Correlation coefficient of a jumping particle
6 replies · 2K views · last reply
Addez123
Assume the a particle to be in origo. Every step it jumps either -1 or 1 in either x or y plane.
So for each step it can move (1,0), (-1,0), (0,1) or (0,-1).
Let the particle start in origo and X, Y define the position after the first step.
Calculate ρ(X, Y)
ρ(X, Y) = C(X, Y) / (D(X) * D(Y))
C = Covariance
D = Standard deviation
C(X, Y) = E(XY) - E(X)E(Y)
What I need help with is how I would start..
I can say p(X, Y) = (1,0) = 1/4, and same for the other 3 coordinates. P = 0 for all other coordinates.
This doesn't give me anything to work with though.
What is XY? I don't even know what X is.
Maybe 0 if x < -1, jumps to 1/2 if x = -1 then jumps to 1 at 1?
Idk how to express it in numbers though.
No I don't think its like that, I expect it to be symmetric around x=0, if by probability distribution we mean the probability ##P(X=x)## where x an integer. The particle can move to +1 or -1 of its current position with respect to x-axis. So it has a non zero probability to be found at any ##(x,y)## where (x,y) integers.
@haruspex any hints how to calculate the probability P(X=x) cause I am stuck also and my probabilities are rusty. The problem I am seeing is that there are infinite ways in which the particle can arrive at (x,y). Am I overcomplicating the issue (I probably am but I don't know where my thinking is wrong).
EDIT: I should have read the problems statement more carefully. X,Y are defined in a specific different way.
(X, Y) is defined as the position after one step. So it is equally likely at each of four positions. In how many of those is X=-1, etc.?
I was able to calculate
$$E(x) = \sum_k g(k)*p_x(k) = -1 * 1/4 + 1 * 1/4 = 0$$
Then I got variance by
$$V(x) = E(x^2) - E(x)^2 = 1*1/4 + 1*1/4 - 0 = 1/2$$
$$D(x) = \sqrt{V(x)} = 1/\sqrt{2}$$
Same for y since they are identical.
$$ρ(X, Y) = C(X, Y) / (D(X) * D(Y)) $$
$$C(X, Y) = \sum_j \sum_k (j - ux)(k - uy)p(j, k) = 1/4 * (1*0 + -1*0 + 0*1 + 0*-1) = 0$$
Now the second question is: Are they independent?
X and Y are independent if
$$E(XY) = E(X)E(Y)$$
We can get E(XY) from this equation:
$$C(X,Y) = E(XY) - E(X)E(Y)$$
$$E(XY) = -E(X)E(Y) - C(X,Y) = -0*0 -0 = 0$$
Therefore x and y are independent. My book says they are NOT independent though.
Where did I do wrong?
Addez123 said:
X and Y are independent if ##E(XY) = E(X)E(Y)##
If X and Y are independent then that is true, but it is not a sufficient condition for independence. Check your notes.
