Converting between wavenumber and wavelength
In summary: This is where you went wrong.In summary, the conversation discusses dimensional analysis and the use of symbols in equations. The conversation highlights the importance of being specific with the definitions of symbols and how their meanings can change depending on context. This is demonstrated through the discussion of the wavenumber and wavelength equations, where the symbol "radians/wave" has different meanings in each equation, resulting in a contradiction.
aliens123
75
None
By dimensional analysis, we have that the wavenumber: $$k = \frac{\text{radians}}{\text{distance}}$$
And the wavelength:
$$\lambda = \frac{\text{distance}}{1 \text{wave}}$$
Then:
$$\lambda k = \frac{\text{radians}}{\text{distance}}\frac{\text{distance}}{1 \text{wave}} = \frac{\text{radians}}{1 \text{wave}}$$
Now:
$$2\pi \text{radians} = 1 \text{wave} $$
$$\frac{\text{radians}}{1 \text{wave}} = \frac{1}{2\pi} $$
So
$$\lambda k = \frac{1}{2\pi} $$
But this contradicts the "well known"
$$\lambda k = 2\pi $$
So where did I go wrong?
You were not specific enough with your definition of ##k##. Instead of ##k=\dfrac{\mathrm{radians}}{\mathrm{distance}}##, you should have said ##k=\dfrac{\mathrm{radians~in~1~wave}}{\mathrm{distance~of~1~wave}}##. Then you get the definition for the wavenumber ##k## with "radians in 1 wave"= ##2\pi## and "distance of 1 wave"= ##\lambda##. Dimensional analysis is not a good heuristic tool for figuring out where constants go, if they belong anywhere.
Likes aliens123
I agree with @kuruman . Symbols such as ##\frac{\text{radians}}{\text{wave}}## can be ambiguous.
For example suppose I write ##\frac{\text{in}}{\text{ft}}##. What does this mean? If it's interpreted to mean the number of inches per foot, then it equals 12. But if it means the ratio of an inch to a foot, it equals 1/12.
You wrote
Here, the meaning of ##\frac{\text{radians}}{1 \text{wave}}## is the number of radians of phase in one wavelength. So it equals ##2\pi##.
Then you wrote
Now:
$$2\pi \, \text{radians} = 1 \text{wave} $$
Here, the meaning of the first equation ##2\pi \, \text{radians} = 1 \text{wave} ## is to say that moving along a wave such that the phase increases by ##2\pi \, \text{radians}## is the same as moving 1 wavelength. You could rearrange this as ##\frac{2\pi \, \text{radians}}{1 \text{wave}} = 1##. The ratio on the left equals 1 in the sense that the numerator and the denominator represent the same amount of movement along the wave. Dividing both sides by ##2 \pi## then gives the second equation. But note that now the meaning of ##\frac{\text{radians}}{1 \text{wave}}## is the ratio of how much you need to move along a wave to change the phase by 1 radian to moving along a wave by one wavelength. This ratio is ##\frac{1}{2 \pi}##. That is, changing the phase by 1 radian only takes you along the wave by ##\frac{1}{2 \pi}## of a wavelength.
So, here the meaning of the symbol ##\frac{\text{radians}}{1 \text{wave}}## is different than the meaning of the same symbol when you used it in your expression for ##k \lambda##.
Likes aliens123
1. What is the relationship between wavenumber and wavelength?
Wavenumber and wavelength are inversely proportional to each other. This means that as the wavenumber increases, the wavelength decreases and vice versa.
2. How do you convert from wavenumber to wavelength?
To convert from wavenumber (cm-1) to wavelength (nm), you can use the formula: wavelength (nm) = 107 / wavenumber (cm-1). This will give you the wavelength in nanometers.
3. What is the unit of measurement for wavenumber and wavelength?
Wavenumber is measured in reciprocal centimeters (cm-1), while wavelength is measured in nanometers (nm).
4. Why is it useful to convert between wavenumber and wavelength?
Converting between wavenumber and wavelength allows for easier comparison and analysis of different electromagnetic spectra. It also helps in identifying specific molecular vibrations and electronic transitions.
5. Can you convert between wavenumber and wavelength for all types of waves?
Yes, the conversion between wavenumber and wavelength is applicable to all types of waves, including sound waves, light waves, and radio waves. However, the units used may differ depending on the type of wave being measured.
