Convolution Help on tri(x,y) ** (step(x) * 1(y))
  • Thread starter Thread starter snatchingthepi
    Convolution
The discussion focuses on performing 1D convolution on a 2D function defined as tri(x,y) ** (step(x) * 1(y)). The user clarifies that the convolution can be separated into two distinct 1D convolutions due to the separability of the triangular function, leading to the conclusion that tri(x,y) can be expressed as tri(x) * tri(y). The integrals to evaluate are ∫ tri(t,y) step(x-t) 1(y) dt and ∫ tri(x,t) step(x) 1(y-t) dt, treating y and x as constants in their respective calculations.
  • Understanding of convolution operations in signal processing
  • Familiarity with 2D functions and their separability
  • Knowledge of triangular functions and their properties
  • Basic calculus, particularly integration techniques
  • Study the properties of separable functions in convolution
  • Learn about the application of convolution in signal processing
  • Explore the use of triangular functions in mathematical modeling
  • Investigate the Fourier transform and its role in convolution
Students and professionals in mathematics, engineering, and signal processing who are working with convolution operations and seeking to understand the separation of multidimensional functions.
snatchingthepi
Evaluate and sketch the 1-D convolutions:
I have some confusion about this question.
I am asked to do the 1D convolution of a function that is clearly 2-dimensional
tri(x,y) ** (step(x) * 1(y)) where ** is the convolution.
Furthermore my professor is not available for questions (have tried). I'm wondering if I simply ignore the bits of 'y' and convolve
tri(x) ** step(x)
or if there's something I'm missing. I don't have the text yet (on order - Easton's "Fourier Methods in Imaging") and the library doesn't have a copy either. Also if anyone happens to know the name of the function 1(y) I'd be most grateful.
I think the exercise means to do two different convolutions, one with respect to x and one with respect to y.(it says evaluate and sketch the 1-D convolutions).
So first calculate the integral
##\int tri(t,y)step(x-t)1(y)dt## (y is effectively a constant for this calculation) and then the integral ##\int tri(x,t)step(x)1(y-t)dt## (now x is considered to be a constant).
I found out what is going on. Turns out that since tri(x,y) => tri(x) * tri(y) the equation is separable and can be written as two 1d convolutions like
(f(x) ** h(x)) * (f(y) ** h(y))
  • · Replies 17 ·
