Convert Longitude/Latitude to cartesian x,y
4 replies · 8K views · last reply
3saul
I have a series of maps from various parts of the world.
Each map is 512 pixels by 512 pixels. I also have approximate left, top, right and bottom latitude and longitude values for each map.
I'm wanting to plot variable lat/long value on the maps which need to be converted to x,y values - any advice on how to proceed?
3saul: You are getting involved in an area of surveying known as geodesy. I think you should Google the term 'Universal Transverse Mercator' to learn the basics. Software to handle lat/long - UTM X/Y conversions can be downloaded from the US Army Corps of Engineers website - Google 'CORPSCON'
I forgot to mention, the map width is equal to 1024km - as is the height (so each pixel equates to approx. 2km).
SteamKing, thank you for your response. I've looked over some of the information, which seems relatively complicated for my purposes.
I don't need a huge amount of accuracy but my current calculations (below) aren't producing accurate enough results. The x/y are both off by about 40 (positive) pixels. This tells me my calculations are too simple.
currentlatitude = -27.445617
currentlongitude = 152.93503
--Make values positive
if currentlatitude < 0 then
currentlatitude = currentlatitude * -1
end
if currentlongitude < 0 then
currentlongitude = currentlongitude * -1
end
--The following are the coordinates for my map
mapLeftLong = 147.98
mapRightLong = 158.46
mapTopLat = -23.15 --was a negative figure
mapBottomLat = -32.31 --was a negative figure
if mapLeftLong < 0 then
mapLeftLong = mapLeftLong * -1
end
if mapRightLong < 0 then
mapRightLong = mapRightLong * -1
end
if mapTopLat < 0 then
mapTopLat = mapTopLat * -1
end
if mapBottomLat < 0 then
mapBottomLat = mapBottomLat * -1
end
xadjusted = mapRightLong - currentlongitude
yadjusted = mapBottomLat - currentlatitude
ypoints = mapRightLong - mapLeftLong
xpoints = mapBottomLat - mapTopLat--Get pixel value
globalXTranslated = (512/xpoints) * xadjusted
globalYTranslated = (512/ypoints) * yadjusted
3saul: What do you know about these maps you have? What kind of projection (Mercator, etc.) was used to make them? Most map projections distort some feature (direction, location, area, etc.) in order to produce a 2-D representation of the surface of a 3-D body. Unless you have a special map projection, a simple linear scaling of lat/long to X/Y will not be accurate.
The projection for the map images is gnomonic. They are Lambert Conformal, with standard parallels of 18S and 40S.
I hope this helps you to help me further. It means very little to me.
