Copying from /usr/local/bin to /usr/bin?
  • Thread starter CAF123
45 replies · 13K views · last reply
CAF123
I'd like to move (or copy) an executable (namely the gfortran one) from /usr/local/bin to /usr/bin. Is it possible?
Copy and pasting via the Go to folder doesn't work probably because it requires permissions and I have tried sudo cp /usr/local/bin/gfortran/ /usr/local/bin in the terminal but it said the operation was not permitted after putting in my MAC password. Also I consider myself a computer noob so probably being silly somewhere. Is the gfortran executable a Fortran 77 compiler?
Thanks!
Yes, but as you found out, you need root permissions for that. Perhaps better would be to either put /usr/local/bin in your $PATH, or make a symbolic link from /usr/local/bin to /usr/bin. Assuming you are in a shell inside the /usr/bin directory and you have root permissions, you could type
Code:
ln -s /usr/local/bin/gfortran .
to make the symbolic link.
I don't know how one becomes root on a MAC, but this should be Googleable. In my Linux Bash shell, I would type
Code:
su -
to become root.
Yes, it compiles Fortran 77 just fine. If you are writing new software, I would recommend using Fortran 90 or newer. (It is safer, more readable, has better matrix support... Simply more up-to-date.)
Software suites like gcc (of which gfortran is part) often depend on particular directory structures, so simply moving a single file will probably not do the trick. Either use @Krylov's advice of running it from /usr/local/bin or reinstall gcc to use /usr/bin.
That should've worked, but without the / after gfortran.
Code:
su -
to become root.
There is no superuser account on Macs (for security reasons). One has to use sudo to perform su operations in a terminal.
For more information on compiling fortran on the Mac, I recommend http://hpc.sourceforge.net
The correct command would be:
Code:
sudo cp -r /usr/local/bin/gfortran/ /usr/bin
with the target directory /usr/bin instead of /usr/local/bin, and with -r indicating copying recursively.
I would suggest moving though with:
Code:
sudo mv /usr/local/bin/gfortran/ /usr/bin
From wiki:
wiki said:
GNU Fortran or GFortran is the name of the GNU Fortran compiler, which is part of the GNU Compiler Collection(GCC). GFortran has replaced the g77 compiler, on which development stopped before GCC version 4.0. It includes full support for the Fortran 95 language and is compatible with most language extensions supported by g77, allowing it to serve as a drop-in replacement in many cases. Large parts of Fortran 2003 and Fortran 2008 have also been implemented.
Code:
Code:
gfortran is an executable file, not a directory.
Consider @DrClaude advice and do not move executables around especially in the /usr tree. /usr should be maintained only by existing code and installer scripts, do not mess with it, even on a mac.
Why? you can easily cause the system to fail to boot with one small change, for example. File and runtime library dependencies are best left to the installer, not the owner.
Ah, in that case I definitely recommend against copying or moving, since there will be other parts of the compiler that won't be taken along, with the result that it won't work anymore.
(And a possible reason for the failure is the trailing slash (/) that identifies gfortran as a directory.)
Then a symbolic link would be more appropriate as @Krylov suggested:
Code:
sudo ln -s /usr/local/bin/gfortran /usr/bin/
Or alternatively, uninstalling and reinstalling.
Or adding /usr/local/bin to the PATH environment variable.
Or defining gfortran as an alias for /usr/local/bin/gfortran.
Many thanks for all these replies. Maybe it's worth explaining what I am trying to do - basically I want to use something called LoopTools and that requires a Fortran 77 compiler, gcc, g++ and make. I see that in the past I have all such things already on my machine in the /usr/bin except the gfortran which is in /usr/local/bin. When I try to run the configure executable in the unpacked tar file for LoopTools (simply ./configure in terminal within LoopTools folder) I get terminal output saying Fortran-77 compiler not in PATH. So I'm thinking that the problem is that I need to move the fortran executable to /usr/bin because everything else needed (i.e make, gcc,g++) was found ok and they're all in /usr/bin. Am I thinking correctly? If not maybe there is a simpler solution.
Thanks again!
Thanks again!
Yes, I think we can offer a simpler solution.
How about:
Code:
export PATH=$PATH:/usr/local/bin
./configure
How about:
Code:
./configure
Oh I just tried it in the terminal while I was in the LoopTools directory and it gave me the same error message :/
Which error message exactly?
I went to the LoopTools folder and typed in the terminal
Code:
MyName-MacBook-Pro:LoopTools12 myname$ export PATH=$PATH:/usr/local/bin
MyName-MacBook-Pro:LoopTools12 myname$ ./configure
and I get terminal output
Code:
looking for make... /usr/bin/Make
looking for Fortran... no Fortran-77 compiler in your path.
Code:
Code:
It looks as if your 'configure' script does not recognize gfortran as a a Fortran-77 compiler.
To confirm, we need a bit more information what ./configure is looking for exactly, meaning we need more verbose output.
Something like:
Code:
./configure --help
should show how to get more verbose output.
ah it gave me the same terminal output as above, when I tried with just ./configure. Would you perhaps recommend I reinstall another fortran-77 compiler then?
First give this command at the command line: echo $PATH
to see which directories are in your path. If it doesn't contain /usr/local/bin, then:
Give the command: echo $SHELL
This will tell you what your default shell is. On my old MacOS (10.9.5) system, it's /bin/bash.
In my home directory, I created (a long time ago) a file named .bash_profile (note the '.' at the beginning) which contains:
PATH=/Users/jtbell/bin:/usr/local/bin:/usr/local/mysql/bin:$PATH
export PATH
If you're using bash also, create this file (or edit it if it exists already), and include /usr/local/bin in your path. You don't need the other directories that I have:
PATH=/usr/local/bin:$PATH
export PATH
If you're not using bash, you need to make a similar change in a different file, but the syntax may be different.
That's probably indeed the easiest way forward.
It looks as if your ./configure script is a bit dated, so to make it work we may need an older fortran-77 compiler.
@jtbell I tried echo $PATH and I see that both /usr/local/bin and /usr/bin are listed, amongst others. Probably I should proceed with reinstalling another compiler, as I like Serena thinks might also help.
@I like Serena Do you know where I can find a compiler that would work? I have done a google search but lots of hits, sorry wish I was more computer savvy :)
If, when you type gfortran in the terminal window, it executes correctly, then the problem is not your installation, it is LoopTools. Check the information in that package concerning installation.
Googling for it actually usually leads to gfortran... although I also see references to a f77 compiler.
Let's try/confirm something.
Try:
Code:
alias f77="/usr/local/bin/gfortran"
f77
./configure
It may already solve your immediate problem, and at least it will tell us:
- whether your gfortran actually works,
- whether the configure script looks for f77.
Good point.
I suggest looking in the directory for other files like README or INSTALL that may explain what is needed.
@I like Serena @DrClaude Thanks, I tried the suggestion of
Code:
f77
./configure
and it said that
Code:
gfortran: fatal error: no input files
compilation terminated.
The error happened when I typed in and executed f77 subsequent to executing alias f77 ="/usr/local/bin/gfortran"
The following is the output from the INSTALL file I find in the LoopTools folder
To install LoopTools you need a Fortran-77 compiler, GNU make, gcc,
and g++. Once you've got these installed, the rest is straightforward:
Run ./configure to configure the GNUmakefile.
Run gmake to build the libraries and binaries.
(Optional) Add $HOME/ff/$HOSTTYPE to your path or copy the files in
$HOME/ff/$HOSTTYPE to a public location (e.g. /usr/local/lib for the
libraries and /usr/local/bin for bra).
so I'm guessing once the problem with fortran 77 has been dealt with probably the rest should be ok.
Edit: Maybe I should also point out that there is also a utils folder inside LoopTools and that contains the following items, ccf, F77, F77.in, f77c, f77290.c and patchup. All but the f77290.c files are executables. I wonder if the F77 is the thing I need?
That's expected. It confirms that the alias works, and that gfortran can actually run.
Question remains, what does ./configure say?
Yes, the presence of those files suggest that you need f77, or perhaps it has to be named F77.
So... what does ./configure say now?
Oh I didn't bother trying ./configure after I got the error from executing f77. But it just gives me the same error as before (that Fortran-77 not in my path). I wish I could move the F77 executable in the utils folder to the /usr/bin but I don't know how to do this (if you agree this would be a sensible thing to try)
Neh. Just try the same alias trick, but now with 'F77' instead of 'f77'.
Ah, same error as before :/
Code:
and ./configure gives again
Code:
Code:
Code:
I guess we need to know a bit more about what that actually means.
Either we need more verbose output from configure, or we have to take a closer look at what its source code is doing.
Can you upload a zip of the whole thing? Or if it's too big, just the top level directory including that utils directory?
Alternatively, you might search for it with:
Code:
grep -R 'Fortran-77' .
and see what comes out.
The configure script probably uses its own instance of the shell. You will need to modify the shell control file .bashrc to set PATH properly.
I have checked that you do not need to create the f77 alias. It will find gfortran by itself, provided /usr/local/bin is in the path.
Thanks! Yes it was an older version that I had downloaded and hadn't realized. It now works :) I want to use this with mathematica, which has the simplest user interface. On page 29 (sect 1.6) it tells me to write Install["LoopTools"] after writing some path. Do you know what hosttype means?
