Find Reliable Current Density Sensors for Aluminum Foil Treatment
The discussion focuses on finding a reliable supplier for current density sensors, specifically Hall probes, for measuring current density in aluminum foil treatment tanks used in electrolytic capacitors. The user is seeking assistance in locating suppliers in Europe and the USA, as they have been unsuccessful so far. The measurement involves a DC current density, despite the initial AC supply being converted to DC for the process. Participants suggest that Hall probes are preferable to ammeters due to their minimal disturbance to current flow. There is also a discussion about the importance of understanding the geometry of the tank to ensure accurate current density mapping.
maconga
Hi all, don't know if this is the appropiated place to search. I am trying to find a supplier for a current density probe (Hall sensor or similar) to measure the current density in a tank where an aluminum foil is treated to form electrolitical capacitor.
Im searching for this in Europe and USA but can't find the supplier.
Could someone guide me please on this topic?
Thank you in advance
Welcome to the PF. :smile:
Can you give more details about the setup, and maybe post a couple pictures? (Use the UPLOAD button to attach pictures)
Is this a DC current density, or AC too? If AC is involved, what frequency range?
Hi Berkeman, thanks very much for replying,
The idea is to measure the density of current flowing in the solution during the process between foil and cathode by introducing a Hall probe (dont know why a Hall probe and not just an ammeter) into the solution.
We treat an etched aluminum foil in a few tanks with solution where we apply certain voltage.
I need to know which is the current density in the solution so we can know the current on the surface foil.
Many years ago we they used to work with Hall probes.
What we have in the tanks is a DC current density. The electricity from the transformers is AC but it’s converted into DC when it’s supplied to the machines.
As you can notice I am not a specialist at all in this field, but I was given this topic and can't find any supplier :/
Thanks for your support.
Can you just measure the overall flow and divide by the area? Or is the current density different in different areas of the tank, and that's what you want to map out?
I think you would use the Hall sensor because it would disturb the currents to try to use any conductive ammeter arrangement.
I'm not sure how to waterproof it, but I think the basic idea would be to use a Hall current sensor probe like the one below, and have a short straw or similar through the center hole to let the current flow through to be measured...
http://www.alliedelec.com/images/products/Small/70282708.jpg
Likes marcusl
I think in electroplating current density refers to amps per square inch of the object being plated.
Like you i can only find references to companies that don't seem to exist anymore.
https://www.openfos.com/supply/2509245-INDUSTRIAL-INSTRUMENTS-in-Newport-News-VA/
http://www.ebay.com/itm/PLATING-CURRENT-DENSITY-MICRO-OHM-METER-/231205023788Here's an old patent for such a meter, based on ohm's law.
US003347770
http://pdfpiw.uspto.gov/.piw?PageNu...BPN/A000000%26RS=PN/3347770%2BOR%2BPN/A000000
I once visited an industrial electroplating concern who used rectangular tanks with planar electrodes on opposite sides, so as to produce uniform current density J. This makes sense, since any non-uniform J would deposit a film that varies with position. Accordingly, berkeman's suggesting would work well.
This is the key question. Please provide details of your geometry.
Likes berkeman and dlgoff
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
