Cosmic background radiation - alternative proposal
55 replies · 13K views
Nereid said:
(various things)
Can anybody please explain the following statement from here
The WMAP spacecraft can measure the basic parameters of the Big Bang theory including the geometry of the universe. If the universe were open, the brightest microwave background fluctuations (or "spots") would be about half a degree across. If the universe were flat, the spots would be about 1 degree across. While if the universe were closed, the brightest spots would be about 1.5 degrees across.​
The website doesn't say (AFAIK) why these angular widths were expected nor how they relate to the proposed age of the universe since the claimed Big Bang.
Astronomy news on Phys.org
zforgetaboutit said:
Let me address one rebuttal at a time.
As a result of your posting I just skimmed http://ernie.ecs.soton.ac.uk/opcit/cgi-bin/pdf?id=oai%3AarXiv%2Eorg%3Aastro%2Dph%2F9905257 as best I could and finally arrived at the Conclusions on page 27 where the authors state
I was impressed with the paper's details, and the very difficult attempts to make sense of the apparently noisy data via COBE et al.
The sheer number of analytical assumptions that permit further progress is amazing, but you have to start some where.
Thanks for the link, it was a most enjoyable paper! You can see that the field has moved on a great deal by reading the early COBE papers, and how they analysed the data to characterise, and remove, the foregrounds (there were also a few subtleties and complexities that I hadn't been aware of).
One way to treat this paper is to think that Tegmark et al want to squeeze every last tiny bit of CMB data (actually, estimates of parameters in cosmological models) out of the experiments as they possibly can, and at the same time be able to robustly address any challenge to their analysis. It is quite possible to use much blunter instruments to make the data tell its CMB story - you could completely ignore all data from 20o either side of the galactic plane, for example, or remove only known radio and IR point sources.
So, as I (mis?)understand it, the results could be off by 2X or 5X, due to the complexities of foreground signal artifact removal. I realize the scope is cosmological here, but still - that's a lot of fudge factor, so far.
That's not quite what they're saying; more that the error bars on estimates of their favourite cosmology model parameters will be greater than if they could remove the foregrounds perfectly - so for example, if they estimate a model parameter (I'm making this up) to be 4.2 +/- 0.5 assuming they can characterise the foregrounds perfectly, the results from BOOMERANG, WMAP (as it's now called), or Planck could be 4.2 +/- 1.0 (or, worst case,4.2 +/- 2.5).
At the end of the parer they state
A large number of papers have now painted a rosy picture of the future of cosmology, with CMB experiments measuring cosmological parameters to unprecedented accuracy over the next decade. In this paper, we have tried quite hard to spoil this picture, using foreground models with hundreds of harmful parameters and pushing them to limits of physical plausibility and current constraints.
Although we have found that great care needs to be taken in the foreground removal phase of the data analysis to avoid potentially perilous pitfalls, we have failed to tarnish the overall picture with more than a few minor blemishes, degrading the accuracy on certain measurements by small factors. Although much work certainly remains to be done on the foreground problem, this is cause for cautious optimism.
Some other scientists think we should wait a little longer.
My interpretation is somewhat different (remember that Tegmark et al are regarded as among the leaders of observational cosmology) - unless there's something totally left-field, we can confidently expect that data from BOOMERANG, WMAP, and Planck will help to constrain cosmological models quite a great deal more than they were when the paper was written (we now have the first year of WMAP data in the public domain, as well as that from BOOMERANG). Why? Because the data can be analysed to characterise both the foregrounds and CMB quite closely.
Maybe there is no correlation.
As for CME's (coronal mass ejections?) - maybe COBE et al weren't looking downwind at the CME's path, so there's no measurement one way or another? Did somebody actually try to do this during a CME?
There would be so much interference from the CME (as I understand from the aforementioned paper) that it would be a messy undertaking to subtract other CME artifacts from the observations.
The beautiful thing about COBE and WMAP (and maybe BOOMERANG) is that the data is all in the public domain! Anyone with a broadband connection can download the many MB to their own computers, write their own cleaning and analysis software, and so on.
Specifically, if you think there might be such a signal in the data, you can do your own analysis!
Re CMEs (yes): IIRC, the COBE papers did say there were some residuals which they felt could be accounted for by solar flares ... however, these were in the zodiacal light, and due to the dust being a little brighter at the time of flares.
However, I think your first step - on a path to show that the 'CMBR' is quite local - might be to describe a physical process (or processes) which could generate the right sort of microwaves.
Our local haze may prevent us from seeing more distant, and therefore less distinct, neighbor extrasolar hazes.
(speaking underwater) "Can you see any water over there a couple of Km away?"
"No, there's too much intervening water to know for sure."​
If we had no clear observations of distant microwave sources, this might be a reasonable counter; however, as the COBE maps show quite clearly, along the galactic plane, the signals in several microwave channels is dominated by galactic dust, synchrotron radiation, etc. Also, there are several radio sources - known to be galaxies (z < 0.5, IIRC) - which can be 'seen' in many of the CMBR experiments.
The universe is pretty transparent to microwaves :wink:
In my proposals, there could still be red shifts in the indicated directions; they would be from different causes (BH's, soups, etc.), not necessarily restricted to Big Bang theories.
Sorry I wasn't clear enough.
The CMBR dipole is interpreted as being motion of the solar system wrt the CMB. From the size and direction of the dipole, you can calculate how fast the solar system must be moving, and in what direction; it's several hundred km/sec. However, nearby MW stars appear to move with speeds of only ~km/sec, to ~tens of km/sec. So, if the CMBR were 'local' - nearby in the MW - all nearby stars would be moving quite fast wrt to it ... why?
If the CMBR were 'local' - in the Local Group, or nearby cluster or supercluster - why do we here in our solar system move with that velocity wrt to it?
Inferred is the operational word here. I'll bet it was fudged just enough to agree with the concordance model.
http://citebase.eprints.org/cgi-bin/citations?id=oai:arXiv.org:astro-ph/0306088 is an obvious example of concordance cosmological model fudging.
I'm not outright dismissing the results, but we have to be aware of the shadowy assumptions made to "make the data/theory fit".
I don't have a problem with this strategy, but I can't yet accept it as obvious fact either because of the fudging.
I think it's important to distinguish between cosmology models and observational data.
For the CMBR, the data are now very good, and with the second year of WMAP results expected out soon (and Planck in a few years' time), will be much better. In summary, the CMBR:
- has a near perfect black-body spectrum, T ~= 2.725 K
- has a dipole, of 0.00335 K
- has smaller-scale temperature fluctuations, <~0.0005K
- has a detailed angular power spectrum, observed to +/-% to l~several hundred
- has specific, well constrained polarisation characteristics.
Any theory - cosmological or otherwise - needs to account for the observational data.
As to whether the observations I referred to were 'fudged', I'll let you read the PR (it has a reference to the paper) - once you've done so, please tell us how you think the conclusion is fudged. http://www.eso.org/outreach/press-rel/pr-2000/pr-27-00.html
Help me here:
Black Body - An ideal body which would absorb all (and reflect none) of the radiation falling upon it. The spectral energy distribution of a black body is described by Planck's equation; the total rate of emission of radiant energy is proportional to the fourth power of the absolute temperature (Stefan-Boltzmann law).​
I don't understand the claim of the CMBR being a black body in the first place.
If we heat a black body and measure the total rate of emission radiation and it fits the law (as above), fine.
How does this relate to CMB being heated, and emission measurements being made in accordance with the law? Radiation being heated? By what? How? I don't understand what you mean. Dumb it down for me. :confused:
It's not that the CMBR *is* a black-body; it's that the observed spectrum of the CMBR is a black-body spectrum (i.e. 'described by Planck's equation').
IIRC, when the COBE results were announced, Smoot (or a co-worker) simply put up a slide like the one at the bottom of this page, with no comment ... the room broke into applause.
(in fact, the diagram is somewhat misleading; the error bars are smaller than the thickness of the line, not as big as the diamond-shaped data points! )
We have the same chance of understanding the universe's origins as cartoon characters having the understanding that they were drawn by an artist.
This may be so, but such speculation has nothing whatever to do with science
Yes it does, because it's a statement made by me based on my study of the physical world and its manifestations. Maybe not so with your science, Horatio.
When was the last time you created a Big Bang in the lab and witnessed/published the resulting isotropic CBR? Where's your fudge-free experimental data? :-p
I think mathematical theorems are fudge-free, as long as you accept the total set of axioms. :wink:
You, and everybody else, don't have any such experiments to relate, and that's why these grand concepts are in the realm of cosmology - nobody can and ever will know why these things are the way they are, because there will never be, and never can be, an experiment to prove them. It's too fundamental. I'm all for the continuation of observation/discussion about them, however, to improve upon their models.
So it comes down to what we each understand to be science ... how about: constructing theories and making observations and doing experiments, the theories which we keep are those which are a) internally consistent, b) consistent with theories that have passed experimental muster, and c) [the most important] consistent with observational and experimental results, within the theory's domain of applicability. In this sense, 'understanding' means little more than 'developing theories which fit the facts well'; one's interpretation of those theories is entirely beyond science itself. In this sense, cosmology is just a branch of science whose domain of applicability is the universe as a whole; cosmological theories are good if a) they are internally consistent, b) consistent with General Relativity (within its domain of experimentally verified applicability), and c) consistent with observational and experimental results.
Well, zforgetaboutit, your cosmology is thoroughly refuted by observational evidence. Nereid tried, but, failed to guide you in the right direction. It was clearly a waste of her time. While I am tempted to remark upon your specious arguments, I decline. Believe what you like, ignore whatever evidence you choose to ignore and make up your own version of reality. Apologies to all, but, I still think 'crap=crap'.
Well, first the paper declares
"Since the universe is expanding, it must have been denser in the past."
A follow-up post will explore this idea.
I believe this with as much conviction as earlier papers that confidently stated the universe is steady-state. Others said contracting.
Back then they also had observational evidence. Yes, science continuosly observes and attempts to construct ever-changing models which rationally predict behavior. That's good. But I just don't see any rationalization happening on the cosmological scale. Too many flip-flops.
So this, therefore, is the first sufficient fudge that turns me off. :smile:
I want to point out the analogy of visible light passing through water. Somebody measuring the blue wavelengths would say "water is transparent to light".
I would counter that with "yes, to a certain extent, but the red wavelengths are severely limited in the distance they travel before being absorbed".
So... maybe the microwaves from your mentioned radio sources can travel from there to here, but the CMBR-like ones are more distance limited before they are weakened below current detection. Or vice versa.
Is a plot of microwave "frequency attenuation in the typical interstellar vacuum" vs. distance, linear? "Typical" will have many interpretations, of course.
I would guess that the microwave frequencies that excite hydrogen would be weakened if they passed through sufficient clouds of hydrogen. Any current ideas about this?
Re COBE's maps of CMBR within particular viewing target regions, are they reproducible (within small limits) from day-to-day, or longer time-periods, ignoring CME's and other local phenomena?
Alas, I cannot comply because of the many resources I don't have, the least of which are mental. :-p
My intuition tells me that if dark matter exists, then CMBR might be caused by dark matter resonating due to
  • energies impinging it (dark matter)
  • energetic particles colliding with it
I find this proposal easier to accept, and simpler, than the universe having a beginning (or end).
No problem with that.
Wow - such jingoism from you. Is that a nice way to behave? You contributed nothing with your Cosmic Forum Posting Background fanboy noise.
Only daring speculation can lead us further, not accumulation of facts.
Albert Einstein
Letter to M. Besso, October 8 1952, Einstein, 1972
Apparently you feel you have the right to insult Einstein also.
I'm not here to refute anything.
My posts on this topic are not things I believe in - I'm just asking "have these alternatives been explored and dismissed?".
I certainly believe in the measurements cited, but not necessarily in the interpretations. I don't have any motivation to make sweeping statements.
Although I don't understand everything Neried writes, I sincerely appreciate the effort.
Anyways,
Cosmology-guiding = religion, and that is crap.
Cosmology-observation-stating = cool, and I embrace it.
http://www.yfiles.com/4th.htm quotes the velocity as being (just to mention a number)
  • In relation to the background heat of the Universe (our wall paper of the Universe for lack of a better term) called cosmic microwave background radiation (CBR) the Earth is moving at 872,400 Miles per Hour (~400 km/s)
This dipole you mention - is it the radio wave analogue to the doppler effect for light/sound? I don't know what you mean, yet.
I'm trying to imagine the resultant of all these motions and it's a necessarily complex path, like being on an amusement ride. If we wait a while, will the dipole observation look different, as we move aong the path?
I.E. While on an actual amusement ride, our perception of the frequency of a stationary static frequency tone emitter will change depending on exactly what part of the ride's path we are on. This may not pertain to your explanation, depending on what you mean by dipole.
Chronos said:
Wrong. Your 'static frequency emitter' only works in your reference frame.
My reference frame is the only one I care about.
'Dipole' in this case simply means 'has two poles' :smile: a hot pole and a cold pole - it's responsible for the 'yin/yang' appearance in the Aintoff projections - one part of the sky seems warmer, the other cooler, and the temperature varies between the two poles exactly as if the solar system were moving towards the warm pole at 369 km/sec (more details here). For comparison, http://astro.estec.esa.nl/Hipparcos/venice-proc/poster05_01.pdf shows that stars nearby move at speeds of ~km/sec to ~tens of km/sec wrt the solar system (so if you seek an explanation for the CMBR that is local, you have a huge difference in the apparent speeds of neaby objects!)
Well, you have the satellites' motions (wrt the Earth), the Earth's (wrt the solar system barycentre), the solar system (wrt SagA*, the MW centre, mostly galactic rotation), the MW wrt the centre of the Local Group; that centre wrt the CMBR! The first two are so well known that the data is analysed to remove these; the third has been directly detected (e.g. long-baseline radio interferometry using quasars), but would take millions of years to show up in the CMBR signal; the last two are estimated based on other data - even LBI would take millenia to detect directly!
Here's the whole of the para: "Since the universe is expanding, it must have been denser in the past. A particular prediction of the Big Bang theory is also that the temperature of the CMBR must have been higher at earlier times. However, although quite a few attempts have been made, no clear observational confirmation of this has been possible so far. In fact, the best observations until now have only been able to establish upper limits to the cosmic temperature at earlier epochs.[/color]"
So, what they are saying is IF the BB theory is right, THEN the CMBR must have been higher in the past ... and that's what they set out to look for, and that's what they found!
To repeat my challenge ... what 'fudge' was used in the observations?
But the point about science isn't what you, or I, or Hawking, or even Einstein believe; it's about how consistent is the good observational data with any theory? So, are you saying that the observational results aren't consistent with the BB theory? If so, why do you say that?
Well, that's OK, you're entitled to your own opinions :smile:
However, if you wish to discuss science, don't you agree that you need to do so within its accepted framework? And that this means testing all theories on the wrack of experiment and observation?
OK, I'd like you to do some work now ... take some time with google and read some papers ... find out what observations have been made in the relevant microwave bands (the range of frequencies is not small!), by what kinds of telescopes, with what sorts of results. Pay particular attention to what absorption and emission process have been hypothesised and observed, and what the limits are to these. (Hint: the universe is pretty much transparent to microwaves; several processes are known to attenuate them, and several emission ones are known e.g. synchrotron, dust)
Yes; read the many CMBR papers on observations since COBE, with particular attention to parts of those papers which discuss consistency with earlier observations.
Your intuition might be right :eek:
However, intuition is not science
Do you know of anyone who has made a proposal more or less in line with your intuition? Has such a paper been accepted for publication in a peer-reviewed journal? Have you worked out the details of your proposal (e.g. how those resonations give rise to a 2.73K black body spectrum, with a 369 km/sec dipole in the observed direction)?
You know, I personally find quantum mechanics downright spooky ... but no one has yet come up with an experiment which contradicts it! So, spooky-to-me or not, that seems to be the way the universe works :approve:
My motives are being misunderstood.
How about if you reconsider my postings as "Has anybody studied or proposed... (zforgetaboutit's musings)?"
When a prof suggests a research topic to the grad student, the grad student doesn't (usually) say "First you prove it then I'll consider it." or "That can't be right because nodbody else has published it."
Most of what I'm suggesting are directions in research for those who have the means to go down that road.
For no good reason one of the replies (not yours) was downright hostile.
I'll be in that forum soon to ask about first principles of QED. Of all the explanations I've read to justify the first steps - they don't seem right to me. I'm missing too much formal background to go with the flow. I hope to improve my understanding in the other QED forum.
Some of you can hardly wait. :zzz:
I don't have enough fundamental background to judge their hypotheses, that ended up agreeing with their observations.
It would be so interesting for me to participate in recreations of all the classic experiments, discussing results, so I could better know the backgrounds of today's physics.
If I had the financial means I would gladly spend the rest of my life doing that.
I continue...
Oops, sorry! :blushing:
Yes, I did misunderstand; the context of the sections here at PF has changed somewhat in the last month or so ... your good questions (if I may paraphrase, 'why is the CMBR considered to be a relict of the Big Bang? what foreground explanations have been ruled out and why?') deserve clear answers. If I may so however, sometimes I didn't fully understand some of those questions, rather interpreted some of them as "I've got an alternative proposal for the nature of the CMBR, it's {X}".
So, in a nutshell:
- AFAIK, no proposal other than that the CMBR is a highly redshifted 'image' of the surface of last scattering is consistent with the high quality observational data
- there are several well-understood foregrounds: the 'red tail' of thermal radiation from the solar system zodiacal light, 'free-free' emission, emission by (MW) galactic dust (both rotation - 'spinning' - and vibration), synchrotron emission, point sources (mostly beyond the MW), and the Suyaev-Zel'dovich effect (SZE)
- there are also some 'cosmological' footprints that are not 'just' the surface of last scattering, e.g. gravitational lensing of the CMBR, the late integrated Sachs-Wolfe effect, the Ostriker-Vishniac effect (aka 'the kinematic SZE'), and patchy re-ionisation
- AFAIK, all the 'well-understood' foregrounds have been unambiguously detected and well-characterised
- the Tegmark paper you provided a link to has a good discussion of each of these, as well as references to papers examining each in much more detail.
The SZE is a very interesting thing! I will do some digging to find what the status of the observational validation, in the microwave region. You will see there's an implication of the SZE for high energy cosmic rays - the inverse Compton scattering which give the microwave SZE footprint also produces high energy gammas (as also happens in supernova shockfronts) - in a few years' time (when CANGAROO and HESSI and VERITAS accumulate good data), and maybe after GLAST has been at work for a while, there should be independent data on the (distant) CMBR ... via UHE gammas!
This set of slides from COBE give a nice overview of how COBE worked, how foregrounds were measured and subtracted (and what they were), what the dipole is, etc.
Note that the microKelvin fluctuations detected by COBE may not all be 'real' - at that level the researchers could only be sure that there *were* statistically significant fluctuations in the (dipole-removed) residuals, of approximately the size and nature predicted by the [tex]\Lambda[/tex]CDM cosmological models. The later CMBR observations - MAXIMA, DASI, ACBAR, CBI, FIRS, BOOMERANG, WMAP - were of higher precision, so any particular fluctuation has now be clearly re-observed (usual caveats apply, e.g. angular resolution).
