Converting V from GeV to meters in M_p^2 = M_s^3 V
6 replies · 2K views
Safinaz
How to get the length in this eqution in the right unit
## M_p^2 = M^3_s V ##
Hello,
If i have this relation:
where ##M_p ## and ##M_s ## are masses in GeV and V is a length. Let ## M_p = 10^{18} ~ ## GeV and ##M_s = 10^3 ## GeV , what is V in meters ?
My solution :
The equation becomes
## V = 10^{30}## GeV , but ## 1 m \sim 10^{15} ~ GeV^{-1} ## or ## 1 m^{-1} \sim 10^{-15} ~ GeV ##
which means ## V = \frac{10^{30} ~ GeV. m^{-1}}{10^{-15} ~ GeV} = 10^{45} ~ m^{-1} ## ! is there any wrong here?? Cause V is so large , and also i want it in meters not ## m^{-1} ##Any help is appreciated!
Thanks!
Your math is off. ##V## must have energy units of inverse energy for your initial relation to make sense.
anuttarasammyak said:
V has dimension of ##E^{-1}##
If like in this case ## M_s = 1000 ## GeV and ## M_p = 10^{18} ## GeV, ( ## M_s ## is much less than ## M_p ## ) . This means this equation should be rewritten to add some factor of dimensions ## GeV^{-2} ##. Then the equation become:
## M_p^2 = \frac{1}{g^2} M^3_s V ## But according to this paper
https://inspirehep.net/files/da3f5a4d325281183a9b6134ad7c7dce
g is dimensionless cause it's a gauge coupling. So I don't get how in this paper after equation : ( 2.1 ) he got ## V = 10^8 ## km.
Safinaz said:
Homework Statement:: How to get the length in this equation in the right unit
Relevant Equations:: ## M_p^2 = M^3_s V ##
Hello,
My solution :
Thanks!
I guess you are using natural units, i.e. taking ℏ = c = 1. (If this is correct, it would have been helpful if you had stated this explicitly.)
##V = \frac {M_p^2 }{M^3_s} = \frac {(10^{18} GeV)^2 }{(10^3 GeV)^3} = \frac {10^{36} GeV^2}{
10^9 GeV^3} = 10^{27} GeV^{-1}##
A length of ##1GeV^{-1}## in natural units ≈ 0.2 fm (=0.2x10⁻¹⁵ m) in SI units.
So, for the final step, you can now convert ##10^{27} GeV^{-1}## to metres.
(Edited, as original version included the final step - which meant you had nothing to do for yourself!)
Thanks! That's very helpful.. It seems I'm just confused.
