Could the polynomials p(x) exist?
  • Context: Graduate
  • Thread starter Thread starter jonas.hall
    Polynomials
The discussion revolves around the existence of polynomials p(x) that satisfy the equation p(x)^2 - 1 = p(x^2 + 1) for all x. Participants explore various approaches to prove or disprove the existence of such polynomials, including specific cases, derivative evaluations, and numerical checks.
  • One participant suggests that the only solutions found so far are the constants p(x) = 1.618... and p(x) = -0.618..., verified through computational software up to a certain polynomial order.
  • Another participant proposes a transformation of the original equation into a form involving iterative mappings of polynomials, hinting at the potential complexity of the relationship between the polynomials and Julia sets.
  • A third participant sketches a method to show that at a specific root of a quadratic equation, the polynomial must take on certain values, which aligns with the previously found constant solutions but does not confirm exclusivity.
  • One participant points out an error in the reasoning of another, specifically regarding the existence of real solutions to a derived equation, and mentions the need for further exploration of derivatives at specific points.
  • Another suggestion involves expressing p(x) as a power series and comparing coefficients to demonstrate that all coefficients beyond a certain point must be zero, although the feasibility of this approach is questioned.
  • A participant expresses uncertainty about the inductive proof suggested and considers starting from a different assumption regarding polynomial terms.
Participants generally agree that the constant solutions are valid but do not reach a consensus on whether these are the only solutions. Multiple competing views and approaches remain, with some participants expressing skepticism about the existence of non-constant solutions.
Some participants note that certain assumptions or steps in the reasoning may be flawed or incomplete, particularly regarding the evaluation of derivatives and the implications of specific polynomial forms. The discussion reflects a complex interplay of mathematical reasoning without definitive conclusions.
Readers interested in polynomial equations, mathematical proofs, and the exploration of iterative mappings in complex analysis may find this discussion relevant.
jonas.hall
Are there any ploynomials p(x) such that
p(x)^2 -1 = p(x^2+1) for all x?
To cut it short: With CAS software I have verified that there are no solutions except p(x) = 1.618... and p(x) = -0.618... (constants) up to order 53 or so, but I have to prove this (or find the other solutions).
For example: If I assume p(x) is fourth order p(x) = c4x^4 + c3x^3 + ... + c0 and put this into the above relation I get two new polynomials that must be equal for all x, so I identify terms and put equal terms equal to get an equation system like the following:
8: c4^2 = c4
7: 2c4c3 = 0
6: c3^2 + 2c4c2 = 4c4 + c3
5: 2c4c1 + 2c3c1 = 0
4: c2^2 + 2c4c0 + 2c3c1 = 6c4 + 3c3 + c2
3: 2c3c0 + 2c2c1 = 0
2: c1^2 + 2c2c0 = 4c4 + 3c3 + 2c2 + c1
1: 2c1c0 = 0
0: c0^2 - 1 = c4 + c3 + c2 + c1 + c0
(Notice how the right hand coefficients are elements in Pascals triangle?)
Now to solve this we start from the top. The only solution is c4=1 och c4=0 but this would not make a 4th degree polynomial and so we disallow this since we presumably already has handled this case. So we set c4 = 0. Then the following 4 equations are such that they allow for the solution of one coefficient at a time. Thus c3 = 0, c2 = 2, c1 = 0 and c0 = 2.
All odd coefficients can be proven to be = 0.
Then we are left with equations 3 down to 0 that also have to be satisfied to produce a valid solution. Surprisingly, everyone but the last sometimes are. If the order of the polynomial is 2^n (2, 4, 8, 16...) then they are. Why? No idea!
The last equation is a special case however. It can be written as
c0^2 - 1 = c0 + S where S is the sum of all coefficients except for c0.
Now all c from c4 and down to c1 are obviously rational. Unfortunately the last equation DO have rational solutions for some (infinitly many) values of S so I can't prove there are no more solutions this way.
I have tried looking at the roots of the polynomial but this doesn't seem to yield much at all. I have various semi-interesting results like
p(0) = c0
p(1) = p(0)^2 - 1 = c0^2 - 1
p(2) = p(1)^2 - 1 = c0^4 - 2c0^2
p(5) = p(2)^2 - 1 = c0^8 - 4c0^6 + 4c0^4 -1
etc (and yes, the 5 is correct)
...but none of this seems to bring me closer to closing the case. I might also add that the numerical discrepancy between the rational value of c0 given by the first equations and the irrational value given by the last equation diminishes steadily for all n-th order polynomials where n = 2^j (j integer) as n increases so it is by no means obvious that a 64th or perhaps a 256th order polynomial will fail.
So I guess I need some help to prove that no solutions exist, alternatively find the rest of them, wherever they may lurk.
Anyone fancy giving some help?
Mathematics news on Phys.org
I expect that there is no solution, but don't immediately see an easy proof.
Set f(x)=x^2+1 and g(x)=x^2-1, so your equation reads g(p(x))=p(f(x)). You can iterate this to get g^np(x)=pf^n(x).
So, the sequence f^n(x) goes to infinity if and only if g^n(p(x)) goes to infinity, and p gives a map from the http://en.wikipedia.org/wiki/Julia_set" for c=1 onto the julia set for c=-1. I'd have to search about on google, but I expect that those two Julia sets have very different properties and can't be related by a d to 1 map, such as a polynomial.
This is a sketch of how I think you can prove that the only possible p(x) are the two constant solutions. There are some important details missing at the end.
Let c be one of the roots of x^2 - x + 1 = 0.
Let's see what happens at x=c in p(x)^2-1 = p(x^2+1).
p(c)^2 -1 = p(c^2+1), but c^2+1=c.
p(c)^2 -1 = p(c)
Now solve for p(c)
p(c) = 1/2 ± Sqrt[5]/2
The value of p(c) is consistent with the constant solutions you've already found. But are those the only solutions? All I've shown is that at point c the value of p(c) must be one of 1/2 ± Sqrt[5]/2.
Let's take the derivative of each side of the original equation.
d/dx (p(x)^2 -1) = d/dx p(x^2+1)
2p(x)p'(x) = 2x p'(x^2+1)
Let's see what happens to p'(x) at x=c.
2p(c) p'(c) = 2c p'(c^2+1)
p(c) p'(c) = c p'(c)
But p(c)!=c, so p'(c)=0.
Which is also consistent with your constant solutions.
In order to prove that the only possible p(x) are the constant solutions, you would have to show that then nth derivative at p(c) is zero for all n>1.
If you know that the first to (n-1)th derivatives are zero at c, I believe that you can show that the nth derivative at c is zero. I'm not sure how to generalize the steps to show this.
Thanks for both answers - they gave me clues I can work on but unfortunately MrJB has done some mistakes. The equation x^2 + 1 = x has no real solutions so a large part of the reasoning fails. If one evaluate the derivatives at x=0 however some progress can be made but every even derivative is = 0 only if another one is = 0 at x=1 so for instance D^4(p) = 0 at x=0 only if D^2(p) = 0 at x=1. Annoying. As for the julia sets I'll have to read up on them but thanks for the tips.
Any other suggestions?
Have you tried writing
p(x) = \sum_{k=0}^N a_kx^k
and then putting this into your equation? You will have to find a new series that is the square of this series, but that's doable. Then simply compare the coefficients, and you ought to be able to show by induction that a_k = 0 for all k > 0.
I can try... but I'm not sure I'm up to showing by induction something I can't show i the special cases. Though maybe you're saying: I have started by assuming the highest order term = 1, instead I should start by the lowest term? I'll think about it anyway.
  • · Replies 48 ·
