Convergence of a functional series (analysis)
5 replies · 2K views · last reply
mred11
Determine whether the following functional series is pointwise and/or uniformly convergent:
[itex]\sum_{n=1}^\infty \frac{x}{n} (x\in\mathbb{R})[/itex]
My answer to this seems very straightforward and I would be very grateful if someone could let me know if the method is correct. We can re-write the series as:
[itex]x \sum_{n=1}^\infty \frac{1}{n}[/itex]
We know the harmonic series (of numbers) [itex]\sum_{n=1}^\infty \frac{1}{n}[/itex] is divergent, so therefore the series cannot be pointwise or uniformly convergent.
Is this correct? Thanks!
You could also use the p-series test to arrive at the same conclusion.
Thanks. I just noticed something: if x=0, then the series is just zero, so it converges. Given that the series isn't convergent for *all* values of x in the domain, is it still correct to say the functional series is divergent? I suppose it's a question of terminology. Thanks for the help.
It's pointwise convergent at points where it converges, and pointwise divergent where it doesn't converge.
Based on your question, i would say that the correct answer is: point-wise convergent at x = 0. (which would imply that at any other values of x, the series is divergent)
