Convert ArrayList to string with spaces between elements
  • Topic: Java
  • Thread starter Thread starter uperkurk
    Java Loop
4 replies · 3K views
uperkurk
Hey guys, I have an
Code:
ArrayList<String> al = ArrayList<String>();
and I have a textbox, the textbox allows a user to enter a word and that word will be added into the ArrayList.
When I print the list out it looks like this
Code:
[Cat, Dog, Mouse]
can you please write out the for loop that I need in order to change the ArrayList into a string? I want the output to look like this
Code:
Cat Dog Mouse
Please don't say go read this or read that, I've googled for loops but I can't find one that will do what I want.
Thanks.
The collections-based for loop does almost the same thing, just behind the scenes (it uses and iterator in its implementation), and is a little easier to code:
Code:
ArrayList<String> al = new ArrayList<String>();
al.add("cat");
al.add("dog");
al.add("mouse");
for(String str : al) {
    System.out.println(str + " ");
For read-only access to your ArrayList, this is the way to go. You will run into problems if you try to remove objects from your ArrayList in such a loop, however (you will get a ConcurrentModificationException), whereas the while loop in jedishrfu's example will have no such problems.
Code:
al.add("cat");
al.add("dog");
al.add("mouse");
Exactly what I was looking for thank you so much! I had the exact same thing but I was using
for(str : al) instead of for(string str : al)
Cheers bro!
With respect to the collections based for loop just be aware that it is in java 5 and beyond. Sometimes programmers are maintaining java 1.4 code or earlier and collections based for loops aren't supported.
