Convex lens questionCant find the equation i need. Please help
The discussion centers on calculating the size of the moon's image on a screen using a convex lens with a focal length of 0.8 meters. The lens equation 1/f = 1/u + 1/v is applied, where 'u' is the object distance and 'v' is the image distance. The user, Si, correctly identifies that the moon's distance can be approximated as infinity, simplifying the equation to 1/v = 1/0.8. The final calculation yields an image distance of 4 meters. The subtended angle of 0.5 degrees is acknowledged but not fully integrated into the final calculation.
  • Understanding of the lens formula: 1/f = 1/u + 1/v
  • Basic knowledge of optics, specifically convex lenses
  • Familiarity with angular measurements in degrees
  • Concept of image formation in optics
  • Study the derivation and applications of the lens formula in optics
  • Learn how to convert angular measurements into linear dimensions
  • Explore the concept of image magnification in lens systems
  • Investigate the effects of varying focal lengths on image formation
Students studying optics, physics enthusiasts, and anyone seeking to understand image formation through convex lenses.
sidge2222
A convex lens of focal point 0.8m focuses a real image of the moon onto a screen. If the moon subtends an angle of 0.5 degrees to an observer on earth, calculate the size of the moons image on the screen?
Thats the question guys, I am really struggling to find the appropriate equation as we havnt been given any by out lecturer as he's been off ill. It needs be in after half term and we don't have any equations, i would greatly appreciate any help.
Im new to this forum so just wanted to say hi to everyone as well :)
Si
Because i have the focal point of 0.8, I am assuming that i should use the normal lens equation of 1/f = 1/u + 1/v which would be rearranged to 1/v = 1/f - 1/u because v = lens to image, so because I am after the size of the moons image on the screen this is what I am thinking is the correct equation. Am i right in thinking this guys??
So if I am after v, i need to obtain u in order to complete the equation - so am i right in thinking i need a sort of equation in order to convert the 0.5 degrees into a relevant figure??
Looking forward to your replies :)
Si
bump - sorry
If you draw a picture you can find out how is the angle of view related to the ratio of the object height to the object distance and that of the image height to the image distance. As for the object distance, the Moon is so far away that the object distance can be considered infinity. Where will be the image than?
ehild
so if u is infinitie that means its 1 right?
then my complete equation will be:
1/v = 1/f - 1/u
1/v = 1/0.8 - 1/1
1/v = 1/0.25
v = 4m
This seem right guys?? I am unsure as I am missing the moon subtending an angle of 0.5 degrees, which too be honest I am quite unsure about
thanks for the reply so far and for everyone that's had a read :)
Si
1 is not infinite. At the limit u→∞ 1/u→0.
ehild
  • · Replies 20 ·
30K
