MHB Does the sequence $(a^n b^{n^2})$ converge for all values of $a$ and $b$?
The convergence of the sequence \( (a^n b^{n^2}) \) depends on the values of \( a \) and \( b \). If \( |b| < 1 \), the sequence converges to 0, while if \( |b| > 1 \), the sequence diverges to infinity. Special cases arise when \( b = 1 \) or \( b = -1 \), where convergence is tied to \( a^n \) and \( a^n (-1)^{n^2} \) respectively. The sequence \( (-1)^{n^2} \) does not converge, as it oscillates between -1 and 1. Overall, the sequence's convergence is contingent upon the specific values of \( a \) and \( b \).
evinda
MHB
Hello! (Wave)
I want to check as for the convergence the sequence $(a^n b^{n^2})$ for all the possible values that $a,b$ take.
I have thought the following:
We have that $\lim_{n \to +\infty} a^n=+\infty$ if $a>1$, $\lim_{n \to +\infty} a^n=0$ if $-1<a<1$, right?
What happens for $a<-1$ ? :confused:
We have that $a^n b^{n^2}=(ab^n)^n$.
If $a>0$, $b>1$ then $\lim_{n \to +\infty} (ab^n)=+\infty$ and thus $\lim_{n \to +\infty} (ab^n)^n=+\infty$.
If $a<0$, $b>1$, then $\lim_{n \to +\infty} (ab^n)=-\infty$. Then what can we say about $\lim_{n \to +\infty} (ab^n)^n$ ?
If $0<b<1$, then $\lim_{n \to +\infty} (ab^n)=0$ and thus $\lim_{n \to +\infty} (ab^n)^n=\lim_{n \to +\infty} 0=0$.
Am I right so far?
If $b<0$, what can we say about the desired limit? (Thinking)
Hi evinda,
Your analysis is certainly on the right track. By using two facts we can reduce the number of cases that need to be considered:
  1. $\displaystyle\lim_{n}|x_{n}|=0$ if and only if $\displaystyle\lim_{n} x_{n}=0.$
  2. If $\displaystyle\lim_{n}|x_{n}|=\infty$, then $x_{n}$ is an unbounded sequence.
The first statement can be proved using the definition of the limit of a sequence. The second can be established via contradiction and the definition of a bounded sequence.
For $a=0$ or $b=0$ we see that the sequence converges automatically. Thus, in what follows we always consider $a\neq 0$ and $b\neq 0$.
Case 1: $|b|<1.$
By writing $y_{n}=(ab^{n})^{n}$ we see that $$|y_{n}|=e^{n\ln|a|+n^{2}\ln|b|}.$$ Since $|b|<1$, $\ln|b|<0$ and the presence of the term $n^{2}$ above will guarantee the dominance of $n^{2}\ln|b|.$ Hence, $$\lim_{n}|y_{n}|= e^{-\infty}= 0.$$ Using Fact 1 above, we have $\displaystyle\lim_{n}(ab^{n})^{n}=0.$
Case 2: $|b|>1.$
We have $|ab^{n}|=|a||b|^{n}\rightarrow\infty~~\Longrightarrow~~|(ab^{n})^{n}|\rightarrow\infty.$ Using Fact 2, it follows that $(ab^{n})^{n}$ is unbounded and, therefore, must necessarily diverge.
Remaining Cases: $b=\pm 1.$
I will leave this to you.
Hopefully by reducing the number of cases the problem is more tractable. Let me know if anything requires further clarification.
GJA said:
Hi evinda,
Case 1: $|b|<1.$
Case 2: $|b|>1.$
I see... (Yes)
For $b=1$, the convergence of the sequence $(ab^n)^n$ equals to the convergence of $a^n$ and for $b=-1$ the convergence of the sequence $(ab^n)^n$ equals to the convergence of $a^n(-1)^{n^2}$.
It doesn't hold that $a^n(-1)^{n^2}$ converges iff $a^n$ converges, does it? (Thinking)
This is correct.
This is not true - take $a=1$ as a counterexample.
GJA said:
This is correct.
Nice! (Smirk)
Ok, how do we show that $(-1)^{n^2}$ does not converge? (Thinking)
This is the alternating sequence $\{-1, 1, -1, 1,\ldots\}$ because $n^{2}$ is even iff $n$ is even. Moreover, the sequence possesses two convergent subsequences: $\{-1, -1, -1, \ldots\}$ and $\{1, 1, 1, \ldots\}$, which cannot happen for a convergent sequence.
I see... Thanks a lot! (Happy)
  • · Replies 17 ·
