Could SR not be built from only one postulate?
  • Level: Graduate
  • Thread starter guitarphysics
    Sr
122 replies · 21K views · last reply
Sugdub said:
it artificially injects an asymmetry in SR foundations.
What?!? You are certainly free to consider the invariance of c to be artificially injected, but it is patently a symmetry, not an asymmetry.
Sugdub said:
Since in the absence of gravitation SR must encompass all phenomena, this specific reference to the propagation of light in empty space is problematic insofar it artificially injects an asymmetry in SR foundations.
Not specifically into the SR foundations, but into the common framework in which both SR and pre-relativistic classical mechanics are defined. That framework admits two different groups of functions that describe a coordinate change from one inertial coordinate system to another. To choose the group is to choose the theory.
Edit: I wouldn't use the term "asymmetry" either. It's simply a choice of which symmetries to include in the theory.
Sugdub said:
What is missing is a different, more general, justification for the existence of an invariant speed c.
I don't think it can be some idea that can be arrived at purely by intellectual means. In the future, we may be able to think of this as a prediction made by some future theory. At the moment, I think we have to rely on experiments.
Sugdub said:
I suggested a way forward in #70 : a physics theory which excludes instantaneous actions at a distance necessarily imposes the existence of a finite maximum speed. True or False?
You will certainly have to limit your attention to some class of theories to make such an argument. If we focus on theories that use ##\mathbb R^4## as a model of space and time, and is consistent with (mathematical statements corresponding to) the principle of relativity, I suppose that your statement is true. But I don't think it's an improvement over the simple idea that we can use experiments to distinguish between the two possibilities.
Sugdub said:
What is your proposed justification for injecting a constant c in your equations? What role does it play?
The thing is, when we set out to find the group of functions that "translate" between inertial coordinate systems on ##\mathbb R^4##, that constant shows up without being "injected". You start out with several undetermined parameters, and then you find that you can get rid of all but one by using the principle of relativity and symmetry principles.
DaleSpam said:
When x doesn't change under y then x is a symmetry of y. The speed c is therefore a symmetry of inertial transforms.
Isn't it the other way around? When the Lagrangian doesn't change under translations, translations are a symmetry of the Lagrangian. I can't think of a reason to call the invariant lines (or the speed they represent) a symmetry.
Edit: I think it's OK to call the group of functions that change coordinates from one inertial coordinate system to another a symmetry group, since the presence of that group in the theory reflects invariance properties of spacetime. So each of those coordinate change functions (Galilean or Poincaré transformations) can be considered a "symmetry".
DaleSpam said:
Personally, I still don't understand your objection to the invariance of c. You said "not in the same sense" and then wandered off into permutations.
I am fine if you don't want to accept the invariance of c as a postulate, but your stated dissatisfaction with it just seems odd to me.
As fas as i know, it never works that way: from a methematical point of view a genuine symmetry is a transformation that let's the laws of physics unchanged even though it might either transform or not various objects that enter the equations. (BTW c is not a scalar field, it is just a fundamental constant, so the invariance of c is also not the same kind of staff as the invariance of a scalar field). For instance once you have admitted the existence of a constant c and thanks to that you have your lorentz transformation, then you can ask the question : are my equations of physics going to be invariant under this transformation, if yes, this is a symmetry.
But of course behind the maths there is also the physical meaning of this invariance : it means that there is no privileged speed in the universe, in the sense that if you make an experiment on a table at rest in frame A and do the same experiment on a table at rest in frame B you will get the same results whatever the relative speed of A and B .
And the physical requirement is even more fundamental than the mathematical one which is just one of its translations in the language of maths: for instance the physical requirement of isotropy is not only translated in the invariance mathematical requirement according to which the laws of physics should be invariant under rotations but is also used to establish the Lorentz tranformations themselves for instance when one demands that the lorentz contraction should be the same for a boost at speed -u and for a boost at speed u (may be this is not used in all derivations of the Lorentz transformations but in the books i have studied it was). In both mathematical requirements there is behind the same and unic physical idea that should remain clear : we don't want any privileged direction so we must treat all of them in the same way.
The permutation symmetry is a kind of generalisation of this : i want to treat x and ct in the same way in the transformation: the physical idea is thus the same as the idea behind any other well known symmetry though the mathematical translation (invariance under permutation) is here a bit unusual.
c is not a priori a constant and it might be transformed into another c' in a boost: thus (x,ct) transforms (x',c't'). At the beginning we don't know what is the meaning of c and c' but we know these should be there because one cannot add time and space coordinates, thus c and c' at the beginning should merely be considered as conversion factors. But if i demand an invariance under permutation then the most general form of the boost that was:
x' =b_11 x + b_12 ct
c't' = b_21 x + b_22 ct
now must be
x' =b_1 x + b_2 ct
c't' = b_2 x + b_1 ct
and then i can derive c=c' and at the same time the usual values of b_1 and b_2 it's quite straightforward if i didnt make any mistake.
I certainly could have it backwards. In any case, you have an operation and a thing which remains unchanged under the operation. Whether you use the word "symmetry" to refer to the thing or the operation or both together doesn't change the facts.
For geometric figures we speak of lines of symmetry quite often.
That is way overly restrictive. I don't know why a "mathematical point of view" would reference "the laws of physics" at all.
Mathematically, a circle has rotational symmetry regardless of any laws of physics. Physically, a disk is axisymmetric even though none of the laws of physics are.
In any case, I have no objection to your rejection of the second postulate, even though I think your stated reason is odd. In my opinion, you don't even need a reason, you can reject it on a whim or a dare if you like.
But , i was trying to explain exactly the same thing, please read again my previous message where i explain that a symmetry is actually more a physical idea which can have many possible translations in maths.
The real issue is that the constancy of c as a principle has nothing to do with a symmetry principle, physically speaking, though mathematically we might be illusioned by the fact that indeed there is a transformation and some thing invariant (c) under this transformation.
Again, since we don't see behind the constancy of c, the physical idea that is the genuine characteristic of a symmetry (no privileged staff) , it's not , physically speaking, a symmetry!
I's not a symmetry but it can be derived from a symmetry : permutation invariance because the requirement is then to treat x and ct in the same way (no privileged staff)
Frankly, I think this is nonsense. We use math in physics in order to make sure that our theory is logical. It is not illusion, it is logic. There is a transformation and something is invariant under it. Logically, that is a symmetry.
If you don't like the second postulate, that is fine, but saying that it isn't a symmetry is absurd as is saying that mathematical conclusions are illusion.
ok, if you are not impressed by my rationnal arguments , i might just remind you that you will hardly find any textbook in relativity saying that the constancy of c is a symmetry principle. And most of the time this is the reason why many people have tried to axiomatized SR just in the hope of avoiding the arbitrariness of demanding from the beginning a constant c: some of them will make use of causality principles (to avoid action at a distance) for instance and exclude the galilean option ... it remains that i don't know many physicist which feel really confortable with the second principle of SR: most of them will just say: ok it's disturbing but the principles of physics are totally arbitrary after all: it's just experimental results that imposes us the principles, and we have to accept them wether we like them or not... (this is not my way of thinking as you may have understood)
DaleSpam said:
I also like Robertson's approach of just making a general theory and letting experiment determine the parameters.
Me too (as you probably guessed). But I have not seen Robertson's treatment. Where can I find it?
This thread is really interesting and helpful (for me at least). I said the reference to a specific set of phenomena, namely the propagation of light in the empty space, creates an asymmetry in SR foundations because it is peculiar whereas the theory embraces all kinds of phenomena. So it is not the invariance of a parameter named c which is problematic, it is the definition of c as the speed of light. This is why I think that only a more general justification for the existence of an invariant speed could remove this asymmetry. Then experiments would show that the speed of light is close or equal to c.
I completely agree on both points (although I'm not really sure what you meant with the "embraces all kinds of phenomena part")- yes, the thread is very interesting and helps a lot! And also, yeah- I think that what's special about c isn't specifically about the speed of light; it's that c is the constant that keeps the spacetime interval invariant. That is, that -(ct)^2+x^2+y^2+z^2 is invariant because of that special number c. I think it's a lot nicer to start from there and, if you want, deduce that the speed c must be constant in all reference frames- instead of the usual approach, I think that more could be gained from beginning by talking about the geometry of flat spacetime and then going on to talk about consequences like the constant speed of light.
guitarphysics said:
I[...] it's that c is the constant that keeps the spacetime interval invariant. That is, that -(ct)^2+x^2+y^2+z^2 is invariant because of that special number c.
It isn't invariant "because of c". In that context, c is just a dimension-conversion quantity so that the sum makes sense. (You can't meaningfully add apples and oranges.)
I think it's a lot nicer to start from there and, if you want, deduce that the speed c must be constant in all reference frames instead of the usual approach, I think that more could be gained from beginning by talking about the geometry of flat spacetime and then going on to talk about consequences like the constant speed of light.
There are textbooks that do start from an assumption of Minkowski spacetime. But in doing so, one magically assumes that the interval ##-(ct)^2+x^2+y^2+z^2## is invariant -- which then necessarily implies the Lorentz group. Such an approach is probably preferred by mathematicians, but I find it doesn't give much physical insight into the foundations.
I'm not a mathematician, but I'm more math-nerdy than most. I find that approach vastly superior when we only want to define SR and see what it says about the world. Those other things that we like to discuss are still interesting, for at least two reasons:
1. If we allow ourselves to make many assumptions along the way, the argument shows how a person who doesn't know SR already can discover SR through clever guesses, and some input from experiments (including the invariance of c).
2. If we take a fixed set of assumptions as the starting point of a rigorous proof, we see that there's no significant difference between SR and pre-relativistic classical mechanics other than the group of functions that change coordinates from one global inertial coordinate system to another. We also see that these are the only two theories that are consistent with the assumptions.
So 1 tells you something about how the theory was found, and 2 gives you some insight into what theories can be defined. I think this is good stuff, but one can argue that this is "just history and philosophy", and not SR at all.
I prefer that approach because I like the analogy that it makes with the invariance of distance in Euclidean space (not really because of any mathematical reason- as I think I mentioned, I don't know much algebra so it's not very significant to me that there's a Lorentz group). I find it more appealing to say that spacetime distance is invariant rather than that there's a specific speed which is the same in all inertial frames. Also, thinking along those lines is a more logical way to proceed into GR, I think (from the little that I've looked into the subject).
Oh, and I misspoke (misswrote?). When I said "because of c" I meant essentially what you said- that there exists a conversion factor we can use for time to put it into the same units as length in space. The sum of "apples and oranges" turns into a sum of just "apples" thanks to c, is basically what I was trying to say.
EDIT: Just wanted to add- I think the reason I prefer starting from an "invariant interval" point of view is that it emphasizes that SR is a geometrical theory from the get-go.
Note that Galilean relativity has two invariant intervals instead of one. Having done a general abstract derivation from POR, isotropy, homogeneity you get that you have a choice of two geometric structures:
1) invariant time + invariant Euclidean distance.
or
2) invariant spacetime interval (equivalent to some invariant speed which would be labeled c).
I still have not seen a single convincing argument for choosing one over the other except experiment. It is, for example, false that (1) requires action at a distance. Newton's gravitation is a specific theory in the framework of (1), and was chosen not because it was forced by this structure but to match the observation that orbits had high stability. GR had an issue of replicating the appearance of instant action at a distance required for orbital stability while having a propagation speed that was too slow by orders of magnitude. This difficulty GR had matching observation (and the solution) are well explained in the classic paper by Steven Carlip: http://arxiv.org/abs/gr-qc/9909087.
[Edit: one statement you could make about this is that gravitational observations falsified SR and were more consistent with Newtonian physics, especially given the modern understanding that a satisfactory SR theory of gravitation that matches observation as well as Newtonian theory is impossible. Thus, you can say EM experiments favored SR, gravitational experiments favored Newtonian physics, and it took GR (general relativity) to successfully encompass all classical observations.]
Ah, yes, now I understand your point, and agree. I prefer to call c the "invariant speed" rather than the "speed of light" for that very reason.
You will also hardly find any textbook explicitly stating that the invariance of c is not a symmetry, even if they don't choose to use it as a postulate or an axiom.
Hmm, my impression is somewhat different as to the motives. Generally, the desire to axiomatize SR (or indeed any theory) is to set up a formal mathematical framework from which mathematical predictions can be formally derived. Einstein's 1905 derivation is clearly informal, and the postulates themselves are not formal mathematical axioms from which anything can be derived without some "translation" into formal terms.
Again, my impression is somewhat different.
DaleSpam said:
Robertson's "Postulate versus Observation in the Special Theory of Relativity" is here:
http://authors.library.caltech.edu/11476/1/ROBrmp49.pdf
Thank you!
[Edit]... after reading it...
Hmm, it turned out to be rather different than I expected...
Robertson's postulates/assumptions/restrictions seem to be:
P1) There exists a reference frame ##\Sigma## in which light is propagated rectilinearly and isotropically in free space with constant speed ##c##.
P2) The physical geometry of 3-space, as revealed by measuring rods, is Euclidean.
P3) All clocks at rest in ##\Sigma## are synchronized.
P4) The velocity of light in free space is independent of the motion of its source.
P5) There exists a reference frame ##S## which is moving with an arbitrary constant velocity of magnitude ##|v|<c## with respect to ##\Sigma##.
P6) The physical geometry of 3-space in ##S##, revealed by the same meaurement techniques as above, is also Euclidean.
(No assumption is made about the speed of light in ##S## -- that is derived.)
P7) The transformation between coordinates in ##\Sigma## and ##S## has only ##v^i## as its essential parameter, and ##v^i=0## corresponds to the identity.
P8) The considerations are confined to laboratory--scale experiments, hence only in a small spacetime neighborhood, hence only a transformation between infinitesimal differentials is considered, therefore the transformation is taken to be linear.
(Some coefficients of the transformations are reduced using a radar method to perform clock synchronization.)
P9) The 1-way velocity of light is independent of direction. Probably this follows from (P1).
He then appeals to the Michelson-Morley and Kennedy-Thordike experiments to reduce the possibilities further, followed by a further appeal to the Ives-Stilwell experiment.
He doesn't seem to make much (any?) use of the group multiplication property.
All in all, at the point before he starts appealing to experiments he seems to be quite a long way from the most-general set of possibilities.
Fredrik said:
... You will certainly have to limit your attention to some class of theories to make such an argument. If we focus on theories that use ##\mathbb R^4## as a model of space and time, and is consistent with (mathematical statements corresponding to) the principle of relativity, I suppose that your statement is true. But I don't think it's an improvement over the simple idea that we can use experiments to distinguish between the two possibilities...
Thanks for challenging my views. In this thread we are looking at the simplest set of preliminary hypotheses/statements/postulates which necessarily impose the Lorentz transformation of the R4-coordinates of a physical event in response to a change of the inertial frame of reference into which this event gets described/recorded.
First I can't see in which way the “focus on theories that use R4 as a model of space and time” could be seen as a reduction in generality or a “limit” to our attention: it is intrinsic to the pattern of the problem at stake.
Second, if the set of preliminary statements leaves open two potential solutions (the Lorentz or the galilean transformation), this shows that further constraints must be added at the forefront in order to reduce the range of potential solutions and derive the Lorentz transformation as the sole but necessary outcome. Invoking some “experiments to distinguish between the two possibilities” is just the same as stating that we haven't so far produced a satisfactory answer. Indeed we know that some experiments (e.g. the decay of muons across the atmosphere) confirm that SR leads to better predictions than the Newtonian mechanics, but this only underlines the importance of resolving the problem at stake.
Third, it is clear that the addition of a constraint like “no instantaneous action at a distance”, because it implies the existence of a maximum speed limit, resolves the problem at stake. Einstein made his second postulate specific to the propagation of light, but his formal derivation would of course work as well with the more upstream constraint I proposed.
Finally, is this “an improvement over the simple idea that we can use experiments to distinguish between the two possibilities”? I can understand your doubts insofar the replacement of a postulate about the world (the speed of light is finite and invariant) with another postulate about the world (there exists an invariant finite speed for any action inside the world) does not bring much. Eventually we don't know anything about the world (how it is, how it works, what happens there) and it is illusory to believe that experiments will ever bring any knowledge of that kind. Any postulate about the world is merely speculative, its content cannot be certified. Postulates about the world cannot root SR (or any other physics theory) into solid ground.
Conversely the key added value of my approach is that the existence of a maximum invariant speed is NOT derived from a statement about the world and moreover it is NOT a postulate. It is a true statement reflecting a fact that all physicists agree upon: our physics theories are based on a causal paradigm which excludes instantaneous actions at a distance. It is this change of perspective which makes the difference, replacing the usual metaphysical approach based on postulates about the world with a pragmatic approach based on true factual statements about the concept of causality which guides the development of our physics theories. Because the existence of the maximum speed limit is integrated (upstream to the consideration of any external phenomenon) into the very structure of the formal space-time framework used to record physical events, SR ensures that the exclusion of instantaneous actions at a distance is enshrined into the theory.
My (somewhat challenging) conclusion is therefore that the second postulate of SR, dealing with the invariance of the speed of light, should be dropped and replaced with a true factual statement: our physics theories exclude a priori any kind of instantaneous action at a distance. Overall I suggest that both SR postulates could and should be dropped because they propagate the illusion that we know something about the world, to the benefit of true, factual statements about the pragmatic constraints that must be met by any proper physics theory.
You keep ignoring the fact that Galilean relativity, per se, does not require instant action at a distance. Instead, to reject it you need the much more specific postulate of an invariant speed, which seems no more natural than the invariant times that comes with Galilean relativity.
You also haven't commented on the point I made (with references) that Gravity (a specific theory, not a required feature of Galilean relativity) made the global symmetries of SR somewhat stillborn, in that it provided apparent experimental support for essentially instant action at a distance (> 1010 c ). Thus, in fact, the global symmetries of SR do not exist in our world. This makes it particularly hard to sustain that it is uniquely natural, but also false (in the precise sense that its symmetries are local, or exist only in the tangent space at an event).
There are theories that don't use ##\mathbb R^4## as the model of space and time. GR uses a smooth manifold, which bears a number of relationships with ##\mathbb R^4## (in particular, it's locally homeomorphic to ##\mathbb R^4##), but it isn't ##\mathbb R^4##. And GR is a better theory than any of the ones we find.
You could also loosen up the constraints and find a vastly superior theory: general relativity.
It seems that what you would consider a satisfactory answer is a perfect theory that can be found just by thinking.
The pre-relativistic spacetime doesn't imply that there's action at a distance. It just allows us to define such theories. SR doesn't allow it (unless we drop the principle of relativity and introduce a preferred coordinate system). But if this is a reason to dismiss the pre-relativistic framework, then we have gone from having a "not so great" theory of gravity (Newton's) to having no theory of gravity*. It's far from obvious that this is a step in the right direction.
*) I know almost nothing about attempts to define a theory of gravity in Minkowski spacetime. This probably means that such attempts haven't been very successful. I have a feeling that if there was a good theory of gravity in this framework, then it would be taught in SR classes and books.
I don't agree that it can't bring us any knowledge of that kind. It already has. We know that Earth is in an approximately elliptical orbit around the Sun for example. But I would say that in many situations, in particular most situations where quantum mechanics is needed, it would be naive to think that the theory (or the experiments that test the accuracy of its predictions) is telling us what's "actually happening" to the system between state preparation and measurement.
However, the fact that the scientific method can't tell us everything that we would want to know, doesn't change the fact that it's the best we've got, and ever will have. It's vastly superior to the method of "just thinking".
Sugdub said:
...the existence of a maximum invariant speed is NOT derived from a statement about the world and moreover it is NOT a postulate. It is a true statement reflecting a fact that all physicists agree upon: our physics theories are based on a causal paradigm which excludes instantaneous actions at a distance.
I agree with the stuff before the colon. But the only things that should be regarded as facts in physics are experimental results. So what I would have said after the colon is that SR makes better predictions about the results of experiments (when gravity is irrelevant).
I don't see a reason to consider "no instantaneous action at a distance" anything more than an assumption.
DaleSpam said:
You should probably actually read the chapter. It involves much more than 1 principle. I think it is 5 or so.
It does. But like a lot of this stuff one can base it on a key principle, namely in this case the POR, and the other ones are so obvious you don't actually state them - they are there all right - but its elegance is such you don't notice them.
Check out the following using that approach:
http://www2.physics.umd.edu/~yakovenk/teaching/Lorentz.pdf
It's an interesting exercise going through it and seeing what the hidden assumptions are :smile::smile::smile::smile:.
Read the chapter, then go through the proof to see what's going on.
BTW this isn't the only area this sort of thing happens in. I often post a rather interesting derivation of Maxwell's Equations from Coulombs law and SR. It's beautiful and elegant. I love it.
http://www.cse.secs.oakland.edu/haskell/SpecialRelativity.htm
But evidently in his book on EM Jackson thinks such proofs are silly because they always involve hidden assumptions, you may as well simply state them to begin with ie Maxwell's equations. I took that as a challenge to find the hidden assumption in that derivation above. I did manage to find it, can't recall off the top of my head what it was, but its there. I think in relation to this type of thing we have guys like me that like beauty and elegance such that hidden assumptions are so compelling and obvious you much prefer it done that way. And we have others for whom an assumption is an assumption.
Thanks
Bill
True, but please remember it in context. This was in the 1940's. I believe that he was the first one looking in this direction, and his intent was not to find the most-general set of possibilities, but simply to avoid the usual two postulates with a benign set of assumptions and experiment.
bhobba said:
But evidently in his book on EM Jackson thinks such proofs are silly because they always involve hidden assumptions, you may as well simply state them to begin with ie Maxwell's equations. ... I think in relation to this type of thing we have guys like me that like beauty and elegance such that hidden assumptions are so compelling and obvious you much prefer it done that way. And we have others for whom an assumption is an assumption.
I am probably more in the latter camp. I can appreciate beauty and elegance, but there is no reason to expect the universe to be either beautiful or elegant. Plus I have seen too many crackpots obsessed with the beauty of their own creation. That is kind of why I prefer the general theory -> experiment approach. It puts a reality-check in fairly early.
For me, everything else is useful primarily for a mnemonic device, to help you apply the theory correctly to analyzing a given scenario. In that sense, the original two postulates are quite useful, as are the symmetry principles.
If I remember correctly, Jackson explicitly shows an alternative relativistic force law that reduces to Coulomb's Law in the nonrelativistic limit, but isn't the same as Maxwell's equations. I don't remember what that was.
I guess that charge could be a Lorentz scalar, instead of a component of a 4-vector.
Well, the point of Einstein's original derivation was not really to come up with the most general derivation. Instead, he had a number of things that had plenty of experimental support, but couldn't all be true simultaneously:
  1. Newton's equations of motion.
  2. Maxwell's equations (specifically, the prediction of the constancy of the speed of light).
  3. The principle of relativity (that there is no preferred reference frame).
Einstein's goal was to find a replacement for Newton's laws that was compatible with relativity and the constancy of the speed of light.
Charge density is the time-like component of the current 4-vector and charge is a Lorentz scalar. Charge is defined as the integral of the charge density over a space-like hypersurface. The proof that charge is a Lorentz scalar is actually quite simple, given the 4-divergence of the current 4-vector. It's basically just an application of Stokes' theorem.
