Mentor
- 50,932
- 26,975
michael879 said:What exactly does time reversal entail? And how do you represent it mathematically??
I think at this point we need to go back to basics. First, let's restrict attention to what you called "local" transformations; i.e., we're looking at a specific event in spacetime and what happens when we do various transformations on the local coordinates. But we can always write local coordinates in Minkowski form, so what we are really looking at with the local transformations is transformations on Minkowski spacetime--more precisely, we are looking at *isometries* of Minkowski spacetime, transformations that leave the Minkowski metric invariant.
The full set of such transformations is the 10-parameter Poincare group:
http://en.wikipedia.org/wiki/Poincaré_group
The 10 parameters break up into 4 translations (one in each of the four spacetime dimensions) and 6 "rotations", and the latter, if you choose a particular local inertial frame, can be further broken up into 3 spatial rotations and 3 boosts.
However, there's also another way of looking at this group, as the Wikipedia article states:
"As a topological space, the group has four connected components: the component of the identity; the time reversed component; the spatial inversion component; and the component which is both time reversed and spatially inverted."
In other words, there are four transformations we can pick out of the whole Poincare group that have special significance: 1 (the identity), P (parity), T (time reversal), and PT (combined parity and time reversal). These four are special because they form a sort of "basis" of the group: any arbitrary element of the Poincare group can be expressed as the composition of one of these four transformations with a transformation from the restricted Lorentz group, the group of "Lorentz transformations" that is usually talked about in basic special relativity courses (this restricted group is really just the component of the Poincare group that is connected to the identity).
So to find a suitable mathematical expression for time reversal, we need to first pick a representation of the Poincare group to work with. But since the full Poincare group is basically just four "copies" of the Lorentz group, each multiplied by one of (1, P, T, PT), we really just need to pick a representation of the Lorentz group:
http://en.wikipedia.org/wiki/Representation_theory_of_the_Lorentz_group
Then we need to make sure that this representation still works when we extend it to cover the full Poincare group by multiplying by (1, P, T, PT), with suitable representations for those four transformations. Doing that last step should give us a mathematical representation of time reversal in a local inertial frame. We could then look at how to transform that to a global set of coordinates.
Of course the problem with the above is that there are lots of representations! However, as you can see from the Wiki article I just linked to, which representation you want to use is really dictated by what you are trying to represent, e.g., if you want to represent the electromagnetic 4-potential you use the (1/2, 1/2) or 4-vector representation. So when we get to the point of looking at how time reversal acts on a complicated expression like that for the Kerr metric, we may actually be dealing with compositions of objects from different representations.
Having just thrown a whole bunch of additional complexity into the mix
Edit: Saw your edit after posting, the above may be moot but I think it's still useful background. Will wait to see your further post.
