Coordination no. in crystals (conceptual)
The discussion revolves around the concept of coordination number in crystal structures, particularly focusing on beryllium (Be) and its bonding characteristics. Participants explore the implications of coordination number in different contexts, including ionic and covalent bonding, and the relationship between atomic size and coordination in crystal lattices.
  • Some participants assert that coordination number refers to the number of nearest neighbors in a crystal structure, questioning its significance in relation to electron bonding.
  • There is a claim that beryllium cannot exhibit a coordination number of 6 due to a lack of orbitals, with references made to various textbooks.
  • Others argue that the limitation on beryllium's coordination number is not due to orbital availability but rather its small size as a cation, which affects its ability to coordinate with larger anions.
  • A participant discusses the distinction between coordination number in crystals versus in molecular complexes, emphasizing that in crystals, distance is used as a proxy for bonding.
  • Concerns are raised about the term "nearest" as a descriptor for coordination number, with examples provided to illustrate potential ambiguities in defining coordination based on distance.
  • Some participants express confusion over the technical explanations provided, indicating a need for simpler language to clarify the concepts being discussed.
  • There is a discussion about the differences in coordination number between salts and covalent/metallic compounds, highlighting the impact of atomic size on coordination capabilities.
Participants do not reach a consensus on the reasons behind beryllium's coordination number limitations, with multiple competing views presented regarding the role of atomic size versus orbital availability. The discussion remains unresolved on these points.
Participants reference various textbooks and sources, but there are limitations in access to these materials, leading to challenges in verifying claims. The discussion also highlights the complexity of the topic, with some participants expressing difficulty in understanding the technical aspects presented.
namanjain
what does coordination no in crystal structures really mean?
i know it's no of nearest neighbors but has it significantly to do with bonding of electrons.
actually my doubt is that -
I read Be can't show coordination no of 6 and is allowed to show only coordination no 4 due to lack of orbitals. Just few minutes ago i read that it is packed in HCP type of lattice
"Beryllium is a steel gray and hard metal that is brittle at room temperature and has a close-packed hexagonal crystal structure." source wikipedia
we know in HCP coordination no is 12
So in crystals what feeling of coordination no. must i get?
Chemistry news on Phys.org
Please cite your source.
"jd lee" Wiley India edition page 332 fifth edition,
also in ncert chemistry textbook(indian board publication)
Now can anyone help me with my problem
I don't have access to this book but the statement seems not correct.
In salts and the like Be is often only coordinated by 4 anions, as it is a very small cation.
However, this is not due to the number of orbitals.
Given that anions are much larger than neutral Be atoms, this argument does not hold in Be metal and coordination can be higher.
I couldn't access page 332 of JD Lee from Google Books.
Please point the page number from the NCERT chemistry textbook.
beryllium does not exhibit coordination no. more than 4 as in it's valance shell there are only four orbitals ...
page no. 302 'chemistry class 11' 'part 2' , first column last paragraph
"Coordination Number" is used in two different main contexts: in a crystal, or in a molecule, molecular complex, or some type of coordinate-covalent structure (usually as a solute). Until relatively recently, it was difficult to use ab initio quantum mechanical calculations to accurately predict/model ELECTRON DENSITY which is the most preferred way to estimate bonding between atoms. In molecules, coordination number is ONLY about the bonding. In crystals the distance between atoms was/is used as a proxy for bonding and it was assumed that the bonding only occurred from one atom to its "nearest" neighbors. (Which often could be determined by crystallographic methods). If you think about it, the term "nearest" is very unsatisfactory as a descriptor. Let me give you two examples: Ex.1. Let's say in a crystal structure Be has 4 neighbors we'll call A, all at the same (nearest) distance, and 2 neighbors, C, both 2% farther from the Be atom than the A's are. Question: what is the coordination number for the Be - 4 or 6 ? Ex. 2. Let's say that the Be has 6 neighbors, each of which is at a (slightly) different distance from it. It therefore only has one "nearest" neighbor. Is it correct to claim that the coordination number is 1? That sounds pedantic (and incorrect) to me. There are a variety of properties from which we can infer bonding type interactions (conductivity and electrical properties being a major type). Now days we can determine which atoms are bonding by calculation with good accuracy (not perfect, still some unknown territory out there). So, no solid state chemist worth her salt would claim that the coordination number should ignore significant bonding interactions simply because the two atoms aren't "nearest" neighbors.
You should not ascribe covalent character to metal bonding. Metallic Be has no simple relationship to the covalent chemistry of Be (all Be compounds are (mostly) covalent). Hence the fact that each atom in metallic Be has 12 nearest neighbors elicits a "so what?" from me. You need to consider the context of what ever you are reading, otherwise understanding will be difficult.
Be will tend to have a formal + charge, which means it would be a very small cation (if it were actually ionized in its compounds). Most anions are quite large, meaning getting 6 of them close to a Be cation would be difficult (at normal pressures, but what about at 10,000 gravities?) There is nothing contradictory in saying that the chemistry of Be is generally tetrahedral (or better and more general has coordination number 4) and the element is HCP in the solid state crystal.
thanks abitslow, you really worked hard over the text but your work was tooo.. scientific and high fi, i mean that I AM JUST in 11th AND FOR SURE THE INITIAL LINES WERE GONE OVER MY BRAIN (over that quantum part and mot..)
also my question was that what was the difference between the two types of coordination no ie. you said it is foolish to compare Be in crystal and covalent bonding, but i think why.
I accept that i am conceptually not clear over part and i again have no mean that you had done bad work but just a bit simple language will help better.
The point is that salts are made up of small cations and large anions, while covalent and metallic compounds are made up of atoms of rather comparable size. Hence in a salt, the cation (Be in this case) can coordinate much less anions around it than a Be atom can coordinate other Be atoms in the metal.
This has little to do with the number of orbitals. So either your text is not right here, or the half-sentence you have given us is quite out of context.
