Converting Celsius to Kelvin Easy but slightly confusing
2 replies · 5K views
Spartan Erik
I'm doing calorimetry, and I have 34.73C and 63C. I need to subtract 63 from 34.73, and get the answer in Kelvin.
I know you add 273 to Celsius values to get Kelvin, but I am not sure which of these methods is correct:
1. (34.73C+273) - (63C+273) = -28.27K
2. 34.73C-63C = -28.27C. Then, -28.27C + 273 = 244.73K
Which one is the correct method? The first one seems unlikely just because the Kelvin's are essentially canceled out in the equation..
The first one. You are subtracting one temperature from another so the "base"- that is what temperature corresponds to 0- is irrelevant. You could as easily have just said that 34.73- 63= -28.27 degrees. Since 1 degree celsius is the same "size" as 1 degree Kelvin, the difference is the same in both systems.
Ah I just realized that I was calculating the DECREASE in temperature of hot water, so a negative decrease is a positive value. Thanks!
