Cosine = Contraction? (Banach)
The discussion centers on the application of Banach's contraction theorem to the cosine function. It establishes that cosine is not a strict contraction on the entire real line, particularly around the points π/2 and kπ + π/2 for integers k. However, it is confirmed that cosine acts as a contraction mapping within the interval [-π/2 + ε, π/2 - ε], where 0 < ε < π/2, with a contraction factor k = sin(π/2 - ε). The proof utilizes trigonometric identities and the mean value theorem to demonstrate the behavior of cosine near critical points.
  • Understanding of Banach's contraction theorem
  • Familiarity with trigonometric identities and limits
  • Knowledge of the mean value theorem
  • Basic concepts of fixed-point theory
  • Study the implications of Banach's contraction theorem in various mathematical contexts
  • Explore the properties of trigonometric functions and their derivatives
  • Investigate fixed-point theorems and their applications in analysis
  • Learn about convergence criteria for sequences and functions in real analysis
Mathematicians, students of real analysis, and anyone interested in the convergence properties of functions, particularly in the context of contraction mappings and fixed-point theorems.
nonequilibrium
So in Analysis I we explained the convergence of cos to a fixed value by Banach's contraction theorem. But is the cos a strict contraction? Is that obvious? (What is its contraction factor?)
It's not obvious to me that cosine is a strict contraction on the whole real line. In fact, I'm not sure it's even true. For instance, around pi/2 seems to pose many problems. Was the contraction restricted to an interval?
As Tedjn mentioned you need to restrict cosine to a small enough interval due to the behavior near pi/2 (and kpi+pi/2 for all integers k). In fact it's a well-known trigonometric identity that \sin(h)/h \to 1 as h\to 0 so this gives us:
\left|\frac{\cos(\pi/2-h) -\cos(\pi/2)}{\pi/2-h-\pi/2}\right| = \frac{\cos(\pi/2-h)}{h} = \frac{\sin(h)}{h} \to 1
for h \to 0. This shows in particular:
d(\cos(\pi/2),\cos(x)) \to d(\pi/2,x) \qquad \mbox{for }x \to \pi/2
so if you choose a contraction factor k < 1 it would result in a contradiction for x close enough to \pi/2.
However it's possible to show that cos is a contraction mapping defined on any set of the form [-\pi/2+\epsilon,\pi/2-\epsilon] where 0 &lt; \epsilon &lt; \pi/2. In fact we know |sin h| &lt; |h| for all h in [-\pi/2,\pi/2]. Let k=\sin(\pi/2-\epsilon) &lt; 1. Using the identity:
\cos y - \cos x = 2\sin\left(\frac{x+y}{2}\right)\sin\left(\frac{x-y}{2}\right)
we have:
\begin{align*}<br /> f(x,y) = \left|\frac{\cos y - \cos x}{y - x}\right| &amp;= \left|2\sin\left(\frac{x+y}{2}\right)\frac{\sin\left(\frac{x-y}{2}\right)}{x-y}\right| \\<br /> &amp;= \left|\sin\left(\frac{x+y}{2}\right)\frac{\sin\left(\frac{x-y}{2}\right)}{\frac{x-y}{2}}\right|<br /> \end{align*}
Clearly a least upper bound for f(x,y) is equivalent to a contraction factor. We can fix x=pi/2-\epsilon and let y approach x from below. Then the first term of f(x,y) approaches \sin(\pi/2-\epsilon) and the second approaches 1, so f(x,y) will approach k=sin(\pi/2-\epsilon). This shows that the contraction factor must at least be k. On the other hand we have:
\left|\frac{\sin\left(\frac{x-y}{2}\right)}{\frac{x-y}{2}}\right| \leq 1
so
|f(x,y)| \leq \left|sin\left(\frac{x+y}{2}\right)\right| \leq \sin(\pi/2-\epsilon) = k
which shows that k is actually the contraction factor for cos defined on [-\pi/2+\epsilon,\pi/2-\epsilon].
This should however be sufficient as |cos(x)| \leq 1 so clearly any fixed point will lie in [-1,1] and \pi/2 &gt; 1.
A very nice proof that it fails near pi/2. Another way I've seen the second part proved is using the mean value theorem.
Ramshop, that's the second time you've made a very informative post, thank you.
Also thank you to Tedjn for posting :)
Having seen the proof, it's logical the fixed-point theorem of Banach still applies, as no matter where you start, you'll eventually end up in the strict contraction "zone".
One button calculator, cos, cos, cos,...
Code:
     _________________________________
    |    _   _  _  _  _  _  _     _   |
    |   | |   | _||_|| ||_||_   | _|  |
    |   |_|.  | _| _||_||_| _|  | _|  |
    |                             rad |
    |           | cosine |            |
    ._________________________________.
