Conversion and Mass Calculations: Acceleration, Momentum, and Water Mass
  • Thread starter Thread starter dabryanman
The discussion focuses on solving physics problems involving units of measurement and calculations related to acceleration, momentum, and mass. For acceleration squared, the correct units are derived as meters squared per seconds to the fourth power. The division of momentum by speed should yield units of kilograms per second, but participants struggle with the calculations. A significant challenge is posed by a hypothetical scenario involving counting $1 bills, with participants attempting to calculate the time required to reach $1.4 billion. Lastly, there is confusion regarding the mass of water in cubic meters, with corrections needed for the calculations presented.
dabryanman
a. if you square the accleration expressed in meters per second per second, in what unites will the answer be expressed?
b. if you divide momentum measured in N*s (1 N = 1 kg*m/s^2) by a speed expressed in meters per second, in what units will the answer be expressed?
c.a billionaire offers $1.4 billion if you will first count the amojnt in $1 bills or a lump sum of 5000 (assume you can count an average of 1 bill per second, and be sure to allow for the fact that you will need about 10 hours per day for sleeping and eating. how long will it take to count the amount in $1 bills?
d. one cubic cm (1.0 cm^3) of water has a mass of 1.0 x 10^-3 kg. determine the mass of 8.0 m^3 of water.
a. no idea
b. m/s^2 / m/s = m(s)/m(s^2) = 1/s ... said seconds but apparently incorrect
c. 1400000000=3600 bills/hour(time) - 10 hrs/day ... t=388889 hours + 10 hrs/day = 16204 days + 10 hrs/day ; 10 hrs/day x 1 day/24 hours =.417 days; 16204 (.417)= 6757 days; 16024 days + 6757 days = 22961 days x 1 yr/365 days = 63 years (wrong as well)
d. 1 m= 100 cm ; 8m (100 cm/m) = 800 cm ; 800 cm (.001 kg/cm)=.8 kg (wrong)
help is greatly appreciated thanks!
When you multiply or divide units, they behave the same as ordinary algebraic expression.
a) If the acceleration was measured in miles/(hour ^2), the square of this unit would be miles^2/(hour^4)
b)
\frac{kg~m}{s^2}/ \frac{m}{s}~=~\frac{kg~m}{s^2} * \frac{s}{m}~=~?
d) 1m = 100 cm, so 1 m^3 = 100^3 cm^3 = 1,000,000 cm^3
8 cubic meters of water would have a mass vastly larger than .8 kg.
thanks but a was still wrong, as was B which i put kg/s...i finished the last one and got 1000 kg which was also wrong
What was your answer, and how did you get it? Just saying "I got it wrong" gives us no clue how to help you out.
The question is asking you to take the square of (m/s^2). Mark44 provided an example using different units.
That answer is indeed wrong. Perhaps start out by giving 1 N in terms of m, kg, s.
Next, multiply by s to give 1 N*s in terms of m, kg, s.
Finally, divide by m/s to get the final answer.
Please show us your work.
sorry i don't really understand what you advised me to do for B...as for A and D, i ran out of try attempts for webassign so those are hopeless now. can anyone help me with the billionaire question I am really struggling on this and need all the points i can get.
Start out by writing 1 N in terms of m, kg, s.
