Undergrad Cyclic rotation of the cross product involving derivation
The discussion centers on the complexities of cyclic permutations in the cross product, particularly when involving vector operators like momentum and vector potentials. It highlights the distinction between operator equations and vector equations, emphasizing that the cyclic permutation rule does not apply straightforwardly when operators are involved. Participants explore the implications of defining vector potentials and the conditions under which certain identities hold, especially in the context of constant magnetic fields. The conversation also touches on the importance of understanding the underlying vector calculus and operator identities to avoid confusion in derivations. Overall, the thread serves as a learning experience for those grappling with the nuances of vector calculus in theoretical physics.
Garlic
TL;DR
How does the cyclic rotation of the cross product work, if one of the vectors is an operator acting on the other?
Dear PF,
so we know that cross product of two vectors can be permutated like this: ## \vec{ \alpha } \times \vec{ \beta }=-\vec{ \alpha} \times \vec{ \beta} ##
But in a specific case, like ## \vec{p} \times \vec{A} = \frac{ \hbar }{ i } \vec{ \nabla } \times \vec{A} ## the cyclic permutation of the cross product isn't that simple, because the ## \vec{p} ## is an operator acting on ## \vec{A} ( \vec{r} ) ## and the wave function ## \psi( \vec{r} ) ## (which isn't implicitly shown).A professor of mine writes
$$ \vec{p} \times \vec{A} = - \vec{A} \times \vec{p} + \frac{ \hbar }{ i } ( \vec{ \nabla } \times \vec{A} ) = - \vec{A} \times \vec{p} + \frac{ \hbar }{ i } \vec{B}
and I've also seen him writing "## \vec{B} = \vec{ \nabla } \times \vec{A} ## , therefore ## \vec{A} = \frac{1}{2} ( \vec{r} \times \vec{B}) ##" which leaves my poor soul utterly confused.
What is the general rule of the cyclic permutation a cross product, can one derive this rule only by knowing the chain rule and the basic rules of cross product?
Thank you for your time,
-Garlic
Let's start with a simpler example. We have the differential operator ##\frac d {dx}##. And, any function ##g(x)## can be seen as an operator, where the action of the operator is the simple product: $$g(x)[f(x)] = g(x)f(x)$$ Now, we may consider the operator "product" (which is defined by composition) of these:
$$(\frac d {dx})(g(x)) \equiv (\frac d {dx} \circ g(x))$$ And the action of this product (or composition) of operators on a test function ##f(x)## is seen to be:
$$(\frac d {dx})(g(x))[f(x)] = \frac d {dx}[g(x)f(x)] = \frac {dg}{dx} f(x) + g(x)\frac{df}{dx} = (\frac {dg}{dx} + g(x)\frac d {dx})[f(x)]$$ And this gives us an operator identity:
$$ (\frac d {dx})(g(x)) = \frac {dg}{dx} + g(x)\frac d {dx}$$
In your case, you need to establish the definition of the cross product of two vector operators. The natural definition would be as follows:
$$\vec A \times \vec B =
\begin{vmatrix}
\hat x & \hat y & \hat z\\
A_x&A_y&A_z\\
B_x&B_y&B_z\\
\end{vmatrix} = (A_yB_z - A_zB_y)\hat x + (A_zB_x - A_xB_z)\hat y + (A_xB_y - A_yB_x) \hat z
Where the product of operators is defined as usual by operator composition. E.g.
$$(A_yB_z)[f] = A_y[B_z[f]]$$
Now, if you use that definition and do some algebra, then the vector operator identities pulled out of the hat by your professor should be provable.
Likes sysprog and Garlic
This is a neat trick where if we define $$\vec{A} = \frac{1}{2} ( \vec{r} \times \vec{B}) $$, we can show that $$ \vec{ \nabla } \times \vec{A} = \frac 1 2 \vec{ \nabla } \times ( \vec{r} \times \vec{B}) = \vec B$$
Again, this can be relatively easily proved using the definition of curl and some vector algebra.
PS note that the solution is not unique. The curl of any gradient is zero, so if we define:
$$\vec{A} = \frac{1}{2} ( \vec{r} \times \vec{B}) + \vec \nabla f$$ For any scalar function ##f##, then we also have$$ \vec{ \nabla } \times \vec{A} = \vec B$$
Thank you very much for your replies!
Although I think I understood what you have written, now I'm stuck proving a more complex expression:
## \vec{p} \cdot \vec{A} ## where the identity ## \vec{A} = \frac{1}{2} ( \vec{r} \times \vec{B} ) ## is inserted. I am trying to prove that :
\vec{p} \cdot \vec{A} + \vec{A} \cdot \vec{p} = \frac{\hbar}{2 i} [ \nabla \cdot (\vec{r} \times \vec{B}) + (\vec{r} \times \vec{B}) \cdot \nabla ] = \vec{L} \cdot \vec{B}
I tried to solve this with einstein summation convention:
\vec{\nabla} \cdot (\vec{r} \times \vec{B}) = \epsilon_{ijk} \; \partial_{i} \; r_{j} \; B_{k}
\epsilon_{ijk} \; ( \partial_{i} \; r_{j} ) \; B_{k}
\epsilon_{ijk} \; r_{j} \; ( \partial_{i} \; B_{k} )
\epsilon_{ijk} \; r_{j} \; B_{k} \; \partial_{i}
\epsilon_{jki} \; ( \partial_{j} \; r_{k} ) \; B_{i}
\epsilon_{jik} \; r_{i} \; ( \partial_{j} \; B_{k} )
\epsilon_{kij} \; r_{i} \; B_{j} \; \partial_{k}
\epsilon_{ijk} \; ( \partial_{j} \; r_{k} ) \; B_{i}
\epsilon_{ijk} \; r_{i} \; ( \partial_{j} \; B_{k} )
\epsilon_{ijk} \; r_{i} \; B_{j} \; \partial_{k}
= (\vec{\nabla} \times \vec{r}) \vec{B} - \vec{r} ( \vec{ \nabla} \times \vec{B}) + \vec{r} ( \vec{B} \times \vec{ \nabla} )
= \vec{L} \cdot \vec{B} - \vec{r} ( \vec{ \nabla} \times \vec{B}) + \vec{r} ( \vec{B} \times \vec{ \nabla} )
And;
( \vec{r} \times \vec{B} ) \cdot \vec{ \nabla }
= \vec{r} \cdot ( \vec{B} \times \vec{ \nabla } )
##Therefore I find;
\frac{\hbar}{2 i} [ \vec{L} \cdot \vec{B} - \vec{r} ( \vec{ \nabla} \times \vec{B} ) + 2 \vec{r} ( \vec{B} \times \vec{ \nabla} ) ]
Can you see what I'm doing wrong?
It's funny that although I started learning theoretical physics 5 years ago, but apparently I still didn't understand cross product correctly. Maybe I should relearn cross product rules from the beginning..
Thank you for your time!
-Garli
There's a useful vector identity: $$\vec X \cdot (\vec Y \times \vec Z) = \vec Y \cdot (\vec Z \times \vec X) = \vec Z \cdot (\vec X \times \vec Y)$$You need to be careful how this transforms when you are using the differential operators like ##\vec p##. That might help.
In the meantime, I'll take a look at this.
Likes Garlic
Try redoing your work using a test function. It's too easy to go wrong with operator identities otherwise.
Let's take a closer look at this. There's a subtlety here. Note that the equation $$\vec \nabla \times \vec A = \vec B$$ is a vector equation. It's not an operator equation. Whereas:
$$\vec p \times \vec A = \frac \hbar i \vec \nabla \times \vec A$$ is an operator equation. The symbol ##\vec \nabla## is different in each case. For that reason, I'll avoid using ##\vec \nabla## as a differential operator. To prove this identity we have:
$$(\vec p \times \vec A)[f] = \frac \hbar i((\partial_y A_z - \partial_z A_y)\hat x + (\partial_zA_x - \partial_x A_z)\hat y +(\partial_x A_y - \partial_y A_x)\hat z)[f]$$$$ = \frac \hbar i((A_z \frac{\partial f}{\partial y} - A_y\frac{\partial f}{\partial z})\hat x + (A_x \frac{\partial f}{\partial z} - A_z\frac{\partial f}{\partial x})\hat y +(A_y \frac{\partial f}{\partial x} - A_x \frac{\partial f}{\partial y})\hat z)$$$$+ \frac \hbar i((\frac{\partial A_z}{\partial y} - \frac{\partial A_y}{\partial z})\hat x + (\frac{\partial A_x}{\partial z} - \frac{\partial A_z}{\partial x})\hat y +(\frac{\partial A_y}{\partial x} - \frac{\partial A_x}{\partial y})\hat z)[f]$$$$= -(\vec A \times \vec p)[f] + \frac \hbar i(\vec \nabla \times \vec A)[f] = -(\vec A \times \vec p)[f] + \frac \hbar i(\vec B)[f]$$
And we see that: $$\vec p \times \vec A = -(\vec A \times \vec p) + \frac \hbar i \vec B$$is a valid operator equation. Whereas: $$\vec p \times \vec A = -(\vec A \times \vec p) + \frac \hbar i (\vec \nabla \times \vec A)$$ is not a valid operator equation (as we must interpret ##\vec \nabla## as simply a vector operation and not as a functional operator).
The other option, of course, is to put hats on operators in order to make the distinction.
Likes sysprog, Garlic and dextercioby
I don't get this to come out. I'm assuming that ##\vec L = \vec r \times \vec p##.
@Garlic what I forgot is that ##\vec A = \frac 1 2(\vec r \times \vec B)## is only a solution for constant magnetic field ##\vec B##. The identity should drop out easily enough in that case. Although, perhaps not quite.
That said, your working in post #4 looks like it has a few mistakes.
Likes Garlic
Again: The correct vector potential is (note the different sign!):
$$\vec{A}=\frac{1}{2}(\vec{B} \times \vec{r}).$$
Proof:
$$\vec{\nabla} \times \vec{A} = \vec{e}_j \epsilon_{jkl} \partial_k A_l =\frac{1}{2} \vec{e}_j \epsilon_{jkl} \partial_k (\epsilon_{lmn} B_m r_n)=\frac{1}{2} \vec{e}_j (\delta_{jm} \delta_{kn}-\delta_{jn} \delta_{km}) B_m \delta_{kn} = \frac{1}{2} \vec{e}_j (3 B_j-B_j)=\vec{B}.$$
Likes sysprog, Garlic and PeroK
After struggling with this problem I finally understood it.
My solution:
\vec{ \nabla } \cdot ( \vec{ B } \times \vec{ r } ) = \partial_i \; \epsilon_{ijk} \; B_j \; r_k
= \epsilon_{ijk} \; ( \; ( \partial_i \; B_j \; ) r_k + B_j \; ( \partial_i \; r_k ) + B_j \; r_k \; \partial_i )
= \epsilon_{ijk} \; B_j \; r_k \; \partial_i
Where the first term vanishes because we have a constant magnetic field ## \vec{B} ##
and the second term vanishes because ## \partial_i \; r_k = \; \delta_{ik} ## and ## \epsilon_{ijk} \; \delta{ik} = \; \epsilon_{iji} = 0 ## .
Therefore
\vec{p} \cdot \vec{A} + \vec{A} \cdot \vec{p} = \frac{ \hbar }{ 2 i } \cdot 2 \; \epsilon_{ijk} \; B_j \; r_k \; \partial_i
= \frac{ \hbar }{ 2 i } \cdot 2 \; \epsilon_{kij} \; B_i \; r_j \; \partial_k
= \frac{ \hbar }{ 2 i } \cdot 2 \; \epsilon_{ijk} \; B_i \; r_j \; \partial_k
= \frac{ \hbar }{ i } \; \vec{B} \cdot ( \; \vec{r} \times \vec{ \nabla } ) = \vec{B} \cdot \vec{L}
I tried to analyze the reasons why I had so much trouble proving this equation.
What I didn't think about in the beginning:
- Constant magnetic field ## B \rightarrow \partial_k \; B_m=0 ##
-I forgot some basic things about einstein summation convention like the fact that ## δ_{nn}=3 ##
-When I chose ## \vec{A}=−\frac{1}{2} \vec{r} \times \vec{B} ## I got a slightly different but physically equivalent expression, which needed to be transformed using ## \vec{r} \cdot ( \vec{B} \times \vec{ \nabla })=−\vec{B} \cdot (\vec{r}×\vec{ \nabla }) ## in order to get ## \vec{B} \cdot \vec{L} ##
-The lecture notes weren't mine, so the person wrote ## \vec{L} \cdot \vec{B} ## instead of ## \vec{B} \cdot \vec{L} ## which confused me a lot.
My conclusion:
I learned many things from this post and I hope this question will help others who also struggle with this problem. I would like to thank everyone for their help!
Likes sysprog, vanhees71 and PeroK
For ##\nabla\times({\bf r\times B})## with ##\bf B## constant, use the algebra 'bac minus cab,
bur the order must be ##\bf B\nabla r##, so ##\nabla## acts only on ##\bf r##.
Then, ##\nabla\times({\bf r\times B})=(B\cdot\nabla)r-B(\nabla\cdot r)##.
Well, correct is
$$\vec{\nabla} \times (\vec{r} \times \vec{B})=(\vec{B} \cdot \vec{\nabla}) \vec{r}-\vec{B}(\vec{\nabla} \cdot \vec{r})=\vec{B}-3 \vec{B}=-2 \vec{B}.$$
The "nabla calculus" is shorter but imho much less clear than the Ricci calculus (see my posting #10).
Likes sysprog
