
Mayhem
Integrate ##\int_{\Gamma} z^7 dz## along the line ##5i## to ##3 + i##
##z = x + iy##
First I parameterize ##z## by ##z(t) = 5i + (3 + i - 5i)t## such that ##z(0) = 5i## and ##z(1) = 3 + i##, which means that ##0 \leq t \leq 0## traces the entire line on the complex plane. By distributing ##t##, we achieve a parameterized expression of the form ##z(t) = x(t) + iy(t)##
$$z(t) = 3t + i(5 - 4t)$$
Then to rewrite the contour integral in terms of ##t##, we determine ##dz/dt##
$$\frac{dz}{dt} = 3 - 4i$$
Yielding
$$\int_{\Gamma} z^7 dz = \int_{0}^{1} z^7 \frac{dz}{dt} dt = (3-4i)\int_{0}^{1} (3t + i(4-5t))^7 dt$$
Not sure where to go from here. The naive approach would be to expand the binominal and factor out all constants (including imaginary units ##i##), but that is tedious. Is there a trick? If this was a calc I problem, I'd just do a simple u-substitution, but not sure if the same logic holds when ##i## is involved.
Observe that you can rewrite your integral,
I=(3-4i)\int_0^{1} [(3-4i)t + 5i]^7dt
(3-4i)=5e^{-i\tan^{-1}(\frac{4}{3})}=5z_0
Expand the integral with binomial thm,
I=5^8z_0\int_0^{1} [(z_0t + i]^7dt=5^8z_0\sum_{n=0}^{7}\int_0^{1}\begin{pmatrix}
7\\
n
\end{pmatrix} z_0^{n}t^{n} (i)^{7-n}dt
  • · Replies 26 ·
