Converting integer into array of single digits in C#?
  • Topic: C#
  • Thread starter rollcast
    Array Integer
4 replies · 61K views · last reply
rollcast
Whats the easiest way to take an integer in C# and convert it into an array of length equal to the number of digits and each element is a digit from the integer?
EG. If I had the integer 12345 I want to convert it to an array like so {1, 2, 3, 4, 5}
Thanks
AL
Thanks
AL
I don't know if it's easiest, but in C I would use the modulus operator %. Can you see how you would use it to do this task?
Nope, :confused:
Converting 12345 to an integer array:
Code:
int[] digits = 12345.ToString().ToCharArray().Select(Convert.ToInt32).ToArray();
If you only need a character array you can obviously stop after the ToCharArray().
Code:
The conversion to an int array is not quite right. The Convert.ToInt32 will convert the char to its equivalent decimal value which is not the same as parsing it. e.g. the character '1' will be converted to 49. Instead you will have to use the int.Parse which will require casting the char to a string first but the better approach is to use the Char.GetNumericValue and cast to int16, int32 as preferred because the method returns a double.
The code should look like:
Code:
int[] digits = 12345.ToString().ToCharArray().Select(x => (int)Char.GetNumericValue(x)).ToArray();
To take it to the next level and you want to convert an unknown string you can use regex to strip out non numeric characters.
Code:
int[] digits = Regex.Replace(numberToParse, "[^0-9]", "").Select(x => (int)Char.GetNumericValue(x)).ToArray();
