Could Time Be Conceptualized as a String?
  • Level: Graduate
  • Thread starter Thread starter petm1
    String Time
47 replies · 13K views
vld said:
Are you sure this is always the case? Of course, we have to parameterise our models. But the notion of the idealised time is completely gone, e.g., in GR, where the evolution of manifolds is represented "statically", since time is put almost on the same footing as space (as Zapper noticed). Everything is measured by using just distance (no time). Equally one can use time or speed (that of light), as I was proposing.
Can you tell me how you are able to "measure" space without invoking ANY time? How are you able to know the distance between 2 points in space, a question that I had asked earlier to another person who made a similar point, but never gotten a reply? Before you pull out a measuring stick, consider a series of implicit assumption that you had to make to use such a thing.
Zz.
Ah, here I have two comments :
(a) first, we do not know the beables of GR (although some proposals are under construction); a problem which is very similar to the indeterminism present in the gauge field theoretic formulation of -say- electromagnetism. In the latter case for example, people have found underlying, fully deterministic, theories which reproduce the usual formulation as a low energy effective approximation. So, diffeomorphism invariance could be an emergent phenomenon.
(b) second, GR does contain time in its formulation : you still need coordinates (t,x) to formulate the theory, it is just that no particular coordinate system has an OBSERVATIONAL significance. But neither has the absolute time I was speaking about before in special relativity. Furthermore, since the 30 ties it is well known that one can reformulate GR as a theory of scattering gravitons in a Minkowski background (so the geometrical interpretation isn't necessary at all).
When a theory has excess bagage, we can take two attitudes :
(a) either these hidden variables exist and we have to reformulate the theory with respect to them (GR as a particle theory in a fixed background)
(b) they don't exist and we have to find a formulation which eliminates them.
Now if you say that coordinates are in the category (b), then GR, as it stands now, determines only an evolution in terms of the clock time associated to one observer. But clock time is itself an observable, which we agreed to be associated to a periodic motion in space which again requires an auxilliary notion of time and space. Hence, we are again at our starting point : find a deterministic theory for which GR is an effective approximation !
What the rest of your comments are concerned : the speed of light is not a fundamental but emergent quantity (you are kind of forced to do this if you want to save realism and accept QM).
ZapperZ said:
The FACT that C, P, and T stand TOGETHER implies that you simply cannot downgrade T. Yet, you attempt to do just that.
You seem to be missing the whole point of what you are doing here. If you try to do something to "time", why are you ignoring the fact that in physics, "space" and "motion" ALSO follow along. If time is an "illusion", then so is space. I really do not understand why time would be any more special, or any less fundamental, than "space", especially when they are inseparable.
In condensed matter physics, there is a whole series of phenomena that is characterized broken time reversal symmetry. This is where such broken symmetry signifies the onset of a particular transition. Unconventional superconductors such as high-Tc superconductors are one such system. Several "ladder magnets" are also characterized by such symmetry. In other words, the time component is an essential ingredient in the description of such system, and nothing else will do. Such a description is as fundamental as describing broken spatial symmetry when water turns into ice.
I see that you are talking about a mathematical (model/theoretical/languistical) concept of time because in the CPT-theorem C, P and T do not stand together for charge, parity and time but rather for charge-reversal, mirror-reflection and time-reversal, which is not the same. These are mathematical operations needed for modelling but which do not actually occur in nature. The examples you give are all related (as you have correctly mentioned) to time irreversibility which is not a problem. However, anisotropy of time is the property making it distinct from space.
ZapperZ said:
This is not an argument of making "time" to be special. This is an argument on why you are picking on time when space and charge and others are part of the mob also! I have presented several aspects in which time is essential in these description. You have shown nothing in which one could make do without, or discard, time while still preserving the complete description.
Your examples are irrelevant here. Yes, the concepts of space, and charge are also part of the mob, but this thread was about time and motion. Time is, indeed, a special case, at least, by being anisotropic, which is worth while discussing and exploring. My example was about a system whose motion is FULLY described by a trajectory in the phase space (x,p). The coordinate x IS NOT time; momentum p IS NOT time. If you prefer describing the radioactive decay in terms of tunneling, this kind of motion can be described through energies and probabilities, neither identified directly with the notion of time (although related to it). For better understanding of these motions we need an auxiliar parameter. In many cases it is suffice to simply use this parameter without thinking about any deeper implications, which does not necessarily mean that we have arrived at the complete description of physical reality. If you perceive these arguments as my intention to say that time is "illusion", your are wrong. This is not an illusion, this is an entity needed to be studied since we do not know enough about it.
I know what those operations are. And what does it mean by "These are mathematical operations needed for modelling but which do not actually occur in nature"? I could say the same with your "mathematical modeling".
Remember, I brought this point not because I want to discuss what they are, but rather to point out to you that the time operation is as "fundamental" as both C and P. Remember, YOU were the one who said that time being "... in the human mind as a reflection of periodic motion.." My counter argument is, if time is nothing more than that, then so is space, and so is charge, since time symmetry operation has the same status of importance to parity and charge conjugation operations. You continue to try to tell me what these operations are, but refuse to see that they all have the same "status" of importance.
Not only that, there's nothing in neutron decay, kaon decay, etc... etc.. that indicate an internal "periodic motion". I can easily point to these particle as showing that they are "aware" about time, unless you want to speculate that they have a "mind".
But p is a TIME RATE OF CHANGE! How could it not appearing explicitly somehow implies that it isn't fundamental or needed? That is like saying when I solve the hydrogen atom wavefunction, I make the change of variable of u(r)=rR(r), and therefore, the actual radial wavefunction R(r) is not longer relevant or fundamental. Try solving it if it doesn't exist! For some odd reason, you seem to be ignoring (among other things) the fundamental formalism of the calculus of variation that ALLOWED you to solve the dynamics of a system using only x and p as the canonical variables.
I didn't. You did. You were the one who brought up tunneling of alpha particle. I mentioned Radioactivity in GENERAL and especially the decay of many particles, especially those found in high energy experiments. And for the arguments that tunneling isn't directly related to time, look at the actual formalism of tunneling beyond just what you get in intro QM text and tell me what the Fermi Golden Rule actually is and why it is relevant to tunneling processes, especially in calculating the tunneling matrix element. So not only is time "related" to tunneling, it is a fundamental part of this process.
First you call it as a construction of the "human mind", as if everything else isn't. Then you tell me that operations such as C, P, and T are "... mathematical operations needed for modelling but which do not actually occur in nature..." And now you tell me that my argument that you think that time is an illusion is wrong? HELLO?
I also put it to you that we don't know what "space" is (I notice that you never reply to my question on how one can actually MEASURE space without invoking the concept of time). Thus my question to you on why is time the only thing we seem to question here when its sister is also in the same boat! I have given you all those examples (and I know that they are relevant here) simply to indicate that in many of these phenomena, the time symmetry (or lack thereof) IS a fundamental description of them as much as the spatial symmetry is important for others. Should we study more about the idea of time? Sure! But don't pick on it while you ignore the same problem with other quantities as if they don't exist.
Zz.
You can measure space through motion. As an example, take a sphere and measure its Gaussian curvature in a point by applying the standard differential geometry procedure (i.e. by moving along a loop around the point). You can implement this operation instantly or (not being in rush) consuming an infinite amount of time. Therefore this measurement is time-independent but as a result you have measured the distance between two opposite points of your sphere (its diameter).
So in other words, if we dump Special Relativity completely, we can implement this instantaneously, and you won't need any time?
Zz.
Please, don't slant. Take the infinite amount of time if you want.
Please don't use a frame-up! Here are your own words:
ZapperZ said:
Come again? Alpha decay can be described as a tunneling process that is independent of any oscillatory motion of the nucleus consituents. In other words, even when they do not move, they will still tunnel through.
Incidentally, from these words I deduce that you don't consider tunneling as one of
the forms of motion.
But that is what I don't understand. The motion takes TIME, and you are essentially measuring the displacement. I could put a measuring tape along the path and achieve the same thing, no? If not, how are you to know how far you have moved? So how did I know what the length is? Did I just assumed some "simultaneous" event on the front and back of the measuring tape that allowed me to know of such a thing? Did Einstein went out of his mind by insisting on the use of light as a measuring device for both space AND time?
I would like to see you publish this in, let's say, AJP and see if you can argue that such a measuring process requires NO involvement of any time at all in your measuring device.
Zz.
I take that back. I meant that you were the one who brought up alpha particle as being THE representation of radioactive decay. One such process attributes this to tunneling.
That is not correct. I gave my explanation based on the alpha particle. I did not give my explanation for tunneling phenomenon in general. Besides, you haven't defined how "forms of motion" is related to tunneling process in general. My argument earlier is that the time rate of decay of a free neutron has nothing to do with any spatial displacement. Yet, its decay rate is well-defined.
Zz.
vld, in the context of this thread, what does special relativity have to say about doing things instantly? What does it say about the absolute meaning of distances in space compared to distances in spacetime? Does special relativity really allow the sort of time-independence that you`re talking about? Are these things related?
Of course, nothing can happen instantly, and in a real physical system one will need a finite time to measure a distance. But this artificial theoretical construction shows that you can use ANY amount of time to measure a distance, which is what actually means that such a measurement is time-independent. But an important point is also that it is GR (not SR) that might help us to get insight into the deeper properties of time and motion. In fact, the very postulate that "nothing can happen instantly" might be a good starting point in the exploration of these properties. As for the absolute meaning of distances, I don't think this makes much sense because to measure a distance one has to compare it with some other distance (that is, involving at least two entities and their relationship).
But you have not even addressed by what it means to measure a "space" or a "length". Your "theoretical construction" doesn't tell me how I could measure it. Compare that to how SR/GR indicates how length and time are measured.
Zz.
(ict,x)
The existence of various equivalent formulations of GR, including graviton scattering, torsion, polarisable medium, etc., means that the underlying physical reality might be richer than any of that theories. When we deal with something unknown, none of the working models has to be dismissed beforehand. The hidden variables model has the right to be explored as well.
I thought this was the main idea of GR: the entire evolution is determined locally
That is what I was talking about: out notion of time might be incomplete being conditioned by periodic motions of matter around us but eventually converted in a concept of absolute uniform time. Realising that time is neither absolute nor uniform (not speaking about its anisotropy) makes this concept richer.
I thought that the speed of light is not a limit in QM since some quantum processes are assumed to happen instantaneously (e.g. the reduction of a quantum state).
vld said:
As for the absolute meaning of distances, I don't think this makes much sense because to measure a distance one has to compare it with some other distance.
Yes, one must introduce standard rulers. But according to relativity, one must also introduce standard clocks because there can still be disagreement in when measurements are made. What we need are quantities whose measured properties do not depend on the choice of standard rulers and clocks consistent with the principles of relativity. One helpful notion is that of proper length. We define the proper length of an object as being that measured by an observer at rest with respect to that object. Different observers who are not at rest with respect to that object will measure a different length because their clocks will not record time at the same rate that the proper clock does. This impossibility of separating time and space is the core idea of relativity.
vld said:
(ict,x)
Whatever you want :rolleyes:
Euhh, I insisted throughout this thread on determinstic hidden variable reformulations ! I thought that was clear. :confused:
Hem, I was talking about GR not having a good deterministic reformulation yet (and one will have to do its utmost best to make it local !)
True, clocktime is conditioned by periodic motions, but as I said before, clocktime is a derived concept (with an underlying Newtonian time).
Ah, just forget about this reduction of the wave function and all that crap. There is clearly something else going on, but whatever it is, it must involve things traveling faster than light in vacuum (just as in QFT correlations outside the lightcone do exist), but we have to properly define signals so that they do not travel faster than light in vacuum (the no FTL signalling theorem in QFT). Clearly, this implies that SR must be only true at the coarse grained level (the level of signals).
Careful said:
...reduction of the wave function...must involve things traveling faster than light in vacuum...we have to properly define signals so that they do not travel faster than light in vacuum...
To make sure we`re on the same page here, what did you mean by these remarks?
You have to read it as follows :
(That is the *single* mechanism reproducing the quantum correlations must be very different from wave + measurement)
but whatever it (this mechanism) is, it must involve things traveling faster than light in vacuum (just as in QFT correlations outside the lightcone do exist), but we have to properly define signals so that they do not travel faster than light in vacuum (the no FTL signalling theorem in QFT).
