Control Subspace of LTI System X = Ax + Bu: Nonzero Parameter Analysis
  • Thread starter Thread starter ayham87
The discussion revolves around the controllability of a linear time-invariant (LTI) system represented by the equation X = Ax + Bu. Participants are exploring whether the system is completely controllable given specific nonzero parameters in matrices A and B, and they are attempting to find the controllable subspace if it is not.
  • Homework-related
  • One participant presents a MATLAB approach using symbolic variables for parameters a1, a2, a3, a4, b1, and b2 to determine controllability.
  • Another participant suggests that A and B should be declared as double floats rather than symbolic variables, claiming this worked for them.
  • A later reply clarifies that "syms" is used for the parameters, while A and B are indeed declared as double floats, but an error occurs when trying to convert a struct to double.
  • Another participant advises against using the ctrb function with symbolic variables and recommends performing the controllability analysis manually in MATLAB, offering to share their code for this process.
Participants express differing views on the use of symbolic versus numeric representations in MATLAB for the matrices A and B. There is no consensus on the best approach to resolve the error encountered during the analysis.
Participants have not reached a conclusion regarding the controllability of the system, and the discussion includes unresolved technical issues related to MATLAB functionality and the handling of symbolic variables.
ayham87
Given the LTI system X =Ax+Bu where
A =[ 0 1 0 0 0 0; a1 0 0 a2 0 0;0 0 0 1 0 0;0 a3 0 0 0 0; 0 0 0 0 0 1;0 0 0 0 a4 0];
B = [0 0 0 ;b1 0 0 ; 0 0 0 ;0 b2 0 ;0 0 0 ;0 0 b2];
and the parameters a1; a2; a3; a4; b1; b2 are all nonzero. Determine whether the system is completely controllable. If not, find the controllable subspace of the state space.
I tried systematically but it seems to long so i try by MATLAB by the following code
syms a1 a2 a3 a4 b1 b2
Co = ctrb(A,B)
Thanks in advanced
The variables A and B need not be symbolic variables. Just declare A and B as double floats and use ctrb function. It worked for me.
Thanks for your response
actually "syms" not for A & B, its for the variables (a1 a2 b1 b2 a3 a4), I declare A & B as double float :
syms a1 b1 a2 a3 a4 b2
A = float('double');
B = float('double');
Co = ctrb(A,B);
but i get the following error:
The following error occurred converting from struct to double:
Error using ==> double
Conversion to double from struct is not possible.
Error in ==> ctrb at 32
co(:,1:nu) = b;
can u help me again...thanks in advanced
the ctrb function doesn't handle symbolics. Just do the steps to find out controllability "by hand" via matlab. Its not that long, I've done it already, just create a few loops and such. I can provide the code I used to do it before I figured out MATLAB had the functionality, if you'd like.
  • · Replies 38 ·
