Curious About Symmetric Number Sequences
  • Level: Undergrad
  • Thread starter hariz91
12 replies · 2K views · last reply
hariz91
TL;DR
I've been exploring symmetric sequences like 1,2,1 and 1,2,3,2,1. The middle number seems to produce a new value. I'm curious if this pattern has a name or if anyone has explored it before.
I’ve been exploring number patterns as a personal interest — particularly symmetric sequences like 1, 2, 1 or 1, 2, 3, 2, 1. I noticed that the middle value in these sequences sometimes seems to produce a new number when combined in a certain way. For example:
- 1, [2], 1 → gives 0
- 1, 2, [3], 2, 1 → gives 3
- 1, 2, 3, [4], 3, 2, 1 → gives 8
- 1, 2, 3, 4, [5], 4, 3, 2, 1 → gives 5
- 1, 2, 3, 4, 5, 6, 7, 8, 9, 8, 7, 6, 5, 4, 3, 2, 1 → gives 63
I’m not sure if this pattern is already known or if it has a name. I’m just curious — has anyone seen something like this before? I’d appreciate any thoughts or references.
jedishrfu said:
How are you getting those results?
Thanks for the question. I got those results from a simple process I’ve been playing with:
1. I imagine 0 as a source that releases the value 1, one after another.
2. The first 1 appears — it’s just there.
3. When the second 1 appears, the two 1s interact and produce a new value: 2. They form a symmetric sequence: 1, 2, 1.
4. When the third 1 appears, it interacts with the first 2 to produce a new 2, then the old 2 interacts with the old 1 to produce 3, and then interacts with the other 1 to produce another 2. The sequence becomes: 1, 2, 3, 2, 1.
5. Each time a new 1 appears, the same process continues — building a symmetric sequence step by step.
I’m not claiming this is a new discovery — it’s just a number pattern I found interesting and wanted to share.
0, 3, 8, 15, 24, ... is a known sequence with a general term n2-1 where n=1, 2, 3, ..., but I do not know if it has a particular name.
By the way 1, 2, 3, 4, 5, 4, 3, 2, 1 gives 15.
Do you mean 15 instead of 5?
This description may be meaningful to you, but when communicating with other people it is not helpful to use phrases like "the two 1s interact and produce a new value: 2".
The way the sequences develop is quite clear from listing them, you don't need any words for this. What is not at all clear though is how you get the numbers on the right (0, 3, 8, 5, ... 63)? Others have noted that these seem to follow the pattern ## (n - 1)^2 ## where ## n ## is the bracketed number (assuming you meant to write 15 instead of 5 - you should take more care), but this doesn't fit your description.
When you have a sequence you are not sure about, a good place to find out more is The On-Line Encyclopedia of Integer Sequences® (OEIS®).
My apologies, I made a calculation mistake
- 1, 2, 3, 4, [5], 4, 3, 2, 1 → gives 15
I'm sorry...
By following the patterns provided by the original poster, it seems to me that the original poster has used the next calculation for getting the sequence 0, 3, 8, 15, 24, …
For the general term an there is a pattern
1, 2, …, n-1, n, [n+1], n, n-1, …, 2, 1
and there is the calculation
an=1+2+...+(n-1)+n+n+(n-1)+...+2+1-(n+1)
an=2(1+2+...+(n-1)+n)-(n+1)
an=2n(n+1)/2-(n+1)
an=n2+n-n-1
an=n2-1
an=2n(n+1)/2-(n+1)
an=n2+n-n-1
an=n2-1
‎Whether we look at the arrangement or the formula, the n^2 - 1 sequence consistently follows a clear quadratic pattern. Even though the gap between numbers gets bigger, it's completely predictable and not random at all.
Sorry, I might be dense. I understand where people are getting the ##n^2-1##, but I have no clue what the OP means by "gives", other than that.
I give up.
No. Its not you. I am not sure why the OP did not simply write:
"consider the following sequence":
  • 1 - 2 + 1 = 0
  • 1 + 2 - 3 + 2 + 1 = 3
  • 1 + 2 + 3 - 4 + 3+ 2 + 1 = 8
  • 1 + 2 + 3 + 4 - 5 + 4 + 3+ 2 + 1 = 15
  • 1 + 2 + 3 + 4 + 5 + 6 + 7 + 8 - 9 + 8 + 7 + 6 + 5 + 4 + 3 + 2 + 1 = 63
  • 1 - 2 + 1 = 0
To me, the method used doesn't really matter as long as the math is correct. The real point I wanted to make is how endlessly versatile numbers from 0 to 9 can be. It might seem trivial or meaningless to some, but for someone like me who loves discovering patterns, it’s truly beautiful. It feels as though we can never really run away from the magic of numbers.
You seem to be using the "reply" or "quote" functions incorrectly which makes it very difficult to reply to your messages: your own reply should not be inside "QUOTE" delimiters.
But the math isn't correct: "[]" is not the symbol for subtraction and "→" and the word "gives" are not the symbol or term for equality.
One of the most significant features of mathematics is that it has symbols and terms that enable people to communicate regardless of their background or abilities: if you want to communicate your ideas then you need to use these symbols and terms.
